Tyler's 04 slicktop 6spd Silvergrey MCS/BBS/Brembo/CSL/Karb/Nogaros/Supersprint
    Thank you! I only will swap OE sect 2 for CSL green stamp sect 2 (actually I may try a resonated X pipe just for fun sometime purely for sound reasons)
    April 2020
    Finally got around to installing some software and buying a license from Martyn for the binary tool. My car's already been coded by other people for almost everything I want, but my goal here is to play with the throttle settings and view flash counter (Martyn's most recent tool).
    May 2020
    Originally, I didn't do a great job routing my Turner IAT harness. I finally got around (I should name this thread "I finally... ) to cleaning the area up and I routed the IAT wiring along the same path as the factory wiring in the area for the cleanest look I can do I think:
    June 2020
    Interior work. I guess I should have bought a new set of carpets back at this point in time (hindsight, before they ran out), but I just wanted to refresh the look of the driver side one. I used soap and water to clean it, then I used my old E36 "back to black" trim dye to darken it to look newer.
    Looks ok
    July 2020 more interior work
    Finally decided to just rip out the tint. I've always liked tint, being in Socal, but as I've been making the car more OE/CSL looking, the tint is detracting from the look and just now looks cheap/ghetto to me. At first, I was thinking I'd have to pay someone, but it ended up being very easily actually, just using a heat gun (or hairdrier). Thanks to liam821 for tint removal info. Didn't need steam. I did use windex/water mixture to lube as I went. Almost all of it came out in whole sections, luckily. The tint is 3m, and was applied in 2010, so it's not like it was recent and that's why it came off super easily.
    Used a razor blade to get the corners started (heat first)
    Some little bits might get caught in the window trim. I used a razor to hold the trim off the glass, then pulled/dragged the little bits of film/adhesive with windex soaked Q-tips.
    Clean
    Driver side
    The rear is the hardest. To make it easier (access), and because I've never cleaned/touched this area, I pulled the rear shelf.
    OGs will know about the tennis balls
    The good side effect of having tint for so long, for a car that was not always garaged, is that my interior is in good shape and this rear shelf isn't too faded. I was thinking of dying/spraying it, but....
    After a good wash (water/drop of dish soap), it got a little darker and matches the other interior fabrics perfectly, so I don't want it black black.
    Removed more weight. These are part of the child restraint sys. No car seat in this car lol
    303'd the rear vent/trim
    I had done this years prior, but got a picture of it now. I put some closed cell sound foam under the rear bench to quiet down the diff whine and overall road noise. I've said it before, but my goal for the car is that fine line between hardcore and BMW luxury/class. This doesn't add any weight.
    Along the same lines, I added some sound deadening to the rear panel and the speaker cones.
    Light weight sound blocking foam on top of the BMW foam
    Rear Tint C pillars removed as well
    Center shade cover has been cracked and warped a while, so finally got a new one
    Pretty clean! I don't run rear headrests
    Obligatory Nogaros shot. Tasty
    FISHBOWL:
      Awesome build, if you slide the seats all the way forward can you still access the rear seats and some one could sit back there? Thinking about these seats or the speedsters. Thanks!
        Thank you. I can only speak about Nogaros on OE manual sliders using BK setup. The passenger side seems to scoot a little farther forward, but both sides are pretty difficult to get behind. And I'm not a big guy, pretty slender. It's not ideal tbh. Perhaps there's a way to mount them differently that would create more space. Oh, and I have them in the more reclined position, so that makes it a hair tighter too (it's not that tilted tho)
          I need those seats!! Looking good my dude.
            Nice, looks like you have been busy too.
            Sent from my SM-G965U1 using Tapatalk
            2004 Jet Black/Cinnamon 6spd ///M3
            Build///Journal
            IG: Khan_Art_
              I've never done so many things! Still got more updates coming too.
                I don't know how you find the time to keep it that clean.
                  July 2020 continued
                  I had been running OE grilles with blacked out center slats ala non-m 3 series. It was a sleek look, striking a balance between OE class and aggressive, but I decided to go completely original as far as the exterior goes.
