Originally posted by duracellttu
What do you mean by "oscillating rear"? It doesn't make sense that you would have more movement with stiffer springs.
Flat ride theory makes sense to me. While a suspension designer may be able to use brute force damping to mask a naturally unsettled car, it seems more efficient for the car to be naturally settled without added damping, then apply a small amount of damping to fine tune things as necessary. The inertia of a car bouncing around back and forth is not conducive to grip or comfort, and using damping to cover this seems like a band-aid.
I can say this... In the ownership of my M3, as I've gone from 550/600 lb/in F/R spring rates, to 300/600 and now 155/375-750 (Eibach), the car has become far more pleasant to drive.
I'm intrigued by the quest for desirable handling characteristics while still maintaining comfort. In my mind, a "perfect" suspension would allow the car body to "float" (have essentially no vertical movement) as it goes down the road, and at the same time the tires are maintaining a steady or constant force on the pavement as they roll down the road. I suppose this would be a numb driving experience, so it would also have to have perfect road feel.
Like lots of other things in life, the more I've learned about suspension design and theory, the more I realize I don't know (I don't know much). I've also come to realize that most people have absolutely no clue what they are talking about when it comes to suspension systems. Automobile suspensions are far more complex than they appear on the surface. Most of us don't have the opportunity to try a significant number of different spring/damper setups over the ownership of our car, let alone test multiple setups back to back in a somewhat controlled environment. And even if we did have that kind of opportunity, most of us would not be able to tell what is actually going on with the suspension from the driver's seat, or accurately determine what was changed in a blind test.
Good discussion!
I think most people miss this point. As long as you’re not in the bump stops, you want softer if you want grippier. You might prefer the slower cornering car that transitions faster, but that’s the trade your making, to make it clear!
