  • heinzboehmer
    Quick bit of maintenance.
    Harman Kardon amp in the trunk was acting up. When I parked the car in the sun, the amp would overheat and no sound would come from the speakers. So, I took it apart to clean it and replace the thermal paste:
    Click image for larger version  Name:	20250511_143042.jpg Views:	0 Size:	106.2 KB ID:	304883
    Click image for larger version  Name:	20250511_144338.jpg Views:	0 Size:	127.1 KB ID:	304884
    That's what the unit looked like straight from the car. I was honestly very surprised at how clean it was. I was expecting it to be filled with dust, but nope.
    23 year old thermal paste was definitely not doing its job anymore though:
    Click image for larger version  Name:	20250511_144604.jpg Views:	0 Size:	139.0 KB ID:	304885
    Click image for larger version  Name:	20250511_144618.jpg Views:	0 Size:	81.8 KB ID:	304886
    Cleaned the old stuff off, replaced with new and done. Hopefully this fixes my issue.
    Also, I have to say that I really like how this thing is designed. The housing is extruded aluminum, so the board slides in from either side. The long silver strip then clamps the amps to the housing and acts as more area for heat to dissipate. The part I thought was most clever is that the board isn't directly fastened to the housing. Instead, it's held in place by the front daughter board (with the harness connector), the heat sink clamp and these rubber bands that friction fit into the housing:
    Click image for larger version  Name:	20250511_145720.jpg Views:	0 Size:	146.7 KB ID:	304887
    Click image for larger version  Name:	20250511_145758.jpg Views:	0 Size:	80.3 KB ID:	304888
    Good stuff, gonna have to steal that rubber band idea for some future design of my own.
    The one downside of this design is that assembly is a bit fuzzy, as you can smear the thermal paste everywhere if you're not careful. But overall, thumbs up from me.
    Also, keeping with the audio theme, just sent my CD53 out to Baris - Carphonics for amp upgrades. Excited to get the upgraded unit back and installed. I didn't want to be left with no music, so I ran over to the junkyard and grabbed another CD53, which ended up being in way worse shape than my own. Swapped faceplates before sending mine out, as I was definitely not going to be able to stand the shitty junkyard one.
    But of course, nothing ever goes smoothly, and it turns out that the display backlight driver is broken on the junkyard HW. At first, I thought I had messed up the ribbon cable/faceplate when swapping, but I swapped back (and forth) and the issue stayed with the junkyard HW. So now I can't really see what the display says unless in fairly direct sunlight. Oh well, at least the audio seems to work fine. One more reason to be excited about getting my own unit back!
  • heinzboehmer
    Oh man, that's a serious crash. Glad you weren't hurt!
  • George Hill
    OH I know, I did this a long time ago. Walked away without a scratch surprisingly. The engine moved back far enough the starter broke off the block. I think the strut tower would have to be past the firewall to be an issue and I don't think that is likely a survivable crash, but maybe? IDK. Either way, I appreciate that it is a concern for you.
  • heinzboehmer
    If the bar moves that far to impale your chest I think you are dead either way lol
    But I appreciate your concern.
    Ha, you're almost certainly right and it's very likely that I'm being overly cautious about an improbable scenario. However, I really hate the idea of having something I designed injure someone, so playing it as safe as possible.
    I'm particularly scared of a front overlap crash. Note how much the strut towers can move in one of those scenarios, especially compared to how little (relatively) the passenger compartment deforms:
Name:	Bmw Crash.jpg
Name:	Screenshot 2025-05-07 at 4.09.52 PM.png
Name:	Screenshot 2025-05-07 at 4.10.01 PM.png
Name:	Screenshot 2025-05-07 at 4.10.09 PM.png
    (yes, I spent way too long looking at crashed E46s at the start of this project )
  • George Hill
    Chassis rigidity is cool and all, but hitting a wall head on and ending up with a brace going through my chest (or worse, a passenger's chest) would really, really suck.
  • heinzboehmer
    Originally posted by YoitsTmac View Post
    A quiet thought of mine is you could probably repurpose the hardware on this kit to get carbon fiber mountings.
    While I wasn't aware of that specific kit, I did consider similar approaches. This project would have been way simpler had I just made my own braces or adapted aftermarket ones, but I really want to keep the crash safety aspect of the OE E86 braces. I don't trust that aftermarket pieces were put through rigorous crash testing and definitely don't have the skills/resources to do that with a design of my own. E86 uses the same suspension design as E46, so that gives me confidence that the forces seen by these braces will be similar on both chassis.
