Driveshaft recommendations?
    I will most likely be just getting a stock one but IF I can get a one piece that works, I'll probably do that. Pulled the driveshaft to drop the subframe and it's loosing its grease. I'm not in the mood to rebuild it myself. CV is no issue but the U joint is more trouble than it's worth.
    What are some aftermarket suggestions I can buy now? This project can't sit around for a month.
    Where have you gotten your rebuilt one and what was the ETA on it?
    If it’s a standard driveshaft, I can usually get a rebuilt one to you in about 3-5 days. Then just send your core back.
      Wouldn't hesitate to go with bigjae46 but if for whatever reason you don't then this is who I used in March of 2019.
