S54 Vanos post Beisan/DV Rebuild Timing Issue
    Thank you for replying, I will go with Sapote method
      “4. The timing: turn both hubs full CCW, then insert the splined shafts into the hubs and if needed, turn the hub not more than 1 tooth to align the splines to get the shaft inserted in about 5mm​”
      A typo, it should read full CW, not ccw. I will edit the original post.
        Thank you kindly Everyone
        There are a lot of different way to do this
        I tried sapote method, was unsure how far back to install splines,
        So i installed the vanos the way dirtydans did it in his part 4 video 37min30seconds
        1. attached splines to vanos
        2. pushed pistons in vanos back all the way
        3. left all hub bolts loose
        4. set up vanos with spines attached into pre marked sweet spots on splines
        5. pushed vanos in completely, all in 1 push with oil pump aligned straight to the head
        6. tightened vanos to head with 5 bolts
        7. tightened 4 hub bolts on each intake and exhaust
        8. removed vanos
        9. torqued all hub bolts to 14nm
        10 reintalled vanos
        turned the engine by hand twice and engine returned TDC with cam tool perfectly
        Now how do i check the vanos is timed correct ?
        thanks again for helping
        NB >>
        Turning the engine after vanos install, to check cams are at TDC, does not mean vanos is set correctly, Please have a look here - VANOS INSTALL INCORRECT
        NB2...
        Solenoid pack and block are not installed when checking cams are TDC after motor rotation
          8. removed vanos
          10 reintalled vanos
          NB >>
          NB2...
          You pushed the pistons all they way back into the VANOS unit in step 2 before tightening the hubs, so the VANOS should be properly timed. One can verify the piston position by pulling off the pistons caps, but it is not necessary when following the Beisan instructions.
            Like slideways said, if you pull the caps now and they are both at the end of the beveled edge, then timing is good and move on.
              8. removed vanos
              10 reintalled vanos
              The above steps can cause timing error, as the pre-tension the two hub bolts is missing.
              "I tried sapote method, was unsure how far back to install splines,"
              I clearly said insert the shafts in about 5mm into the hubs here.
              I wrote: " The timing: turn both hubs full CW, then insert the splined shafts into the hubs and if needed, turn the hub not more than 1 tooth to align the splines to get the shaft inserted in about 5mm. " Although I forgot to write pretension the 2 hub bolts at this step.
                I pulled my Vanos out yesterday to check on my cam bolts.
                Back in 2013, I replaced all the original cam bolts with the new T30 bolts while also applying blue Loctite (non-oil resistant). A few weeks ago, I heard a very faint "Marbles in a Can" sound, so I figured I would inspect the bolts to see if any were loose. The plan was to replace any bolts that were loose and /or replace the non-oil resistant Loctite with Loctite 243.
                None of the bolts were loose , but I still used the Loctite 243 for peace of mind.
                All of this is to say the timing on these engines does not have to be complicated, but all the different methods add to the confusion.
                After struggling to get my engine timed to PERFECTION back in 2013 (so much so that I ended up disconnecting the top and bottom timing in a bonehead move that, luckily, I was able to resolve). I started following the method used in this guide - https://nam3forum.com/forums/forum/m...anos-hub-bolts
                In short
                1.) Lock the Intake and Exhaust cams using the timing bridge
                2.) Install the Intake hub hand-tight so you still have the full range of motion.
                3.) Rotate the intake hub all the way clockwise.
                4.) Take the Intake spline gear and insert it into the Intake hub - You want to find the spot where the intake hub has to move the least for the spline to go in.
                5.) Check the range of motion by moving the spline gear in and out.
                6.) Place the Spline gear so the teeth are just visible.
                7.) Now torque the Intake hub down using a star pattern.
                Step 7 is the part I like about doing it this way. It allows me to torque the bolts down using a standard torque wrench, and since I have the cams locked down with the timing bridge, I do not have to worry about the timing moving while installing the Vanos.
                Install the Vanos by sliding the Vanos onto the head using the longer Vanos bolts, line up the pistons with the spline gears, and tighten the spline gear and Vanos pistons using a 7mm and 10mm wrench. Finally, I make sure the Vanos pistons are fully inserted in the Vanos before torquing the Vanos unit down.
                Before starting my car, I hook up DIS and go to expert mode where I clear both Vanos adaptations and standard adaptations (No idea if both really need to be cleared, but this is how I do it). I then start the car and take it for a drive, getting everything up to temperature. Once the car is nice and warm and still it feels ok, I run the Vanos test in DIS.
                My results from this morning. My Vanos is a little lazy on the reaction time, but the car feels good.
                2004 M3 Silbergrau (Silver Grey) ◙ Convertible ◙ SMG ◙ Karbonius CSL Airbox ◙ Mullet Tune ◙ Front 996 Brembos ◙ Status Gruppe V2 Headers ◙ CPI RTX Sec 1 ◙ Kenwood DMX958XR
                  Just for reference the later Torx bolts are made of the same material as the original bolts.
                  The E36 M3 bolts are made of stainless steel with a higher tensile rating.
                    All of this is to say the timing on these engines does not In short
                    7.) Now torque the Intake hub down using a star pattern.​​
                    This is not good.
                    Step 7: the hub bolts should not be torqued down to final spec when the vanos module is not bolted down to the head. This will give wrong timing.