    Also, custom strut bar end brackets are coming! I need to machine the stock cast aluminum pieces first before starting on the design, but I'm still waiting on the certification class to get access to the machine shop at work. Those pieces are gonna be designed for laser cutting + bending, so manufacturing should be very quick.
  • YoitsTmac
    This thread is epic. I can't wait to seee the progress on this bar modification - I would totally follow in your footsteps. Even just the firewall mount opens a lot of doors. A quiet thought of mine is you could probably repurpose the hardware on this kit to get carbon fiber mountings. I don't know the dimensions of that piece, but if you did a custom top mount, you'd have a lof of flexibility. you can likely replace the ends with whatever you wanted and just use the carbon tubes. Just a thought. Subbed!
  • heinzboehmer
    Hell yeah! Excited to see the process
  • bigjae46
    Just opened the box
    I am trying to get the mold done before the end of the month. I’m going to mold in threaded inserts - a first for me. I’m excited to get this done!
  • heinzboehmer
    Heinz, are the studs and nesting surface at an angle? Never noticed the bars ends were slanted. Looking good!
    Yep, they are. The bars themselves are totally flat, but the mounting point is angled to tuck the bars up as much as possible. There wouldn't be enough clearance for tools and the moment trying to rip the mount out would be greater if it wasn't angled. Makes the machining more expensive, but no good way around that, unfortunately.
  • maupineda
  • heinzboehmer
    Last piece of the validation puzzle arrived:
    Time to run through an entire mock install, just to make sure there isn't some small detail I overlooked.
    Started by printing exactly what is going to be sent out to be machined and installing the timeserts:
    Car then got disassembled and piece installed:
    I also printed out a cutaway of the piece to check (for the last time) that the profile of my design matches the chassis:
    Everything seems to check out!
    I forgot to take pics, but I also validated that there's enough tool clearance for the cap head screws that hold the brace attachment point to the main windshield piece. Regular hex bits are a little long, but stubby ones fit just fine!
    Was a bit nerve-racking, but this thing has officially been sent out to be machined! ETA is about 30 days, which gives me enough time to finish up the strut tower brackets.
    Also worth mentioning that I did a couple of small maintenance items while the car was taken apart:
    1. Replaced the main throttle actuator pull rod just for preventative maintenance reasons.
    2. Found a leak coming from the timing chain tensioner, so swapped that crush washer and retorqued. Was as enjoyable of a job as it always it. Let's see how long it takes before it starts leaking again.
  • heinzboehmer
    Important to note that if you’re going the weld route, absolutely do not use 7075, as it is prone to cracking in the heat affected zone! 6061 for welded, 7075 or 6061 for machined. Agree that the small premium for large piece of mind (strength) is worth it here. You could also machine this from various steels and thin the walls to mitigate some of the mass hit. But the machined design should be mega stiff so there’s not much benefit to the stiffer steel material.
    Oh that's good to know! I wasn't aware that 7075 was prone to cracking when welded.
  • Bry5on
    Clearances looking good, ready for a test fit:
    Couple things I should also mention:
    Some fab shops (the type that seem to sponsor every single electronics-related youtube video) are way, WAY cheaper than others. Like $300 for everything, it's insane. However, none of these cheap vendors specify T6 for their materials, so who knows what they're using. I think I'm not gonna risk it and instead I'll go with a vendor that tells me the exact material composition of what I'll be getting.
    Also, I ran some quick quotes to compare cost for the laser cut + machined version of the windshield piece I briefly discussed above. Bottom line is that I don't think it's worth it, unless you're good at welding aluminum.
    For 7075-T6:
    • Machined in one piece: $641.42
    • Multiple pieces: $409.49 (machined main body) + $40.25 (laser cut bottom sheet) + ~$100 (welding + machining bottom flat labor) = $549.74
    So roughly $100 less for the windshield piece if you go the multiple piece route. Even less if you use a cheaper vendor for the machining. I'm personally gonna stick to the fully machined version. Yes, it seems a little crazy to carve away that much material for the flat part, but the extra overhead involved with the other approach is not worth the $100 saved for me.
    All this is to say that you could technically get this all made for <$300, but I'm not going to.
  • heinzboehmer
    Got the full SimSolid analysis going to check the stresses on the adhesive. Largest load was with both braces in either tension or compression:
    Since everything is either gonna be steel or aluminum, I think I'm gonna use 3M 07333. Datasheet says that ultimate tensile strength of the adhesive is 35 MPa, so we're good! Will run this latest design through all my mechanical engineer friends just as a final check, but it's looking pretty final!
