My exhaust timing was a bit off after I installed the Vanos and and I am having a bit of an issue adjusting it.
In the Beisan anti-rattle procedure right at the end it decribes how to adjust timing post vanos install. I have followed the procedure and it doesn't seem to be helping.
(Said timing instructions are at the very bottom)
Summation:
- With crank at TDC with cyl 1 cam loosen top 3 sprocket bolts.
- Turn Crank to TDC again and insert crank locking pin. (Cylinder 1 cam lobes are now roughly pointing at each other)
- Retard cams and loosen remaining 3 sprocket bolts that are now accessible.
- Using bridge tool rotate (CW rotation in my case of exhaust cam) cam(s) until the bridge sits flat on head with pin installed.
- Tighten 3 top sprocket bolts a bit
- Turn engine to TDC tighten 3 sprocket bolts to 14nm (by hand)
- Turn engine over again to TDC (cam lobes pointing to each other) and finish tightening top 3 bolts to 14nm
- Cams should now be in time
I have done this 3 times and my exhaust cam doesn't seem to be adjusting at all, do I need to remove the vanos to really re-time the engine? What could I be doing wrong here?
Summation:
