Request for Brake Pressure Scan Data
    If anyone out there with a scantool with the MK60 DSC that isnt throwing codes can log some data for me I would appreciate it. Trying to debug brake pressure issues. If possible could someone do the following:
    1. Turn key but don't start car to turn on the DME/DSC etc.
    2. Press brake pedal until there is no more vacuum in the booster, pedal should become quite hard
    3. Log the front and rear brake pressures from the DSC module without your foot on the pedal at all.
    4. Log the front and rear brake pressures from the DSC module with a moderate amount of force on the pedal (dont stand on it but dont be a wimp either ).
    I have about 1-2 bar difference between front and rear brake pressure circuits and trying to figure out if the sensor data is good or not. I'll post my data once I get home as reference.
    thanks in advance.
    For number 3: 1.7 and 1.9 bar
    For number 4: 7.8 and 8.0 bar
      Thank you! Your numbers are much closer than mine. And one of the circuits is negative with no pressure. I think it’s time to change those sensors.
