I took another look today. There is definitely a leak coming from the timing chain tensioner - there were all kinds of oil and grime under it. I tried snugging it up and didn't get it to budge, but I had to use a weird combination of a 32mm deep impact socket, 1/2 to 3/8" adapter, u-joint and ratchet. That didn't provide the best of leverage. Do you guys use a short 32mm, or a 1/2" u-joint and a deep socket? I will need to get the correct tools for this job, especially if I'm to replace the washer. I also tried to inspect the bolt behind the thermostat housing. It appeared dry from what I could see.
sapote asked if sealant was used on the VCG - there is some at least in the corners. I've read that's where it's supposed to be applied anyway. However, the VANOS itself looked pretty grimy on the exhaust side.
See photos below. Would you guys say the VANOS could be the cause of the timing chain tensioner leak? Thanks again for the help!
