Today I learned:
1) The steering model is not just a ratio model, it is built alongside the vehicle cornering model
2) The ZCP model has very few changes from the M3 model
3) The ZCP model has a significant change to the expected yaw calculation at around 65mph that *goes with the steering ratio model that we set in NCS* - and this change is to a table that is not editable with NCS Expert
4) My too-early DSC interventions all happen about 65mph where the calculated expected yaw and actual yaw values differ by ~4deg/s
5) The DSC intervention threshold in normal DSC mode is ~4deg/s (variable and above 15deg/s in m-track mode)
Why is this significant? In my build thread I've been chasing (and datalogging) DSC interventions and trying to figure out why I have this issue with the non-m (same ratio as ZCP) steering rack even though I'd coded the rack's ratio. The learnings above explain why Heinz, who has a ZCP MK60, has not been able to reproduce these symptoms.
Here is a graphic to help tell the story (snippet of my datalogs here, pulled from CAN MK60 datalogs of expected and measured yaw). ZCP calculation in red, M3+ZCP rack calculation in blue, actual value in black, DSC trigger threshold in dotted blue:
edit: here's a plot that shows the differences between the two calculations ZCP vs M3+ZCP rack:
