  • duracellttu
    You should have the fronts on full soft and rears somewhere in the middle of their range, probably. Full soft up front for sure.
    maybe more in the rear— 700 is the stiffest spring tck says your can use with their shocks, so it might need to be on the stiffer side to control it.
    Just took the car out for another drive after setting the rear shocks to 1/4 turn from full firm. While its much better, its still bouncy. Just doesnt feel planted when going over bumps.
    Does this mean I've reached to limitation of my shock? Exchanged a few emails with TC and he said that the SA shock doesnt have enough compression damping control to "be really good", but the DA does
    Any recommendations for replacement rear shocks to support 700# springs? Should I just get TCK DA rears and keep the SA fronts? TIA for the help.
  • Obioban
    Just purely out of curiosity, why full soft up front? Because of the low spring rate?
    Yes. A softer spring rate needs less damping to control it.
    And too much is a bad situation— the car jacks down (over repeated bumps the spring gets more compressed as the shock is too stiff to let it expand in time to hit the next bump), so you end up driving on the bump stops.
  • r4dr
  • Obioban
  • duracellttu
    That looks pretty bang on perfect to me. I'd say start your front sway off on medium, and tweak it to taste from there. Medium should put you at 74%, which is a pretty optimal starting point for "medium". I wouldn't worry at all about a 0.4% FRC variance left/right-- unavoidable.
    Click image for larger version Name:	Screen Shot 2020-06-03 at 8.32.27 AM.png Views:	0 Size:	48.8 KB ID:	30897
    Click image for larger version Name:	Screen Shot 2020-06-03 at 8.29.43 AM.png Views:	0 Size:	121.6 KB ID:	30899
    Just finished this project which included CSL king pins, new springs, TMS monoball RTABs, new wheel bearings all around, and 996 Brembos.
    During the first drive, the car felt REALLY bouncy. Seemed to be coming strictly from the rear. I have TCK SA shocks and they are set to 3 clicks from full soft front and rear. Spring rates are 350# FL, 336# FR, 700# RL, 657# RR.
    Do I need to adjust the shocks to be more firm? Not sure why it's so bouncy. Any advice is appreciated!
  • Redline
    Any suggestions for fixing the issue with bilstein HD and eibach bottoming out on anything larger than a 1” bump? Gotten worse over time and feels like I have 2x4”s for front struts, simple bumps have me bracing for impact at speed lol...
  • ChapterM3
    Bump for a terrific thread! Currently weighing my options for Koni sports and Dinan springs - if anyone has had experience with this setup I'd appreciate your input! How is the ride for day to day driveability? Anything else I should know before pulling the trigger? Feel free to PM me to not take up space in this thread. Thank you Obioban for the great post!
  • Obioban
    Originally posted by Drewrivera View Post
    Geez I just bought a set of bc and now I'm thinking about going to stock with a set of springs after this read. I have koni with h and r spring but my ride kills my car. +1 on the info
    It's more difficult to correctly set the car up with springs/shocks than it is with coilovers. The only springs that I know function properly are Eibachs and Dinans (vogtlands may as well-- I don't know anything about them). Nothing you can do is going to make the H&Rs work well.
  • Tbonem3
    H&R springs kinda suck. The rears are fine, but the fronts are awful. Pair some eibachs or dinans or vogtlands with koni or bilsteins.
  • Drewrivera
  • Tones
    It’s the front “knuckle” that connections your strut to the front wishbone and tie rod. Your caliper mounts to it and the wheel bearing presses into it.
    Ah okay. I don't think i've ever heard kingpin before but have heard knuckle.
  • duracellttu
    Originally posted by Tones View Post
    Okay what is a kingpin.
  • Tones
  • Obioban
    Looks like my idea worked! Did you have to get longer bolts to accommodate the additional spacers? If so, what size bolts and washers did you end up using?
    The stock bolts were long enough that I did not need to swap them out for my set up.
  • duracellttu
    Then I noticed the the bracket that mounts the sway could just be spacered off the control arm with some washers. You can go either direction, just by spacering one side, vs the other. So long as your ride heights are reasonably the same left/right, this should be plenty to dial out the preload.