                  New OE:
                  August 2020
                  I was starting to tire of the paint finish (too flat, too bright) of my Sportline wheels. They're such great wheels, I even contemplated having them repainted, but when an almost new set of CSL wheels (which are backordered!) with new PS4S popped up, locally, for sale by member Discowagon, I jumped. These wheels and the CSL boot are just perfection to me, I had to have them!
                  Glam shot upon returning home:
                  Sportline 18" 275 PSS vs. OE CSL 19" 265 PS4S
                  Mounted
                  Before mounting, I dressed the wheel liners and cleaned the suspension:
                    Thanks. I've really only been able to take my car to the next level due to these 3 things:
                    -No longer a daily
                    -Fully garaged
                    -Covid19 lockdown, work from home
                      -No longer a daily
                      -Fully garaged
                      I'm all those things too, but yeah, I couldn't tell you the last time I wash my car lol
                        One of the best M3 builds on the planet! Love this thread.
                        Instagram: @logicalconclusion
                          Thanks guys! Still got more content to upload, and a big development coming!
                            Anyone else feel like this after this update??
                            2005 BMW M3 (6MT) Instagram
                              everything is done really tastefully! love it!
                                You might have seen, I made a new thread for it, but I recently acquired a 02/2002 Steel Grey 6 speed coupe with 123k, 2 owners, no accidents M3. It doesn't fit, chronologically, with this thread as I'm still updating from 2020, but I wanted to mention it, very exciting! It's replacing the experiment that was the 128i. A very cool car in its own right, but not what I want exactly, as I came to find out in 2020, after owning it about a year. In the end, it being a place holder for this new E46 worked out perfectly as its value hasn't dropped at all.
                                Continuing with the silvergrey...
                                September 2020
                                Coolant flush/refresh. I'd already replaced the WP, Tstat, radiator previously, so this wasn't a full refresh, but it was time to flush the coolant anyway so I took the opportunity to make some small-ish changes. My friend gave me a lower mileage expansion tank (mine's level had broken inside), I replaced the hard line going from upper hose to exp tank (with new OE), I got Wolfn8tor's O-ring pack, and I bought new radiator hoses as I tired of the blue silicone ones after like 6 years (going more OE look).
                                It also gave me the opportunity to clean the last, untouched part of my car, the area under the exp tank/SAP.
                                One of the messier cars to drain. I pull the lower hose off the rad.
                                Tank removed. SAP is already gone, if you remember.
                                My friend also gave me a waterpump shaft "beauty" nut. I should prob sand it down and paint it.
                                Putting Gary's o-rings in. I bought new hoses, but the OEM CRP (conti) ones, and I didn't quite trust the o-rings like I would with OE. Gary's kit was great timing.
                                I use aerospace 303 wipes on just about everything, even little harnesses. Cleans and rejuvenates in 1 step, plus protection.
                                New(er) Exp tank in, O-rings on and lubed. Two o-rings on these because this cap vents. Our exp tank is the highest point and is self bleeding (after/as it cools). The little screw on the upper rad hose is vestigial from E36 days, I believe.
                                I already polished most exposed metal like heatshields, vanos, AC line ends. I did a another quick polish since I was in there. Used a wet rag and simple green to clean the fender area down there. Sprayed the back of the headlights with 303 to renew all that plastic/rubber.
                                More than any special product/chemical, just putting in some effort will yield a significant improvement. My way isn't too fancy, I clean with simple things like water and diluted simple green, then I follow up with products like 303 or any trim/vinyl protectant. Mostly, it comes down to elbow grease/effort/time. Which is great, cause I have that! No real $ spent yet it transforms these 20 year old cars.
                                Moar engine bay shots 'cause why not
                                To finish, I use Genuine BMW blue, I put in a half gallon and then almost 2 gallons of distilled water. Run it, open the heater, let it get hot, then check it the next morning and add a few ounces of water till the level pops up. No need to bleed, as I mentioned earlier. Squeezing the hoses can help move fluid through, but you don't need to do it to try to get air bubbles to come out.