                      Thank you for helping sapote, OK, i will measure 5mm back and strike a line on both shafts and insert them up to the 5mm line,
                        This is not good.
                        Really?
                        Please explain how this could result in the timing being wrong. Both cams are locked down using the timing bridge basically from the moment the VC is off.
                        Also if my timing is wrong would that not result in the Vanos test failing?
                        Cheers
                          Really?
                          Cheers
                          Locking the cams using the bride pin is to set the cams timing to the crank, but this has nothing to do with setting the vanos pistons in correct relation to the cams.
                          To set the vanos pistons in correct relation with the cams, is to have the pistons bottomed on the caps while there is zero backlash from piston to the cam.
                          In the steps you wrote below, the vanos bolts are torqued to spec with the shaft inserted so the splines are just visible. This description of the shaft and hub relation is vague and not precise. Just visible could mean the shaft is off relative to the hub and a few thousands, or more. Let's assume that the shaft is 0.020" too deep into the hub as compared to the ideal position, then this means with the vanos installed the piston is 0.020" too advanced with the cam at TDC.
                          The correct way to set the spline shafts into the hub at the correct position is to have the installed vanos pushing the shaft into the pretensioned hub, not just by eye ball the shaft to have "splines just visible".
                            Thanks for the detailed response.
                            I must admit it took me some time to go over your reply to understand fully how the seemingly slight procedural difference of installing the spline gears and torquing the hub bolts down before attaching the Vanos/ Vanos pistons impacts the final timing.
                            It was only after reviewing what you wrote in post 90 of this thread that it fully clicked how my eyeballing it (I also run a V2 Turbo Toy exhaust hub, which makes it harder to eyeball) resulted in my adapted Vanos values below:
                            My understanding is:
                            • Vanos piston extended retards timing
                            • Vanos piston retracted advances timing
                            My car calls for -5.9 °cr Intake adaptation and -4.3 °cr Exhaust adaptation, which, if I understand correctly, means that when I installed the Vanos onto the head, the Vanos pistons were not fully retracted into the Vanos. To get the expected range of travel, the DME has to pull the pistons back -5.9°cr and -4.3°cr, respectively.
                            I like the method you fully described in post 90 of this thread.
                            1. The hole on the hubs don't have to be aligned to anything nor to the vertical top posiiton, and these holes can be anywhere as they have nothing to do with vanos timing.
                            2. No need to mark on hub and splined shape for indexing, or the need to find the sweet tooth.
                            3. I don't like the method of bolting the splined shafts to the vanos pistons before inserting the shafts into the hubs, as it's more difficult to pre-tension the hub bolts and inserting the shaft into the hubs. The easier way is to insert the shafts into the hubs first, pre-tension the bolts, then bolt the pistons to the shafts later.
                            4. The timing: turn both hubs full CW, then insert the splined shafts into the hubs and if needed, turn the hub not more than 1 tooth to align the splines to get the shaft inserted in about 5mm.
                            Edited: pretension the two hub bolts for each hub.
                            5. Mount the vanos with gasket (with the solenoid plate removed) on the head with about 10mm gap in between or more, bolting the shafts and pistons together, then evenly tightening the vanos bolts to pull it into the head fully. This set the final timing. Now try to tighten all the hub bolts down. To torque these hub bolts to spec using standard wrench, then disconnect the pistons off the shafts, remove the vanos, and torque the hub bolts to spec. Install the vanos and finish all the bolts. Rotate the crank 4 turns or so and verify the cams timing.​​
                            One final question that is open to all. Do my adapted Vanos values have any real-world impact on the performance of my car? In other words, if I have no reason to open it all up again, should I bother now or wait until I have another reason to crack it open?
                            Cheers
                              This depends on the context:
                              * in operation, extended piston (rearward) to advance the cam;
                              * during timing setup, extended pistons leading to retarded cams and DME has to adapt more advanced data to get it right.
                              My car calls for -5.9 °cr Intake adaptation and -4.3 °cr Exhaust adaptation, which, if I understand correctly, means that when I installed the Vanos onto the head, the Vanos pistons were not fully retracted into the Vanos. To get the expected range of travel, the DME has to pull the pistons back -5.9°cr and -4.3°cr, respectively.​
                              For me, adaptation -5.9 means adding 5.9* advance, which also means your timing result is too retarded due to the piston is not bottomed on the cap with the cam aligned to bridge pin.
                              Do my adapted Vanos values have any real-world impact on the performance of my car? In other words, if I have no reason to open it all up again, should I bother now or wait until I have another reason to crack it open?​
                              The book says the IN cam timing variation range is 70* to 130* for max advance to max retard. I also don't think the cam when aligned to the bridge pin is 130* but something like 140* with 10* margin, and if I'm right then the IN piston bottomed on the cap when the cam is 140* retard, and so during operation between 130 to 70 the piston never near hitting the cap. I also think the piston rearward limit is less than 70* but not too far advance to cause valve/piston interference. So even with -5.9 adaptation the piston has full travel to cover 70 to 130, and the engine has no negative impact.
                              I'm interested to know how the DME uses the adaptation value such as -5.9 in this case, as it has no idea where is the vanos piston to add the 5.9 offset to its travel position.
                                That is a good point.
                                Thanks again for the enlightenment.
                                All of these discussions will help others in the future. For now, I will leave my Vanos and open it up after tackling my rod bearings in April.
