Originally posted by Arinb12
Let's says you set your cams up so the bridge sits perfectly flat on the head with the crank locked at TDC1, you torque your hub bolts to spec but after you turn the engine over 4 times and lock at TDC1 again now you find you have a gap between the bridge and head on the intake side of head when checking the intake cam.
In the case of this hypothetical scenario you would re-time but instead of setting up the intake cam so the bridge sits flat you need to slightly advance the intake cam, this means rotating slightly Clockwise as viewed from front of the vehicle.
If both of your cams are off by about the same it would be easier to bias the crank, you either bias the crank ~1-2mm CW or CCW depending on if your cams end up slightly advanced or retarded when you check timing with the bridge.
