Vincebar Group Buy 2021
    Vince just posted a 4 part video playlist about both Vincebar versions and gusset cups (and Vinceskinz). He also goes over the RACP chassis structure and gives installation tips:
      Sign me up for an epoxy/rivet + tooling kit. Thank you! (Las Vegas, Nevada)
        1) Slideways (CA) - Epoxy/Rivet Vincebar
        2) jlmotorwerks (WA) - Epoxy/Rivet + Tooling Kit
        3) ej257 (NE) - Weld-in + Tooling Kit
        4) Bimmerrodg (montreal,Canada) epoxy/rivet + tool kit
        5) BoostedBoobs (Toronto, Canada) Weld-in kit
        6) EthanolTurbo (CA) - Vincebar
        7) bran.stum (CA) - Weld in kit, might need tool kit as well. I’ll verify
        8) K-Dawg (FL) - Epoxy/rivet kit + tooling kit
        9) simonnim (CA) - Epoxy/rivet + tooling kit
        10) hallerhan (PA) - Epoxy/Rivet + tooling kit
        11) SQ13 (TX) - Epoxy/Rivet + Tool Kit
        12) SQ13 (TX) - Epoxy/Rivet
        13) cmitch024 (TX) - Epoxy/rivet kit + tooling kit
        14) kenster (CA) - Epoxy/Rivet Kit + tooling kit
        15) Monte (OR) - Epoxy/Rivet Vincebar
        16) M3kid (FL) - Epoxy/Rivet Vincebar + Tooling kit
        17) Tom Day (IL) - Epoxy/Rivet Vincebar
        18) E46Envyy (Toronto, Canada) Epoxy/rivet kit + tooling kit
        19) big,JON (Australia) - TBC + tooling kit
        20) Jsottile - Epoxy/rivet + tooling kit
        21) ericthehalfabee (NV) - Epoxy/rivet + tooling kit
          Zekarus (Germany) - epoxy/rivet vincebar + tooling kit (+ vinceskinz if in stock need everything asap )
          2003 AW/BLK 6MT - Instagram
            I'm in for a epoxy/rivet + tooling kit, Southern California. Thanks.
            I hope we get past 30 units for 15% off.
              22) white_335i - Epoxy/rivet + tooling kit
                Just adding myself to the list.
                23) Will (CA) epoxy/rivet + tooling kit
                  Should be possible
                  23) Zekarus (Germany) - epoxy/rivet vincebar + tooling kit (+ vinceskinz)
                  24) Will (CA) - epoxy/rivet + tooling kit
                    Please add me for a weld-in + tooling kit. Will confirm with my shop tomorrow which style they prefer but should be fine, thanks!
                      How much shop time do y’all anticipate this would take? I guess I could take out the rear seats ahead of time.
                        ~70% of the job is stripping coatings up top and down below to bare metal. Total job will probably run north of 10 hours. Seats are quick, but good to remove yourself so there is no damage, even if shop covers them up while working.
                        Youtube DIYs and more
                          Updated my order to the weld-in kit, since my shop prefers to weld.
                          14) kenster (CA) - Weld-in + tooling kit
                            25) Vereni - Weld-in + tooling kit
                              Hey guys, put my name down for the weld in kit, I think?
                              I'm in Los Angeles, CA, trying to figure out if I should get the epoxy vs weld in kit. Will have to get a shop to install it. Do you guys know of a good shop in LA that has experience installing these along with Reddish V2 plates? Also, will I need to get the tooling kit if I have a shop install it?
                                I recently E-mailed Vince with the same question. This was his reply in a nutshell:
                                "My recommendation of VinceBar kit is the epoxy/rivet-in version of the simplified design.
                                Epoxy/rivet because it’s much less intrusive to the car, it avoids all the heat related issues related to welding, and it’s more DIY friendly.
                                Simplified design because it’s much easier and faster to install, and it’s still completely hidden and out of the way once the interior is back in."
                                I am also located in LA, however i'm planning to take my car to kaiv, He said he has installed a handful of these, however he's in SD. (he prefers to install the weld-in kit, which is why I went with that choice)
                                I called around locally and EAS in anaheim said they have not installed any.
                                Lang racing in Lake forest reported they have installed a few, however i found their pricing to be a bit steep for me.
                                Hope this helps!
