I have seen numerous posts that suggest if you want to bleed the ABS/DSC then you can simply drive on some wet gravel or ice, trigger ABS, then do a normal brake bleed.
So would it also follow that if you wanted a shop to do the brake bleed but they did not have DIS you could go through the DIS bleeding procedure before bringing it in and just not open the bleeder screws? Wouldn't that have the same effect?
