S54 Vanos post Beisan/DV Rebuild Timing Issue
  • Arinb12
    Google it if you already have INPA installed.
    I did, it shows nothing and I see no vanos options in my INPA unfortunately.
    I will keep trying.
    ​​​​​​do you think it could be down to an error (that somehow has manifested now) with my camshaft position sensors? Or throttle position sensors?
    Maybe the exhaust one to be specific?
  • sapote
  • Arinb12
    Can you test the vanos using INPA as I think it's easy to understand the result as shown below? Yours test tool is hard to understand, i.e. why for Intake, it reported 60 deg movement (or it could mean moved to max retarded at 130 after TDC) while for EX it reported zero (or it could mean moved to -128 max advanced before TDC).
    Where do I go to run test for vanos in INPA?
    Thanks!
  • sapote
    Originally posted by Arinb12 View Post
    sapote
    One thing I did notice was that the exhaust piston was easy to slide in and out, could slide down jsut by turning the vanos on its end. While the intake piston was a little more resistant (better seal?)
    Maybe the exhaust side did not seal well with my replacement piston from another vanos because the inside seal was already worn to the original piston size? Perhaps this is causing my issue with the advance/retard part of exhaust test?
    Could this be a possibility?
    It can't be the actual timing if my pin slides in and bridge is flat when at TDC right? (It's easy butter slide for exhaust, and little resistant to slide but still slides easily enough for intake)
    I couldn't have done anything wrong when using a solid tensioner? Maybe too much or too little tension did something?
  • Arinb12
    sapote
  • sapote
    Are you saying my mechanical timing is 10° off? Because it's stating 60° while 70 is the minimum range starting point?
    The test did not use the absolute true timing angle, which is [70 to 130] for IN, but it used a relative range from 0 to 60. So 0 is 70 position and 60 is 130 position.
    I think your vanos timing is perfect, as the test didn't say anything wrong.
  • Arinb12
    Btw, Neither 60 deg and 0 deg are the correct absolute working cam angles. Their working range are: IN [70: 130] after TDC and EX [-83 : -128] before TDC.
  • Arinb12
    From that one sample of command to move EX to max advanced position (zero deg is max advanced and 45 deg is max retarded), 5 deg adaptation makes no sense, and so I think the test had performed moving at a few positions and then averaged out the error to a value of 5. You only posted one sample data and so we haven't seen the other values, I think.
    That screenshot (diagnosis) is the vanos adaptation values from a different place in DIS. The test I did stopped after showing me the following intake values, it did not get as far as the exhaust values.
    I am not sure if it is saying it failed on the inlet or the exhaust being out of range (photo below)
  • Arinb12
    DIS did not show me anything more than that
  • sapote
    What do you mean regarding the EX? It's not commanding it to move?
  • sapote
    I think the tool commanded to move the vanos end to end, and the posted pic is only one sample out of a few target positions. And from averaging many samples, the DME chose to use that adaptation data.
    The values in the pic of 60 and 0 are relative angles, with 60 as the max retarded and zero is the max advance for Intake (130 -70 = 60) . For exhaust, they should be 45 and zero (-128 – (-83) = 45)
    Take a video and maybe we can interpret it better.
  • Arinb12
    The tool display doesn't make sense to me either.
    Consider the DME commanded Intake to 60* and the actual was 59.8* with error only 0.2*, so why it needed to adapt a whole -1 deg?
    For EX, command is 0 and actual is 0.5, and the adaptation is 5 deg.
  • sapote
    Exhaust 5.0 adaptation?!
    Inlet shows -1.0 (makes sense as pin didn't slide in easy but bridge did lay flat)
  • Arinb12
    The solid tensioner is to take out any slack on the pulling side of the chain (RH side vu from front).
    I would do these steps:
    Loosen vanos solenoid block to release oil pressure.
    With stock tensioner, turn crank to 3mm before TDC compression (stop crank at 3mm on the left of TDC ref mark).
    install solid tensioner just snug. Don't tighten too tight as it pushes hard on the guide and can break it. Slowly turn crank CW to TDC (3mm more than before). Snug up tensioner if it's loosen after turning crank CW. Set cams to retarded and verify with the bridge pin.
    At this point the chain should have no slack. Proceed to pretension the hubs and finish the remained steps.
    After the hubs bolts are torqued to spec, install the stock tension, then rotate the crank 4 turns and check timing with bridge pin.
    Okay so someone help me understand what the hell is going on!
    Situation.
    New/2nd hand vanos. (Used exhaust piston from my old vanos as this ones piston was missing a seal)
    Vanos pressure tests confirm hot engine pressure of 115 bar.
    Leakdown fast, accumulator still bad.
    Engine timed as per using the solid tensioner and standard preload method.
    Engine turned over 10 times post vanos install. Checked at TDC.
    Exhaust, bridge flat, pin slides in like butter.
    Inlet, bridge flat, pin needs some pressure to slide in.
    Ecuworx tool shows (photo):
    Click image for larger version  Name:	IMG_20220126_190914.jpg Views:	0 Size:	59.2 KB ID:	150289
    DIS shows (photo) the same adaptations.
    Vanos test FAILS?! - WHAT THE HELL IS GOING ON?! (photo)
    Click image for larger version  Name:	Screenshot_20220126_193929_com.microsoft.translator_edit_399006259338073.jpg Views:	0 Size:	68.2 KB ID:	150291
    ​​​​image widget
  • sapote
    Here is after the first rebuild
    And next the ISTA+ testing values
    Questions and comments:
    Why the test only commanded the vanos to move Intake to 130 deg (max retarded which is an easy motion) and not to 70 deg (max advanced which is a more difficult motion)? And, for the Ex cam, why commanded to to to max advanced (128 deg) instead of max retarded (83 deg)?
    ISTA test value:
    For exhaust cam: The actual steering advanced is 128, which is perfect. But the actual steering retarded is 79, which is not too good when the command value is 83 I assume. So 4 deg off here.
    For intake cam: 70 deg advanced and 130 retarded and so they are perfect with zero error.
