  • Bry5on
    I got ECS ones as Turner was out of stock for a while. the adjusters are in the center which is not as good as at the wheel, but better than at the subframe/above the exhaust.
    Give the wagon a shot, you should be able to feel the difference in toe on initial turn in, but it might be tough to differentiate from the rebuilt rack at this point. Really good change IMO
  • heinzboehmer
    You should’ve gone with CSL rear toe specs! Also, you want my ground control spherical lower control arms?
    I thought about it, but didn't want to mess too much with toe before a track day. I've learned that toe really impacts how much I enjoy driving the car and decided I'd rather stick with something that I know is fine, rather than spend the whole track day annoyed because I didn't end up liking the change. Will probably mess around with it when I do the camber arms though.
    Did you end up getting the turner ones instead?
  • Bry5on
  • heinzboehmer
    Track day tomorrow, so got the car ready for that.
    Clock spring replaced with a new one:
    Then got an alignment:
    Rear camber is maxed out. I really need some camber arms, but I'm dreading the install. I did order some E36 diff bushings to replace the poly ones I have, so maybe that'll finally get me to do it.
    I also bought a rear dashcam for the car. I decided to tap into the existing parking mode power module and run a long USB cable to the rear. Soldered some stuff and ended up with two output wires from the module:
    Also added a connector for the long cable for easier servicing:
    Now onto routing the cable. Easy choice would have been to route it along the seam between the headliner and the door, but I really didn't want to have it interfere with the side airbags, so I did it a bit differently.
    Here's the output out front:
    Connected the long cable and routed it back towards the sunroof:
    I then routed the wire along the perimeter of the sunroof, this definitely keeps it far enough from the airbag:
    Pulled it out through the alarm ultrasonic sensor hole (just as a middle stop cause feeding it all the way to the rear was not easy):
    Fed it through to the third brake light area:
    And out the passenger C pillar:
    Still had some wire left, so I zip tied that out of the way:
    Trim back on and done:
    I did rip some of the fabric off of the pillar trim when reinstalling, so I reglued that real quick, no big deal. Pretty happy with the end result and install was a lot less painful than I expected.
  • heinzboehmer
    Never mind it died
    Oh well, back to using the worse looking key
  • heinzboehmer
    Today I left my key in the pocket of my jeans and put them in the washing machine. Key still works lol
  • heinzboehmer
    Was reading through the BlueBus thread and saw that some people were adding ground loop isolators to theirs. My throttle actuator seems to add a fair amount of interference, so I bought the necessary connectors + the isolator and made one real quick.
    The isolator came with a 3.5mm male to male wire, so I cut that in half and crimped terminals to the cut ends. Ted mentioned that the car side connector needs both ground pins populated, so made sure to do that:
    Fortunately all of Ted's stuff is open source, so no need to go probing with a multimeter to find out what is what. Instead, I just pulled up the schematics and based everything on that: https://cadlab.io/project/1479/maste...ZUJ1cy5zY2g%3D
    Difference is huge. I was getting both a low frequency hum and a higher frequency noise (from the throttle actuator) as interference before. Pretty much dead silent now.
    Here's the before. Creaking noise is me actuating the throttles to get the interference to come through:
    And after:
    I can hear some very slight high frequency pops with the isolator in, but I don't know for sure that those weren't there before. I have a feeling that the radio volume was set a lot higher during the test with the isolator and that's why those pops were audible. Either way, much happier with it now.
  • heinzboehmer
    When I found both lower wishbone to subframe bolts loose, I torqued them back up, but was only able to get a torque wrench in on the passenger side. Driver's side I did using the double wrench thing. Wasn't too confident that it was torqued properly, so I bought a stubby socket. Surprisingly, it still wouldn't fit, so I had to cut the thing down:
    Barely any socket left after that, but it worked! Still need to fix the subframe with the mending plates, but that will come later.
    After that, I was pulling out of a parking spot and heard/felt a crunch when turning the steering wheel. It only did it once, so I figured it wasn't an issue. However, on the way back home, I noticed that none of my steering wheel controls were working. So I took things apart and found this:
    Somehow one of the clock spring ribbon connectors failed. I didn't get an airbag light, but nothing else on the steering wheel worked. I guess the signal wires for the airbag are on the ribbon that didn't fail.
