Originally posted by fattycharged
I mean itās your car, not mine, so what you do to it doesnāt affect me in any way. My point was that youāre probably better off doing things right the first time instead of fucking with things, which is the route Iām going with (i.e. getting a ready to install high quality coilover kit, catted sec 1 instead of welding cats into a catless sec 1, etc).
my consumer V3's just went in for a rebuild last week and I just got the call today that they don't want to rebuild them as they're slammed with race builds for the start of season, instead they're sending a new dampers from Germany.Originally posted by r4dr View Post
The KW Motorsports and KW consumer (V1, V2) products seem to be different. KW Motorsports stuff in Europe is the real deal, and a lot of people from Manthey to BMW customer racing run their dampers. Emotion Engineering is the only one I'm aware of in the US that works with KW Motorsports products.
I never felt the V3's were stiff, always thought they were extremely compliant even on Houston streets.
To SQ13's chagrin, I may just run them with some linear springs and see how they do š
This is true, all this started with FCM and they only work on monotube non adjustable Bilsteins.Originally posted by Nate047 View Post
Thing is there's no real harm in just tinkering. You can always set them back to full soft and start again if you end up hating life. Shops will each have their own preferred brands, and won't always be objective about why ($$$) so just keep that in mind. The basics of damper tuning are the same on any brand.
Thing is there's no real harm in just tinkering. You can always set them back to full soft and start again if you end up hating life. Shops will each have their own preferred brands, and won't always be objective about why ($$$) so just keep that in mind. The basics of damper tuning are the same on any brand.Originally posted by r4dr View Post
Thatās good to know because I had no idea. Then the next step is finding shops that support it⦠because I definitely donāt know the ins and outs of fiddling with knobs.
Thatās good to know because I had no idea. Then the next step is finding shops that support it⦠because I definitely donāt know the ins and outs of fiddling with knobs.Originally posted by cornerbalanced View Post
In the states you can order KW Motorsports through KW themselves. You simply have to fill out an order form, denoting monotube/twintube, inverse strut, spring rates, external reservoirs, reservoir line sizingā¦virtually every aspect of the damper is customizable. Hope to see more people take advantage of this program! Pricing is on par with JRZ/MCS.
In the states you can order KW Motorsports through KW themselves. You simply have to fill out an order form, denoting monotube/twintube, inverse strut, spring rates, external reservoirs, reservoir line sizingā¦virtually every aspect of the damper is customizable. Hope to see more people take advantage of this program! Pricing is on par with JRZ/MCS.Originally posted by r4dr View Post
mrgizmo04 lvm3sm46 What front spring rates and lengths did yāall end up with for the R&T kit, and what ride height was achieved?
Iām ordering a TrackDay kit from 3DM, and Barry recommended 7ā 336 lb/in Swift springs when I mentioned that I want the front rate to be around 350 with stock 630 rear. However, it looks like I wonāt be able to get the car high enough (13.5ā) if I go with that spring? FWIW, Iāll be trying the kit with Ohlins/Vorshlag camber plates.
If the car is too low, I could add a helper spring to get me to my desired ride height, and Barry suggested this as well. Hyperco sells 2.5ā helpers with a solid height of 0.44ā and 0.70ā, and Ohlins (Swift?) sells a 65mm helper with a solid height of 0.63ā. Plus the thickness of the adapter/spring guide. Even if the lower spring perch isnāt near the top, I donāt think Iāll have clearance issues with 18x9.5 ET35 ARC-8s, since I run a 10mm spacer to clear the 996 calipers?
STs are KW1s iirc.Originally posted by WestBankM4 View Post
It was the M4 GTS fitted with KWCS 3-way from the factory.
Has there been a lot of hate with KW products? I wanted KW's for the E46 but I was told the ST's are KW's, just doesn't have the anti-corrosive coating on the shock body. I naturally went with ST's, otherwise it was going to be KW2's. Can someone confirm that ST XTA's are basically KW2's?
The KW Motorsports and KW consumer (V1, V2) products seem to be different. KW Motorsports stuff in Europe is the real deal, and a lot of people from Manthey to BMW customer racing run their dampers. Emotion Engineering is the only one I'm aware of in the US that works with KW Motorsports products.Originally posted by STAATS View Post
I agree it's probably a little unrealistic to think they have tested every suspension package option they sell on every car but given their on/off close relationship with BMW Motorsport (BMW Motorsport | KW suspensions) I would be surprised if they didn't put in testing effort into their BMW M kits... This is why I have never understood the hate for KW in the US... they are super common in Europe and BMW clearly backs them, I can't remember what GTS/CS model it is but it is the factory suspension for one of their M3/4 fitouts.
BMW likely does the testing and tells KW what they want. Europe is one thing where the roads are generally smoother. The bumpy roads in the US require a more compliant suspension.Originally posted by STAATS View Post
It was the M4 GTS fitted with KWCS 3-way from the factory.Originally posted by STAATS View Post
I agree it's probably a little unrealistic to think they have tested every suspension package option they sell on every car but given their on/off close relationship with BMW Motorsport (BMW Motorsport | KW suspensions) I would be surprised if they didn't put in testing effort into their BMW M kits... This is why I have never understood the hate for KW in the US... they are super common in Europe and BMW clearly backs them, I can't remember what GTS/CS model it is but it is the factory suspension for one of their M3/4 fitouts.Originally posted by bigjae46 View Post
They don't typically tune to specific cars. JRZ provides a damper that physically fits and provides a damper set up to some sort of calculation. It takes a Bimmerworld, Vorshlag, Turner, etc to fit the damper and try out spring rates and damper settings.
KW says they test on each car they sell a suspension for. Not sure I believe it, KWs are so stiff they ride like crap.
Thanks for the replies regarding my question about AST. I remember I was number one or two with their 5100's, so early in fact that they were indeed having "teething issues", specifically portions of my kit that were incorrect after delivery by Vorschlag. They had a specialist from Holland flown in to assess the situation, I thought that was extremely odd at the time.
They don't typically tune to specific cars. JRZ provides a damper that physically fits and provides a damper set up to some sort of calculation. It takes a Bimmerworld, Vorshlag, Turner, etc to fit the damper and try out spring rates and damper settings.Originally posted by cobra View PostI would hope these companies like jrz/moton/ast are putting effort into tuning each vehicle individually but maybe they aren't.
