Bmw X5 E53 Rear differential on M3 E46
    hello ! have my M3 E46 since 10 year ago.
    i'm in love for it but my lsd is totally destroy since many year. it make a very loud noise when i shift gear or turn left or right.
    after a lot of research for a m5 e34 3.91 big crankcase bridge. it seems rarer than adamantium.
    I discovered that the X5 E53 3.0D Have 3.91 big case differential.
    I can't find much information
    Has anyone ever tried mounting the internal X5 IN m3 e46 case?
    Apparently it fits but I've never seen it done in the US.
    2005 BMW ///M3
    Black6MT Daily
      I could certainly be missing something but a quick google shows the case- and cover-mounting points completely different. If you're talking switching in the innards between the two then it certainly couldn't be worth the time and effort.
      I must be missing something...
        May be able to just swap over the E46 M3 differential cover and reinstall?
          Both the X5 4.6is and 4.8is also use 3.91 Large Diffs. May as well just pull the the ring and pinion and swap into the m3 diff, rebuild/replace the lsd and refresh bearings and races, etc. My .02 from the research I've done on the subject.
            anyone have done this? I mean not only from research? Would be a good/cheap source for 3.91 ratio.
            …under construction.
              If its a type 215 diff, the R&P will not work in a large case diff. All of the large case diff internals are interchangeable across the chassis specific case.
              Here's a list...
              E24 M6
              E24 633 CSi
              E24 63 5CSi
              E28 M5
              E32 750iL
              E34 M5
              E36 M3 (Euro Only)
              E39 M5
              E46 M3
              I think select E34 535s or 540s have the large case diff.
