Black & Tan 332iT
  • Suspension Decoder
    Nice to see you in here! Big fan of the spreadsheet you’ve been hosting for ride calcs. Thank you. If you’re interested, I’ve modeled roll, jacking and travel earlier in this thread as well.
    I’ve been chasing chassis (vs suspension) stiffness and have roughly doubled the torsional rigidity of my e46 at this point. I’m actually pretty happy with the stock M3 ride frequencies and travel (my touring corner weighs very similar to an M3), just not in love with small bump sensitivity performance. The stiffness increases in the chassis have been super eye opening for grip, chassis and suspension/tire control. Next, if I can make the front struts act more like a constant cylinder than a wet noodle by redesigning the front knuckle, I figure I can set myself up to best position the dampers up for success by reducing some stiction and undamped flex.
    I was actually pretty local to you for the past 8 years and only moved to San Diego two months ago. It would have been great to A/B drive both cars. Maybe I’ll come back to visit and can take a rain check.
    Glad you've found those calcs helpful - I'd be happy to check out your modeling. Any idea what pages / what part of your build thread to aim for when searching??
    Chassis stiffness is magical. I learned this from my Miata days. Interesting how much room for improvements exists on the M3 as well. Your M3 dampers are jacking down into the bump stops, have a TON of compression and rebound in the rear, and have ZERO high-frequency softening capability (which is what my Ripple Reducer provides, inspired by off-road racers who have been drilling small holes in their pistons for decades to filter road rumble). The behavior isn't unique to the E46 M3, but it's all to familiar when I look at sport sedans / sport coupes.
    I would be happy to meet you in LA sometimes before I go if you want to experience first-hand what I consider a well-optimized GT / Dual-Purpose suspension (frequencies around 1.9 Hz / 2.1 Hz). I'd have the bulk of the drive so it's your call. I've had a lot of people decide to work with me without demo rides. Obioban / Ian has a setup from me on his E46 M3 and I'm doing to build one for his 128i that includes more recent enhancements to my Ripple Reducer per conversations and calculations with an Mech Engr customer.
    The rain check would be driving to Alabama so I've got two weeks if we want to make a meet happen. I can drive during the week so it's not limited to weekends. Maybe sleep on it and see if this appeals to you?
  • Bry5on
    Originally posted by Suspension Decoder View Post
    Bry5on, greetings!
    Our uber-moderator recommended I contact you. In a brief review of the first and last pages of your build thread, I can see you're extremely thorough. It also looks like you're in San Diego? I would love for you to experience a Fat Cat Motorsports suspension - I have the top-end Stage 3 Ultimate on my E46 330i right now (baby M3, not S54 swapped yet like your wagon, but lightened and tuned for track/autocross). The balance between grip and comfort is very good for a track/autocross-focused suspension.
    I am leaving CA in a couple weeks for a relocation to Birmingham, AL, though would love to drive down (perhaps to LA?) and meet up with you! First, a phone chat would likely be a good start. My cell is 408-221-8247.
    Cheers,
    Jalal (Shaikh @ Fat Cat Motorsports)
    Bry5on, greetings!
    Cheers,
  • heinzboehmer
    The necking down is below the clamp, fortunately, so it’s not actually hurting deflection as that section is dormant. But good thought.
    Oh right, was misremembering where the clamp went on the strut.
  • Bry5on
    Looks like you're modeling this with a hollow cylinder of constant radii, but don't the dampers neck down at the knuckle interface?
    I would think the necking down makes the deflection even more pronounced with just one clamp.
  • heinzboehmer
  • discoelk
    That stiffness increase almost justifies bracing the OE strut/knuckle interface.
  • Bry5on
    Okay, did the math. George Hill came through and cut a strut tube open to measure its wall thickness. When accounting for the actual strut wall thickness, we get almost exactly a half degree of camber lost under the max-G load case.
    And since this is a pretty simple beam flexing calculation, we can nondimensionalize (conservatively) the change of adding the second clamp 80mm higher. What's the result? It almost halves the expected deflection for any given load case on stock suspension, where the benefit is even greater the lower the car is.
    So I'm planning to find a way to re-run another generative design iteration with the goal of keeping all the stiffness improvements but dropping some of the unnecessary weight imposed by the earlier iterations. More time in the design seat, coming right up.
    Click image for larger version  Name:	Screenshot 2025-07-22 at 9.59.26 PM.png Views:	6 Size:	426.5 KB ID:	312847
  • IamFODI
    Tough call, but...
    My, not particularly well-informed, opinion is to go with the extra stiffness, on the basis that if you want to drop additional weight then there's probably still some other ways you could eke out some savings, but seems this is the only way to improve the strut mount stiffness.​
    ^ This IMO
  • karter16
    Looks like the only thing for it is an A/B test 😉
    I was going to say you need to run the box section through the generative design tool to make it look more organic 😂, but then you posted the renders with the shielding etc. and it all ties together very nicely!
  • YoitsTmac
    All fair points. I guess this points to why someone didn't just make the “perfect suspension” and never iterate. Pros and cons to each possible route you take.
    - 1% weight, higher cost, less camber distortion, more consistent alignment under braking and turning
    - easier dev, similar distortion to stock, but no really handling benefits outside of handling your updated control arm design.
    The track guys seem pretty happy with the stock M3 geometry so I'm glad you're not messing it. I forgot one quality of Ackerman was its relation to the pivot point, so makes sense you can't adjust it too much. Definitely excited to see what you choose.
    If you go for the more rigid setup, for prototyping, you can probably 3D print two pieces with some pegs to hold them together for initial prototyping.
