Sapote:
Hub tangs to disc = ~.7mm
Mau:
Beisan disc thickness outside edge = 19.93mm
Beisan disc thickness to "stepped" area = 20.09mm
Failed vanos test post Beisan
I measure ~0.6mm on mine. You can see my picture some pages back. Is difficult to get the gauge to attack perpendicular to the gap for a precise measurement
If the stock hub tabs have the radius corners instead of sharp machined 90 degrees corners (which are stress risers leading to breakage), then the gap is smaller.
To reduce this gap, one cannot add shim behind the hub as this affect the cup spring force. The only option is to add shim between the disc and tabs.Last edited by sapote; 03-25-2021, 05:36 PM.
I think stack up your feeler gauge blades will be even better than compass. BUT DON'T DROP THEM IN THE BLACK HOLE.
I haven't measured that yet, I'll try to get that dimension before closing it up. I think I have a compass somewhere, might go find one today.
might be able to use feeler gauge set from valve adjustment to measure the gap. Just sandwich some of the gauges together then use calipers to measure the thickness.
The OE disc might have less leakage at the center shaft, but the final gap between the OE disc and the hub tabs can have negative affect on the pump pressure if the offset is too much and causing oil holes blockage or partially blockage.
Did you measure the gap from disc to tabs with the disc flush to the center shaft end?
I hear you, one thing I think we can agree on is the pressure test is most definitely independent of the S54 vs S62 springs. So if my response time improves/worsens it may be directly related to S54 springs and/or hubs bolts torque, although they were to same spec with same tool. However if the pressure goes from 40bar to 100bar then we can focus on disc unless of course there is something to the hub to disc relation and installation practices. But the disc rests in the roller bearing so its free to move around bit regardless of how it was assembled.
It's a pain to remote/install the VC; the vanos job is not that much time consuming.
Originally posted by Cubieman View PostI hear you, one thing I think we can agree on is the pressure test is most definitely independent of the S54 vs S62 springs.
Did you measure the gap from disc to tabs with the disc flush to the center shaft end?Last edited by sapote; 03-25-2021, 02:46 PM.
Originally posted by heinzboehmer View Post. I kinda wish you would have changed one thing at a time just to see what difference each individual component makes.... If only it weren't such a pain to get the VANOS on and off...
Originally posted by heinzboehmer View PostHope this fixes your problem cubie. I kinda wish you would have changed one thing at a time just to see what difference each individual component makes. But, tbh I probably would've just changed everything at once too. If only it weren't such a pain to get the VANOS on and off...
Originally posted by maupineda View Postit is the same on my spare VANOS, the disc takes some persuasion to slide in and out, needs to be done straight forward or it sort of gets stuck. we will see with your pressure and VANOS test but I suspect your will be good (crossing my fingers).
