Originally posted by timmo
Black & Tan 332iT
- Likes 4
Originally posted by timmo View PostI'm wondering if there has there been feedback that these solid couplings make any noticeable difference to steering feel. Cool idea and neat little machining project with the sphericals though
- Likes 3
Interesting in hearing your thoughts about that steering coupler. Especially considering how sensitive you are to NVH
Maybe you could start with one of the off the shelf ones and drill it out to accommodate the spherical bearings. Would save you a bit of work. Most of them have reliefs cut out though, so not sure if you'd have enough material to work with.
I thought this was a 'no no' with LHD cars since the rubber guibo compensates for misalignment while RHD cars have a UJ. Solid steering couplers on LHD cars can damage or wear the steering rack IIRC. That's why places like CMP only sell a solid coupler for RHD. I'm sure there was a discussion about it a while ago but I could be misremembering.good callout though, you’re absolutely right that a solid adapter is a no no
Originally posted by Bry5on View PostSpent a few minutes last night to design a solid/spherical bearing replacement for the steering guibo, another mill/lathe project once I free up the time
- Likes 5
Originally posted by heinzboehmer View PostStill planning on swapping in the M3 floor and exhaust? Don't know too much about these hitches, but will the wagon version still fit with that muffler on?
Originally posted by timmo View PostCareful, the PNs are different between sedan/coupe and wagon. Also don't forget the backing plate that goes in the trunk and sandwiches the rails as well, but that is something you could easily get waterjet and bent with sendcutsend
Do you know the model/part# of that Westfalia hitch? I want one for my 2001 LSB.
No kidding on the recovery, I believe you there!
I’m currently looking into the aluminum version of the Westfalia hitch, as it’s lighter and also has a bolt pattern for replacing the ball adapter with a hitch mount. I’d expect to drop another 40lb, all from above the roof, after accounting for the added hitch weight. Thanks Gt4 !
I'm currently looking into the aluminum version of the Westfalia hitch, as it's lighter and also has a bolt pattern for replacing the ball adapter with a hitch mount. I'd expect to drop another 40lb, all from above the roof, after accounting for the added hitch weight. Thanks Gt4 !