  • Bry5on
    Originally posted by YoitsTmac View Post
    What do you suspect the camber loss is? My initial inclination would be to say stiffen it up. But, for those who really want maximum performance out of these, you can get an alignment to contract these negative externalities.
    Dropping a pound, while I don't know the percentage decrease from factory, should allow for more steering feel I'd presume. If you went this route, you could likely design the nuckle to “give more” performance IE Ackerman (maybe?) to offset the performance losses from lack of stiffness.
    Of course, it's entirely up to you. Seems like the lighter design is also the easier build. Combined with your proposed CA design that makes the car more bump compliant, it feels like the more cohesive package. If the camber loss is similar to stock, then your net package will be an improvement over stock in weight, steering, bump compliance and maybe Ackerman.
    You can basically interchange weight and rigidity as a benefit as the rest is the same. Otherwise strut flex can be adjusted for in an alignment while you can't align weight out of the system.
    Yeah good points, I'm thinking about it similarly. One caveat: adjusting more static negative camber comes at the cost of braking performance. Camber loss looks like about .25 degrees in an absolute max-G corner with a sticky tire.
    For percentage weight reduction:
    245/40/17 tire: 25lb
    17x9 apex wheel: 17lb
    brakes: 28lb
    e46 spindle, hub, heat shield: 15lb
    damper: 8lb?
    other stuff: 5lb? (control arm affective weight, spring effective weight, sway link, sway effective weight, etc
    total: 98lbs
    So 1lb is 1% of the front corner's sprung mass.
    The stiffer part is also a bit more money, and it's taller than my plastic printer can print (time for an H2D??) so I can't do a full prototype unfortunately like the lightweight one.
    I'm also maintaining the factory e46 M3 Ackerman setup as closely as possible. I adjusted the trailing arm pickup point along the virtual Ackerman line that intersects the car centerline at something like 400% of the wheelbase. In theory I can add a tiny bit of Ackerman before I run into the brake rotor, but not much. The newer cars use the dual ball joint trick to dial in more Ackerman while staying well away from the brake rotor. Since my car isn't lowered, I'm also not dropping the LCA and tie rod pickup points at all as the roll center height is pretty dialed in from the factory - not looking to change that.
  • YoitsTmac
  • Bry5on
    Okay, so I have a dilemma. I got back to work on the custom suspension knuckles. As a reminder, I'm targeting the non-m steering ratio, the later model replaceable beefy wheel bearings and a stiffer overall knuckle. Ideally, we do all that with an unsprung weight reduction.
    I'd been pursuing 3D printed aluminum, but was juuust shy of making the loads close with the safety factor I wanted. Then I remembered that even 3D printed materials can be heat treated for better properties. Once I punched those properties in to my analysis, the loads closed with some margin. So we're back in the game, after receiving the printed parts I'll just need to do a multi-hour ~450C oven heat treat followed by a quench, then a handful of hours at 100-150C for accelerated aging. The e39/porsche style steel inserts still need to be very strong, 4340 for those.
    So back to the dilemma. I've been hemming and hawing about putting a second strut mount up above the first one ever since I saw the amount of camber loss that happens from strut bending (the primary source of camber loss, as it appears). I decided to take some inspiration from the M4 GTS, but figured I could do better by using 3D printing. The F80 M4 GTS knuckle:
    Click image for larger version  Name:	zunouk5g2ylzt57ykxlw.jpg Views:	4 Size:	47.3 KB ID:	312613 Click image for larger version  Name:	KONgsk7.jpg Views:	4 Size:	108.1 KB ID:	312614
    This knuckle uses a second strut clamp and some ribs to connect directly back to the wheel bearing. So how can we do better? Well, because we're going to be 3D printing these, we can leave internal voids in places that would never be able to be machined and we can box this entire section out. This should significantly stiffen/support the strut which will provide less hard corner camber loss and also better damper motion (because it's not actively being bent nearly as much). BUT it adds 1lb to each corner, which means I'll effectively come in at the same weight as the stock e46 M3 knuckle, whereas before I was dropping a pound. So what do you all think I should do here, lightweight or stiff?
    Click image for larger version  Name:	Screenshot 2025-07-20 at 3.37.35 PM.png Views:	4 Size:	837.1 KB ID:	312615 Click image for larger version  Name:	Screenshot 2025-07-20 at 10.07.57 PM.png Views:	4 Size:	934.2 KB ID:	312616 Click image for larger version  Name:	Screenshot 2025-07-20 at 2.01.56 PM.png Views:	3 Size:	352.7 KB ID:	312619
    edit: Here are the heat shield options as well. One simple, one ducted. And as you can see, the gusset acts as the heat shield to protect the strut from radiation:
    Click image for larger version  Name:	Screenshot 2025-07-20 at 10.39.30 PM.png Views:	0 Size:	491.0 KB ID:	312622
    Click image for larger version  Name:	Screenshot 2025-07-20 at 10.39.52 PM.png Views:	0 Size:	547.7 KB ID:	312624
    Click image for larger version  Name:	Screenshot 2025-07-20 at 10.40.13 PM.png Views:	0 Size:	653.0 KB ID:	312623
  • Bry5on
    Short on time so the rest of the updates will have to wait. But in the meantime, the Tesla Model X hitch adapter will fit the BMW receiver if it is 1) bored out a little in the aluminum section and 2) clearanced a little bit where the blue is in the photo below. Party time, doing our family e39 touring this way.
    3D scan, Tesla hitch: https://s.digital3dcloud.com/space/f...lang=en&loop=1
    3D scan, BMW hitch: https://s.digital3dcloud.com/space/f...lang=en&loop=1
    Preview, remember this project?​
Name:	Screenshot 2025-07-19 at 6.47.54 PM.png
