E46 M3 Rod Bearing Job Parts List
    Hi all.
    About to tackle this job here soon my car and wanted to see if there is an exhaustive list of parts, with part numbers that someone has compiled for this job, both including the necessary replacements as well as some additional "while you're in there" things.
    For my particular car it's an 02, pre LCI, that had rod bearings done under recall at 16k miles in 2005. So, I'm unsure if I need updated bolts or reusing my current ones. Also, ARP or not in this case?
    I remember we had a thread on the old forum so figured it'll be helpful to get one going here.
    Current:
    Parts list for my 06/2003. Hopefully helpful to someone if not the OP.
    Part Part number Qty
    oil pan gasket 11 13 1 437 237 1
    oil pan cover gasket 11 13 7 834 886 1
    dipstick tube washer 11 43 7 838 127 1
    dipstick tube o-ring 11 43 1 707 164 1
    rod bolts 11 24 7 834 310 16
    oil pump tube o-ring 11 41 1 401 769 1
    motor mounts 11 81 2 283 798 2
    motor mount nuts 22 11 6 779 973 4
    lower reinforcing plate bolts 31 10 6 772 199 12
    left lower control arm 31 12 2 229 453 1
    right lower control arm 31 12 2 229 454 1
    control arm inboard nuts 31 10 6 774 714 2
    control arm outboard nuts 31 10 6 777 806 2
    FCAB bolts 33 30 6 760 652 4
    steering shaft coupler 32 30 1 094 703 1
    steering shaft coupler bolts 32 30 6 778 609 3
    oil return line 11 15 7 832 781 1
    valve cover gasket 11 12 7 832 034 1
    sparkplug tube seals 11 12 7 831 271 6
    valve cover grommets 11 12 7 830 972 13
    valve cover grommets 11 12 1 437 395 2
    engine air filter 13 72 1 730 946 1
    cabin filter 64 31 9 257 504 1
    fuel filter 13 32 7 831 089 1
    fuel filter o-ring 07 11 9 963 129 1
    power steering resevoir 32 41 1 097 164 1
    power steering hose 32 41 2 229 369 1
    clamp 32 41 6 751 127 2
    power steering hose 32 41 2282 353 1
    clamp 32 41 6 751 128 1
    power steering pipe 32 41 2 282 354 1
    power steering banjo bolt 32 41 6 854 470 1
    washer 32 41 1 093 597 2
    power steering hose 32 41 2 283 893 1
    power steering banjo bolt 32 41 6 852 470 1
    power steering banjo bolt 32 41 6 781 261 1
    washer 32 41 1 093596 1
    Drei Bond 07 58 9 062 376 1
    Yes, there some extra rod bolts. Yes, I am doing a lot of "while I am there" along with the usual 90K service stuff.
    Jesse
    Old, not obsolete.
      Jesse
      Thanks man. I am thinking I need to order both the M10 and M11 bolts as I'm not sure which ones I have.
      What is the general consensus on ARP bolts in this scenario? Are they OK to use in either case?
      Current:
        ARP bolts are going in my car in the next couple weeks.
        by chance BMWahba was it your e36 in the OG video from about a week ago?
          Nice. I just have to find out which bolts I got. May wait to order until I crack it open.
          Yeah man that was the car! It was fun.
          Current:
            all the parts needed is listed in this document.
            attached.
              I think the consensus around here has been to use OEM bolts over ARP
              2018 BMW ///M3