    Was halfway through soldering the thing back on when I decided that I didn't want to risk driving around with a non-functional airbag:
    Fine, I'll give BMW the stupid $200 that they want for a new one.
    Also, the thing was surprisingly annoying to take apart. Here's how I did it for documentation purposes:
  • heinzboehmer
    The spacers worked great as a quick, easy and cheap fix for the lower front ride height that I didn't want, but I realize they don't make sense for everyone.
    The exhaust clamps are 100% worth it. Super cheap and took like 10 min to install.
  • K-Dawg
    heinzboehmer I appreciate your ingenuity. You've come up with a number of unique and creative solutions that work for you.
    I like those spring mount spacers. I'm going to have to do some pondering on whether they might be something I should try. Same with the exhaust clamps. 🤔
  • Bry5on
    Glad it worked out! And it’s really a surprising difference! Makes the headers into a no compromise mod
  • heinzboehmer
    I could, but it would probably make future installs harder if I ever fully remove the clamps. When installing, I had to dissasemble and bend them open quite a bit to get them around the pipes. The bolts were barely long enough to reach with the clamps bent open, so I think I'll just leave them for now.
    And also, you reminded me of an update I forgot to include!
    Slideways and I compression and leakdown tested my car the other day. 180 psi and 2% leakdown on all cylinders. Pretty happy with those results!
  • Slideways
    Nice progress! Can't you cut down the bolts for the clamp?
  • heinzboehmer
    And lastly, I installed some clamps with a plate to join them together onto my section 1, after Bry5on did the same thing on his car:
    What a difference! No more rattles at idle or at random points in the rev range. I wasn't expecting such a change, but it definitely makes the interior of the car a much nicer place to be in.
    I was slightly concerned about ground clearance with those long bolts on the clamps, but I used my precision instrument to measure and they just barely clear:
    Piece of wood is butted up against the section 1 -> section 2 flanges in the rear and the plastic transmission shield up front. Should not have an issue with these things in that position and can always scooch them towards the cats a bit if I do find them catching on stuff.
  • heinzboehmer
    Also got my front suspension spacers in the mail and installed them. Sendcutsend doesn't do filleting, so I had to do that myself. Was pretty easy to do with a 1/8" radius roundover bit since the things are made out of aluminum.
    Here are the parts straight from sendcutsend (along with a couple different thickness of mending plates for the subframe):
    Click image for larger version  Name:	20230219_222205.jpg Views:	0 Size:	225.0 KB ID:	207733
    Filleted:
    Click image for larger version  Name:	20230220_184350.jpg Views:	0 Size:	59.0 KB ID:	207734
    Click image for larger version  Name:	20230220_183911.jpg Views:	0 Size:	313.1 KB ID:	207735
    Fits pretty well (and most importantly, flat):
    Click image for larger version  Name:	20230220_183923.jpg Views:	0 Size:	271.6 KB ID:	207736
    Click image for larger version  Name:	20230220_184012.jpg Views:	0 Size:	211.6 KB ID:	207737
    Click image for larger version  Name:	20230220_184257.jpg Views:	0 Size:	259.0 KB ID:	207738
    Gave it a quick coat of paint to mitigate rubbing through the powder coat on the spring perch:
    Click image for larger version  Name:	20230221_192224.jpg Views:	0 Size:	264.6 KB ID:	207739
    Click image for larger version  Name:	20230221_192307.jpg Views:	0 Size:	224.3 KB ID:	207740
    Click image for larger version  Name:	20230221_192320.jpg Views:	0 Size:	250.5 KB ID:	207741
    Install on the car was super straight forward. Street driving impressions are that it feels the same as before (which is good!) and there are no weird noises coming from the front (as expected). Also no more scraping when parking the car in my garage!
    And here's the CAD for the spacer in case it's useful to anyone: https://cad.onshape.com/documents/44...9d6f3c638aa3a3
