GB: Enkei NT03+M 18x10 +25 Silver
    GROUP BUY COMPLETED.
    Please see the details below:
    • ENKEI NT03+M
    • 18X10 +25 / 5X120 / 72.56
    • Color: Silver
    • MSRP: $1,476
    MAT Technology
    Enkei developed a new manufacturing process to produce the next aluminum wheel generation. The Most Advanced Technology (M.A.T) combines one-piece cast wheel technology with a rim forming technology called spinning process. Using this new technology of casting and rim forming by M.A.T process, is critical to improve drastically the material property and strength of the wheels. Rim-Rolled technology shapes the rim to improve material elongation without sacrificing the wheels hardness.
    SPEC-E
    All Enkei wheels are engineered to pass rigorous testing. In fact, Enkei established its own test standard called "Spec-E," which is tougher than JWL requirements. Enkei's Spec-E test setting requires a higher drop point in the impact test and 20% more cycles for the rotary bending fatigue and dynamic radial fatigue tests than JWL standards.The Spec-E represents Enkei's confidence in its technology and quality of Enkei wheels.​
    '12 E92 M3 ZCP/DCT
    EC-7 | Ohlins R&T | Motorsport Hardware | M Performance | Recaro
    I could be interested
      1. Original
      2. Fattycharged
      '12 E92 M3 ZCP/DCT
        Crazy, back in 2009-2011. these rims were $290 a pop off Tire Rack
        I had a set back in the day
          More deets, wheel weight? Is a 9.5" et35 an option?
            I love the NT03 +m's, they're a great set of wheels. I had a set on my 1995 E36 M3 which I used as a time attack car.
            I was looking at these for a good while but they only make them in a maximum size of 18" which I know is the go-to size on these boards because of weight and width options. Unfortunately I have my heart set on 19's but good luck with the group buy.
              Unfortunately, 18x10 +25 is the only option for BMWs. The wheel weight is 20.5lbs.
              '12 E92 M3 ZCP/DCT
                Bump…
                '12 E92 M3 ZCP/DCT
                  Bump…
                  '12 E92 M3 ZCP/DCT
                    Is this GB dead? I’d be very interested
                    2003 E46 M3 Titanium Silver / Black
                    www.instagram.com/nextlvel
                      Also interested!
