Anyone use the upgraded VAC Motorsports High Volume Oil Pump?
Yes!Originally posted by Feffman View PostTiming is everything. I was just thinking about this as well.
Feff
Unfortunately I couldn't find too much online in regards to these oil cooling parts, and with losing the OG m3forum, I'm sure lots of info is gone for good, but there's still plenty of good people out here with some great experiences.
Sorry didn't mention I meant mainly for HPDE events. Water seems to be fine for now, just oil gets hot very quick. Can barely do a few laps the way it is right now.Originally posted by 0-60motorsports View PostOverheating? Water or oil? and what are the temps?
Sent from my motorola edge plus using Tapatalk
Have you cleaned the oil cooler front and back?Originally posted by psing23 View PostSorry didn't mention I meant mainly for HPDE events. Water seems to be fine for now, just oil gets hot very quick. Can barely do a few laps the way it is right now.
That will do nothing to solve your heating issues.Originally posted by psing23 View PostI have a built S54 with stock compression with an older AA HKS SC kit with 6 nozzles of meth spraying into the intake manifold but I live in South Florida and of course I have overheating issues.
Does anyone have any experience with the upgraded VAC oil pump? Any noticeable difference?
I'm running this pump, seems to be good for me, hitting max psi not far past 2200 rpm. But if you're struggling with oil heat then I think this pump will do nothing for you. IMO more pressure (not higher max, but towards max more of the time) = more heat. I'd look into a bigger and better oil cooler if you struggle with oil temps.
Regards
