  • heinzboehmer
    Originally posted by Mike RT4 View Post
    Do you have any pictures of the final install of the Slon wall (as in were you able to grind away the required material on the cups)?
    Did you also notice any difference/improvements after it was installed?
    Still have not installed that thing, unfortunately. This is still my only car, so I'm a bit wary to loose the extra trunk space with the seats folded down, but that might change soon. Also, the adhesive I want to use for this is the same adhesive as I'll use when I do a CF roof, so I'd like to combine those two installs because of its short shelf life.
    I did have a conversation with Slon about this and yeah, sounds like grinding away some of the cups is the way to go. Wrote down the important bits from that conversation here: https://nam3forum.com/forums/forum/m...585#post150585. Hope that helps!
  • Mike RT4
    Jan 2022
    New wheels!
    Got some 18s for the street, as the 19s were quite tiring on rough roads and I wanted less unsprung mass. Tires are PS4Ss (which were not easy to source).
    Front: 18x8.5" ET35 Race Silver APEX EC-7 with 235/40/18
    Rear: 18x9.5" ET22 Race Silver APEX EC-7 with 265/35/18
    Car looks great and (most importantly) rides a looot better.
    Click image for larger version  Name:	20220115_122953.jpg Views:	380 Size:	219.5 KB ID:	156173
    Here's some weight data:
    Front (each):
    • Wheel 18": 20.4 lbs
    • Tire 18": 21.6 lbs
    • Wheel + tire 18": 42.1 lbs
    • Wheel + tire 19": 47.9 lbs
    Rear (each):
    • Wheel + tire 18": 47.1 lbs
    • Wheel + tire 19": 53.0 lbs
    Saved 5.8 lbs per corner up front and 5.9 lbs per corner in the rear. Not bad!
    Buut of course something had to happen. Drove for probably 200 mi before finding this in my left rear tire:
    Click image for larger version  Name:	20220116_135256.jpg Views:	352 Size:	91.6 KB ID:	156174
    Ridiculous. Got it patched and all is good.
    At some point, I also took my rear seats out, so I took the opportunity to test fit the Slon wall with the VinceBar cups in place. Looks great, but unfortunately does not fit that well because of the extra material that the cups add. Cups will need some grinding, but that shouldn't be terrible.
    Click image for larger version  Name:	20220129_172919.jpg Views:	351 Size:	100.0 KB ID:	156175
  • heinzboehmer
    Las thing I did was to get started on my custom seat cushion.
    I talked about making an L shaped cushion before, but ultimately decided to split it up. Still going to be L shaped, but just made out of two separate pieces. This is mostly so that the sewing is simpler, but will also make the whole thing a bit more adjustable.
    Started off by sketching out a cut/sew plan:
    Then came translating the drawing to real things. As mentioned before, I have no idea what I'm doing. So instead of messing around with (and probably ruining) fabric, I turned to the trusty CAD:
    These are the final versions of the templates that I ended up using:
    Transferred onto the fabric:
    The machine I got access to was honestly pretty nuts. It could do a bunch of complicated stitches and all you had to do was press the foot control and make sure the fabric was going through straight. Here's some of the stitch patterns I messed around with:
    Crazy.
    I do realize that me being blown away by this machine is probably the equivalent of someone being blown away by one of my torque wrenches, but I still thought it was super cool. Didn't end up using the machine for anything other than regular straight stitches, though.
    Here's the first stitch I did:
    And the final product:
    I stiched everything inside out so that there wouldn't be flaps of fabric on the outside and tried to follow how Cobra made their cushion. Images above also show how I left a ton of extra material on the sides. Did this so that I have some room to play with if I ever want to make this cushion any thicker.
    Here's the thing turned right side out:
    Velcro strips are a bit crooked, but whatever. Decided to use these thinner strips because I felt that the super thick ones that Cobra uses are waay too grippy.
    Then moved on to cutting out the foam. Thought that using scissors would work out well, but quickly learned that this was not the case. Edges turned out super jagged and it was really hard to make sure the cuts were orthogonal to the face of the foam:
    It's good enough for now, but I want to redo the foam with some sort of hot knife thing.
    Lastly, the test fit:
    It fits quite well! Pretty happy with how this turned out, especially considering that I was learning how to do all this as I went along. Seat looks kinda stupid with the Cobra cushion pushed all the way up like that, but whatever, it's a lot more comfortable on the street like this,.
