Installed square APEX ARC-8 18x9.5 ET35, 12mm spacers in the rear with new 4 265/35/18 Michelin Sport A/S 3+ all around...nothing but red tpms light since install. I’ll reset and comes back after a few minutes of driving. Went back to the shop and all checked out as far as pressure and no flat tires. Any ideas or is this a part of running this setup? Appreciate any help!
APEX ARC-8 Red TPMS Light
From a quick search, make sure you follow this properly.
1. Check Tire Pressure to make sure no variance from side to side.
2. Sit in car, with out touching the pedals.
3. Key in ignition, Turn key on to engine off position (second position).
4. Press and hold TPM until TPM lights go out completely on the dash.
5. Press and hold TPM again until yellow TPM light indicator comes lit on dash.
6. Start car and drive. Light will go off itself once it has calibrated tire pressure. (might go out at idle).2006 Silber Grau Metalizat ZCP 6 MT
- Likes 2
I had the same issue and it was driving me nuts. I did a sequence like this (I think I found it on M3Cutters originally) and my TPMS light finally went out and stayed out. Weird system.Originally posted by CrisSilberGrau View PostFrom a quick search, make sure you follow this properly.
6. Start car and drive. Light will go off itself once it has calibrated tire pressure. (might go out at idle).'03.5 M3 SMG Coupe - Jet Black / Black
Worked like a charm...no light on the last drive. Thank you for the help!Originally posted by CrisSilberGrau View PostFrom a quick search, make sure you follow this properly.
6. Start car and drive. Light will go off itself once it has calibrated tire pressure. (might go out at idle).‘02 TiAg/Impulse Slicktop
