My car has been suffering from intermittent Rough running/misfire, makes no difference if it's hot or cold, it just comes and goes, not sure how to describe it apart from it feels flat when driving at normal 2-3K revs and the vibration can be felt and heard even when letting off the throttle and slowing down.
The only fault code I have is a shadow/pending P0128 which seems to point towards the thermostat, or if not the coolant temperature sensor.
Can plugs/coils cause this?
fingers crossed it's not head gasket. Can you describe what your misfire was like? Aren't head gasket failures normally noticed under load, with a noise aswell?