    Next step is to replace those towels with a cushion wrapped in fabric that matches the Cobra cushions. Ordered some dinamica samples, so will get to that once I know what matches best.
  • heinzboehmer
    Knocked out a few things this weekend.
    First off, I noticed that the fabric on my A pillar covers was starting to get pretty bunched up when I ran all my new dashcam wiring. Glued it back on with some 3M super 77.
    Masked and adhesive applied. Put a ton on because that seemed to be what worked best when I was trying it out:
    Turned out great! They look brand new now:
    Then I trimmed the plastic trim pieces that come on the stock seat rails so that they would fit onto the new rails with the nogaro brackets.
    For the first one, I almost exclusively used a dremel to do all the trimming, but I found out with the second one that it was quicker and just as good to use a box cutter. I did have to remove a decent amount of material, so I added some foam and zip ties to keep everything from rattling:
    And here's the final product. Much nicer looking than the naked rail, in my eyes:
    After that, I mounted the fire extinguisher under the driver's seat. Used to have it under the passenger's seat before getting the nogaros, but it's much harder to reach that seat now, so I decided to move it over.
    I just zip tied the plastic clip that came with the extinguisher to the substrap bar:
    Fits quite well in between the sides of the substrap bar. However, it does sit pretty far back, so it's not super easy to reach. I can reach it no problem with the three point belt on (even with it locked), but can't reach it with a buckled harness. There aren't any other good spots to mount it on, so I added some string that I can reach when strapped in with the harness:
    String goes up and is held below the bottom cushion by a small piece of velcro:
    Pretty happy with how it turned out. Extinguisher is super easy to retrieve and is kept above the lowest solid part of the seat rails (substrap bar), so there's no danger of it getting crushed when moving the seat back and forth.
  • heinzboehmer
    Seats look great! Only people on the forum will know that you colored your seats in...lol
    The inboard side mount bolts are the worst. I use B7 studs with loctite on the inboard side of the seat. Makes installing the seat no longer a chore. Eventually I want to remove the upholstery and screw in a bolt from the backside.
    Thank you! I'm pretty sure I saw you say somewhere that you mounted your seats with studs and that gave me the idea to do this.
    Definitely! Too bad it's been raining so much lately. You should also try my seat out (and vice versa), I'm pretty curious how the two differ.
    I was lucky not to have discomfort (our torsos are likely different, but also maybe the wings on the Sparco are higher) - my shoulders are on the lower end of the wings, and don't really get pushed forward a whole lot. I think my height is similar to yours and recall it being quite disorienting as well, but I quickly grew to love it. I generally like sitting low, and usually push the seats in other cars to their lowest setting - not sure if the M3 seats are any lower than the non-M sport seats, but I felt they were always too high for a sports car. When I need to see the hood as reference for parking or pulling in/out of parking spots, I lean forwards off the seat back haha.
    Yeah definitely have been getting used to the seating position, am liking it a lot more now. And yeah! Welcome to try out my seats whenever. Also curious to try yours out.
  • timmo
    Hey man! It has been a while. Maybe we can do an occasional autox soonish
    I'm pretty set on trying to make these seats work for me, as they're the only ones I know of that meet all my requirements (three point compatibility, harness compatibility, ease of ingress/egress, lightweight, etc.). The only others that might meet all of that are Pole Position ABEs, but I'm not fully sure how comfortable they would be on the street with the three point receptacle having to come through the seat. I think it'll be pretty much impossible to find a local car with those seats installed, so I'm going to try my best with the Nogaros. I've been messing around with them a good amount and I think I have a plan to make them comfortable on the street. But I'll definitely let you know if I find that I just don't well in the Nogaros.
    Speaking of, I put a bunch of towels in the car and started driving around. Sat on them, put them behind me, put them besides me, basically tried every configuration I could think of to see if any made it more comfortable for me. I've learned two things (that kinda go completely against what I initially thought was uncomfortable about the seat):
    1. I'm pretty confident now that the discomfort of sitting too low is 100% in my mind.
      1. It felt very disorienting to have such a drastic change in the driving experience of a car that I've become so used to. However, the more I drive it, the more I like the "racecar" feel. I still think I'm at the limit of too low because my eyes are only about 1-2" above the steering wheel, so any lower would significantly limit my visibility. But point is, I'm liking it more and more, so I'm pretty sure I'll get used to this.
