Where to buy 420G input bearing?
    Where are people getting those these days?
    Any leads would be appreciated!
    IG: @limited.slip
    Alpine White 1 Series M Coupé
    Sucks.
    try and get the measurement of it.
    *edit* check here https://123roulement.com/ with the numbers you find on the bearings.
      what happened?? how many miles on this? ive never hear many people replacing this one
        Bump
        Instagram: @logicalconclusion
          Tell us more of what happened. Can you post any numbers on it?
            I do not know what happened beyond what is shown in the photo. Chunks of the bearing cage and ball bearings fell out as I pulled the trans away from the bellhousing.
            I only drove the car a very short distance prior (from the tow truck to the work area) and did not notice or hear anything weird at that time. The owner didn't mention anything either.
            IG: @limited.slip
              The outer race stays with the BH, the inner race with the input shaft, in most cases. If the BH not parallel with the transmission during pulling, the bearing could cock causing the plastic balls spacer to break. There must be part number on the races.
                I bought what seems to be the last one available, shortly after installing my bell housing over a year ago. I still have not installed mine, but my noise hasn't changed. The next time I drop my transmission I'll be addressing it. I got mine from 123bearing.com Product # was 577318A-FAG
                  kaiv Burkhart-Engineering sells syncros for the 420g, maybe they have source for bearings too?
                  Email to [email protected]
                    Deep Groove Ball Bearing 577318A-FAG, Inner diam. 45 mm, Outer diam. 90 mm, Width 21 mm
                    any place that specializes in seals and bearings will get this variation. doesn't need to be a FAG. just give them the details and they will point you to the right one.
                      This one has the same dimension but without seal which I don't think it's needed in this application.
                        Anyone find a place to buy this 577318A bearing? Everywhere I'm looking is out of stock
                          Do you have a link to the synchros? Thanks.
                            They've re done their website and I can't find it now... I'd send them an email.
                              Yeah dont see them on there either.
