They're just yellow konis.
The Dinan dampers you want, if you even can find a set, and they're not too used up, are the JRZs that look like stock.
Anyone try the Koni set up by Dinan? Just seen them as i was putting the regular koni with stock springs on my cart. They say it lowers with same geometry and same feel has out the factory with the Dinan springs.. but not sure. I personally deal with all weather conditions so it's probably best not to drop at all for me.
Great video thanks for sharing!Originally posted by heinzboehmer View PostSuperfastmatt just published another thread relevant video that I thought was pretty interesting: https://youtu.be/Af6eYn3HOjw
I know nothing about that, either.Originally posted by repoman89 View Post
I chose to use these with my CSL front sway, but don’t really get how it would stop the bolts from ripping the chassis apart. If anything I’d think aluminum brackets would want to break before steel ones, and be more likely to save the chassis (steel rear sway bar brackets are a popular upgrade on the E39 M5 which tends to break OE alu ones frequently)
I am EE, not materials/structural engineer though.
I'm not an engineer of any sort - my thought is if the bracket begins to deform, that could exert stresses on the mount in directions it is not designed to handle?Originally posted by repoman89 View Post
I chose to use these with my CSL front sway, but don’t really get how it would stop the bolts from ripping the chassis apart. If anything I’d think aluminum brackets would want to break before steel ones, and be more likely to save the chassis (steel rear sway bar brackets are a popular upgrade on the E39 M5 which tends to break OE alu ones frequently)Originally posted by terra View Post
For what it's worth, the CSL does use steel brackets instead of aluminum for the front sway. Perhaps a mitigation for that failure mode?
31356754336
I haven't heard of anyone doing this, but can the front sway bar reinforcement plates be glued on with structural adhesive?
For what it's worth, the CSL does use steel brackets instead of aluminum for the front sway. Perhaps a mitigation for that failure mode?Originally posted by Feffman View PostIf you go bigger sway bars, may I suggest you reinforce the sway bar mounting area with Bimmerworld's reinforcement kit (https://www.bimmerworld.com/BimmerWo...i-330i-M3.html). Just a thought after last weekend.
Feff
31356754336
Yikes!Originally posted by Feffman View PostIf you go bigger sway bars, may I suggest you reinforce the sway bar mounting area with Bimmerworld's reinforcement kit (https://www.bimmerworld.com/BimmerWo...i-330i-M3.html). Just a thought after last weekend.
Feff
Feff
For me the hardest part as I learn more is letting go of things I thought were true. And then realizing I was wrong yet again just weeks/months later! Also, understanding there is no "right" answer, and instead multiple solutions. And what works for one person might not work for another.Originally posted by Obioban View PostI increasingly feel like the more I know about suspension, the less I know about suspension.
... and that deviating from stock as little as possible (but as much as necessary) is the best strategy-- especially in ride height and geometry.
Regarding the lowering discussion, there is just hardly any room to lower the E46 if you want to maintain civility and performance. I highly recommend not lowering it more than a teeny tiny bit unless you run shorter shocks to maintain some travel before hitting the bump stops. And then you have to be careful about the tire hitting the fenders or fender liners. Not to mention all the geometry stuff that gets messed up when you start lowering.
Then again some people just want it to look cool and don't care how it rides. To each their own!