    2. The discomfort is exclusive to my shoulders
      1. The length of my torso puts my shoulders right at point where the "wings" of the seat extend the furthest out. This means that my shoulders get pushed forward a LOT, which becomes uncomfortable after driving for a while. If the radius of curvature of the "wings" were a bit larger, I wouldn't have any problem.
    Since the discomfort is isolated to the shoulders, I should be able to solve the issues by modifying the seat so that my shoulders can sit a bit flatter. I initially thought that if I sat further up, my shoulders would move out of the most aggressive part of the "wings", but it turns out that I have to sit too far up for this, so that idea won't work. The thing I did find that worked was to add extra padding to the back of the seat. This pushes my entire torso far forward enough so that my shoulders can extend back before hitting the seat. Here's prototype number one:
  • bigjae46
  • heinzboehmer
    With the extra padding, is the seat even an upgrade in supportiveness? For me, as a pretty big guy, the nogaro is already not super supportive, especially in the legs. If you move yourself forward, you’re basically eliminating the side support, other than the very small area (for seat belt receptacle clearance) by your hips.
    Slightly. The wings of the seat still hold my shoulders in place a bit.
    But I only plan on using the extra padding on the street. I'll take it off on track, which shouldn't be as uncomfortable because my arms are always fully outstretched.
  • Bry5on
  • heinzboehmer
    I do want to add a small bit of velcro at the very top of the cushion (already glad I went with the velcro) because it seems to "untuck" itself after you sit in the seat. I don't think it does that because of what I did, but maybe. Regardless, a bit more velcro should keep it on no problem. This is where I want it to go:
    I ended up doing this to one of the back cushions and it didn't solve the problem. Turns out the "untucking" is due to the fact that the fabric on the seat is not anchored to the seat shell and has nothing to do with how secure the cushion is against the seat fabric. I ended up removing the extra strip of velcro.
    However, this won't really be an issue with the thing I'm going to be making for the back cushion, so whatever.
  • heinzboehmer
    Been a while! Sucks to hear... and it wasn't something I planned on but let me know if you want to get rid of them. I no longer do track days (might do the occasional autox) but I still have my Sparco Pro2000 because the height and feel is so much better than stock, but a PITA to ingress/egress out of. Never sat in these specifically but I'm thinking it'd retain a similar feel, but would be much easier to get in/out of
    Note that the seat has the back cushions from both seats stacked one in front of the other in the pic. I was messing with different heights and widths for the top part, so that's why there are multiple towels up there. I found that to be comfortable, the extra top padding could not extend further from the limits of the Cobra back cushion. Which led me to prototype number two:
    Still both back cushions stacked, but now with the frontmost one shifted up. I'll be doing a longish drive soon (that probably will involve a decent amount of sitting in traffic), so I'll set it up like this and if I don't experience any discomfort, I'll move forward with making an actual cushion.
    My plan is to make an "L" shaped cushion ("L" shape is perpendicular to the plane of the back of the seat in this case) that velcroes onto the seat in place of the Cobra cushion. Then the Cobra cushion will go on top of that. The bottom part of the new cushion (the lower part of the "L" and what's represented by the towels in the above pic) will be wrapped in alcantara to match the Cobra cushion. The rest of the cushion will be made out of something that the Cobra cushion can stick to.
    Making it this way as opposed to simply an extra cushion to place in the seat solves multiple problems:
    1. No need to try and get good at sewing so that the cushion looks good (with decorative stitching and curves and shit), as the only visible bit will be the lower rectangular protusion.
    2. No need to go hunting around for comfortable seat foam. I could stuff the thing with rocks and it would still be fine, since the outermost layer will be the Cobra cushion.
    It won't be the prettiest thing in the world, but I think it will finally make the seat comfortable. Plus, everything is held together by velcro, so I'll be able to make it look normal in ~30s in case I want to show off to others how cool the seats look. Oh and I also found a fancy sewing machine that I can use, so no more wasting time sewing by hand.
  • timmo
    I'll play around some more with stuffing towels and pillows in different spots to see if that makes me fit better, but I might ultimately need to look into getting different seats.
  • heinzboehmer
    Let’s just design you a custom bracket that mounts the seat higher. Shouldn’t be more than a hundred bucks per side after powder coating.
