PS res./hose leak.
  • mrgizmo04
    For the tool, spray the connector with some wd40, pull the hose up a bit, then I've had success using an open end wrench/pliers to push on the white plastic tab. Similar to the rear-facing fuel filter connector.
  • uberchris
    On a side note, what type of tool is required for the power steering hose disconnect? I have fuel/AC type disconnect tools but this appears a bit different.
    I'm assuming you're talking about where the lines connect to the cooler (otherwise it's just regular ole banjo bolts and hose clamps)? You don't need a special tool, just push down on the plastic rim evenly and wiggle the hose off the connector. If the hose is original, it will probably be a little stuck.
  • Cubieman
  • Cubieman
    I will do this, just not looking forward to removing that CSL box, but I can't stand fluid leaks.
  • TexaZ3
    ZF is OEM. I would change reservoir, and both feed and pressure hoses.
  • Cubieman
    I was under there last night and it would seem the only way to have any kind of real access to work on this area would be to remove the entire air intake, great. I'll pick up a ZF, a chase bay would be nice but I've been spending too much recently.
  • JamesSJ1
    Originally posted by Andrew 06M3Cab View Post
    I believe ZF was/is the OE manufacturer for BMW. I am just in the process of refreshing the whole system (while doing rod bearings), and went with that one. And Rein is OE for the pressure line.
    ^^^ This. Just bought a ZF reservoir from FCP, and the BMW logo is literally scratched off of the exact same spot as the BMW logo of the original one in my 2006.
  • 01SG
    I got the ZF, don't see how you could go wrong with them. I too believe it's the OEM, although on this part I don't see how it would make much of a difference anyway.
  • Andrew 06M3Cab
  • T.J.
    Fwiw, the new bmw lines have a revised design from what the cars came with from the factory
  • Cubieman
    Just fyi, depending on what kind of clamps you use (or whoever previously used in your car) to attach the hoses to the reservoir, those clamps can loosen over time and make it look like the hose cracked and is leaking. All it takes it to just tighten up the clamps. (Ymmv, not saying it will solve everyone's problem, but something to check).
    Also, the lid/cover for the reservoir has a hole in it that comes out to the side via one of the ribs (you can see it in the ECS screenshot below, the one facing directly at the camera has a hole). It's there for overflow of fluid. That will send fluid all over the reservoir side (whichever way that hole is facing when the lid is tightened down) and will run down the hoses that attach to the reservoir, making it look like a leak.
    I checked the vent hole and unfortunately it does not appear to be the issue. I inspected the connection area and it appeared that the hose was slightly cracking around the connection area.
    I wanted to tighten it up but my CV type pliers only work straight on and not at 90°. I'll have to get some different pliers as its real tight space in there.
  • mrgizmo04
  • Cubieman
    A genuine BMW reservoir is $63 vs. Rein $14, Uro $12, ZF $22, February $27, Dorman $41.
    If I could save $50 I would sure like that, but I know with some parts it is best to use genuine for various reasons and others might not make any difference.
  • Kcalhoun27
    There was a forum member making high press hoses, with varying success stories. Im having mine swapped with oe equivalent from my local indy, i guess getting another 15 years out if them is going to have to be good enough
  • Cubieman
    I may just replace the res. and two lines running to res. for now.
    Is a non-genuine res. acceptable?
