I hope nobody is going to torque this nut to 40Nm or 29.5 ft lbs -- as called out in the torque spec file -- to the water pump shaft as this is unnecessary and causing headache to remove later. Just snug it to 1ft lbs is enough. To remove, just hit the wrench with a hammer and no special tool needed.
Fan clutch nut to water pump torque spec = 40Nm?