    Also, would you mind measuring the offset of the OEM seats if you can, and compare to your mounts? The OEM e46 seats aren’t centered on the wheel either. The cluster is even slightly offset to the right of the wheel so that it’s in the center of your vision with the offset seat. To some degree this can be placed with a custom bracket, until you run into the seat belt.
    I thought about doing what you did and going full custom on the brackets, but I think the problem is mostly how I fit into the seat. The feeling too low issue can be solved with custom brackets, but I'd still be uncomfortable in the seats.
    Drove around sitting on a towel today and it was better, but I think I'm going to need to get that stupid expensive lumbar cushion to get to a tolerable comfort level.
    Also narrowed down the comfort problem to my shoulder position. The combination of being hunched over because of no lumbar support and sitting too low in the seat makes it so that my shoulders are pushed way too far forward all the time. I'll play around some more with stuffing towels and pillows in different spots to see if that makes me fit better, but I might ultimately need to look into getting different seats. Super annoying because I did sit in a Nogaro for a decent amount of time and thought it fit me well, but I guess I really should have driven around a bit to be sure.
    And yeah I can definitely measure that. Will try to do that soon. I do have a feeling that the offset is similar to the stock seats though and I just noticed it now because I was looking at everything in much greater detail with the new seats in. Steering wheel position doesn't really feel any different than it did before when driving around.
  • Bry5on
  • heinzboehmer
    Got the second one installed. Went pretty smoothly since I knew what I was doing this time.
    I did learn that the transmission tunnel is asymmetrical though. The passenger seat does not run into the tunnel and instead hits the stops on the sliders when being pushed all the way forward. Makes backseat access easier, but it's still tight.
    Here's a pic taken from an angle more like yours Thoglan, with both seats as far forward as they'll go. Passenger seat is visibly more forward than driver's.
    Still less space than with the PPs. Maybe the Nogaros sit further back in relation to the seat rails?
    Also, got a couple hours of driving in with the new seat. Very boring, sit in stop and go traffic type driving, but I think that makes my impressions more insightful, as it's the worst case scenario comfortwise. In summary, the Nogaros are definitely a downgrade for street driving and for my body type compared to stock.
    Here's a list of pros and cons:
    Pros:
    • Much more solid than stock. No creaking or flexing when adjusting myself.
    • Much lighter.
    • Three point seatbelt works perfectly fine with them. I knew this would be the case, but it's still nice to confirm.
    • I did not notice the off centeredness (in relation to the steering wheel) at all while driving.
    • Backrest uprightness is totally fine for me.
    • Feels like a racecar. I feel cocooned by the car and the lower seating position puts the shifter and steering wheel in a spot that makes me feel like I'm in an S2K.
    Cons:
    • Feels like a racecar. There's no button to turn off this feeling, so you're stuck with it whether you're in traffic or not. Gets old fast if you're not driving aggressively.
    • These things are HOT. I was not expecting this at all, but they're not very breathable, especially in the sections wrapped in alcantara.
    • Sitting in traffic means a decent amount of time with my arms down, which in turn means my shoulders get pushed forward by the seat a bit too much. Can get quite uncomfortable after a while.
    • They're unfortunately past the limit of too low. I thought they weren't, but driving the car made it very apparent that they are.
      • I can't see the front of the hood, which makes placing the front of the car much harder.
      • Every car blinds me with their headlights.
      • Blind spots are HUGE (they weren't before).
      • Being so low means that I don't know what to do with my left arm. The door armrest is too high and just dangling my arm in space feels weird.
    I sat and stared at the seats a bunch after the test drive and I've come to the conclusion that the seat is at a decent height in relation to the chassis. However, I sit far too low in the seat (stupid short torso). I'll drive some more tomorrow sitting on a towel or something, but I'm pretty sure most of my comfort issues can be solved by having me sit a bit higher in relation to the seat. So I think my solution to this is to build myself a booster seat. Should be pretty simple to wrap a block of foam in fabric to put between the lower seat cushion and the seat itself. Need to look into what type of foam and fabric to buy, but I'm fairly convinced that my next modification for these things is going to be that.
    Also, just to be clear, these things are super supportive and feel great when driving closer to the limit. I'm sure they're going to be awesome on track, but they did turn out to be very much a compromise for me on the street.
