I own ess supercharged m3 with 570 whp and would like to change clutch soon so any recommendations here ? Since I always used sach performance clutch so I don’t have experience with other clutch .
Single disk clutches with heavy duty pressure plates will have a lot more pedal pressure. South Bend’s ferramic clutch holds a lot of power but it tends to fuse to the flywheel or pressure plate if you drag race. Twin disks are nice because they hold more power but don’t have the increased pedal pressure. The lightweight twin disks are a lot less streetable than heavier ones though. I run a ceramic twin disk from competition clutch but I don’t think it’s available anymore.
I run a UUC feramic twin disc that’s treated me very well. UUC has a somewhat mediocre track record but I’ve really enjoyed the clutch and their customer service wasn’t bad (in my personal experience).
I have a lightly used tilton twin disc from Bimmerworld for sale in the FS forum. PM me if interested. I loved it and easier to modulate va the triple disc. I think it will support your power needs.
Honestly, you probably do not need any crazy if you know how to drive a manual and do not abuse your clutch. Someone I knew, daily drove his AA supercharged e46 m3 on a stock clutch with zero issues. He drove the car hard and never had any issues. You have to remember with a centrifugal supercharger which all e46 m3 superchargers are, there is not a lot of torque made low in the RPM range. Your not making crazy torque to begin with. It’s not like a turbo car. How often are you going to be shifting beyond 5-6k rpms? I got sucked into believing that the stock clutch wouldn’t hold 400whp and swapped a lightweight flyweight and upgraded clutch, which I hated. Ended up swapping stock flywheel back into with an HPF clutch which looking back I didn’t even need. Ended up flushing close to 5k down the toilet with worrying about upgrading the clutch because of the supercharger.
If you like the stock feeling clutch pedal, use the stock flywheel and either a stock clutch or a slightly upgraded clutch. No need to go crazy and dropping tons of cash on clutch.
I ran a new OEM clutch setup with mine on 10PSI / 575HP flywheel, and it ripped the friction disc clean off the rivets and separated after a track/race weekend resulting in a DNF. Switched to FX400 clutchmasters+flywheel and no issues. Good feel and pedal weight not too heavy.
