Hello, recently just installed an intercooler active supercharger kit on my e46 m3. Car is smg and has headers, id1050s, walbro 450 and I’m having issues when full throttle. Currently waiting on my wideband and boost gauge so don’t have info on that. When I give the car full throttle the car bogs and makes no power and the rpm won’t even go up. If I give slight throttle the car will rev out to redline and make boost. When data logging my throttle shows 136% when floored when obviously it should only be 100%. I checked and have found no vacuum or boost leaks. Changed my tps sensor located on top of the engine. Still having this issue and I’m guessing it’s correlated to my bogging issue. But now I’m stuck and wondering where to look next. Any help would be appreciated thank you.
Supercharger kit installed bogging when full throttle
Are you getting any codes when it bogs down? Normally if you had an issue with the throttle actuator, it would give you a code. Why the id1050s? Who did your tune and is it an alpha n tune or are you using the MAF before the blower? Sounds like it does not know where it is at full throttle. Did it run fine before the charger install? (same DME I am going to assume)
Hassan at HTE performance is the tuner that resolved everything and I couldn’t be any happier with his tune. Not only his tune but he responds super fast and is always there to help or answer any questions.Originally posted by nextelbuddy View PostDid you want to mention who you switch to that solved your issues?
I don’t want to bash the tuner I had issues with, all I can say is use HTE and you will not be disappointed.
- Likes 3
Give HTE tuning a chance to tune ur car right and you will change your mind about removing the kit.Originally posted by Epoustouflant View PostThe SC VF420 tune I have feels awful. It’s strong mid range but feels flat from 5 to 8k. The SC is coming off anyways, but it appears tuning SC S54s requires *some* expertise hehe.
