Rogue Engineering 2.5” resonated section 1
I was thinking the same thing. Ben said yes its possible. Im assuming a GESI catalytic converter would fit but don't quote me.Originally posted by ridebikes View PostLooks very cool. This is a bit of a newb question: would it be possible to weld a cat into a piece like this? Or would it never make sense to do that when you can simply buy a catted section 1 if you want to run a cat?
DropTopKingM3 you are the devil on my shoulder getting me to give all my money away!
It started with the Black Friday Eventuri Deal, now this
Sure would go nice with my Diablo section 3.
Ahah even my friends tell me I’m a bad influence sometime. But did they die ? 😂😂Originally posted by cbean View PostDropTopKingM3 you are the devil on my shoulder getting me to give all my money away!
did the eventuri come in yet ?
I ended up buying an Eventuri too because of him lolOriginally posted by cbean View PostDropTopKingM3 you are the devil on my shoulder getting me to give all my money away!
Sure would go nice with my Diablo section 3.Instagram: @logicalconclusion
- Likes 2
You would hope. Isn't the box in our stock sect 2 so?Originally posted by digger View Postnot a fan of it unless its fully partitioned
Also, there are no 2.5" header outlets that mate using stock style flanges. So you've got 55mm > 63.5mm back down to 57.5mm or so in sect 2.
Seems to me, if you're gonna go 2.5" at all, the headers should be priority. But if you do 2.5" ssv1s, you can't mate to this RE sect 1.Last edited by Tbonem3; 12-10-2020, 10:22 AM.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
That would make no sense for someone to use this section 1 then...from a performance/ flow/ pipe sizing standpointOriginally posted by Tbonem3 View Post
I think it might flow a bit better, but what 3-5hp? Just put the $600 or whatever this pipe costs towards stepped headers imo. Ssv2 + stock sect 1 over euro headers + this pipe is my guess.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Is the 3-5hp an estimate for this section 1 or are you referring to SSV2? If so would it be beneficial for someone who wants to eliminate rasp and add 3-5hp?Originally posted by Tbonem3 View PostI think it might flow a bit better, but what 3-5hp? Just put the $600 or whatever this pipe costs towards stepped headers imo. Ssv2 + stock sect 1 over euro headers + this pipe is my guess.
The description alludes to the need for greater sound control as being the primary purpose for development. I'm sure some customers were critical of the smaller tubing in the early version so they wanted to meet customer expectations. Sure, v2 will flow more on its own and you can't fault them for marketing as such.
But this is all tells you that there aren't going to be meaningful improvements to power - that's where Tbone was going.
Edit - I'm curious what Rogue means by muffler-style solution and wonder if that means internal baffling.'05 M3 Convertible 6MT, CB/Cinnamon, CSL Airbox&Flap, PCSTuning, Beisan, Schrick 288/280, SS V1's & 2.5" System, RE Stg 1&SMF, KW V2, CB PS, Apex EC-7R
