We're trying to make this here: Onshape
I started with a scrap block of aluminum and cut it roughly to size:
Then migrated my way over to the Bridgeport to start taking shape. First removed a bunch of material to create a clevis:
Then flipped it over and drilled/power-tapped the hole pattern to mate to the euro tow bar (plus a test fit):
Then I flipped it on its side and drilled two 5/8" holes all the way through both sides of the clevis so that it can bolt directly to the adapter used in Stealth Hitch kits (same system we have on the Macan) like this:
After a quick deburr and clean, assembled it all together, threw it in the trunk of the jag and went home:
And that brings us to this morning, where things get exciting between coats of paint on the vincebar. I popped the bumper off, removed the standard mtech-2 bumper insert, trimmed a section of the bumper beam, removed the bumper shocks and installed the hitch. It fit like a glove with just enough room to comfortably actuate the hand lever of the Stealth Hitches adapter:
And here it is in all its glory, no additional trimming required, great placement, centered with plenty of driveway clearance:
And that's it for the hitch install! The factory setup was rated for over 4,000lb of towing capacity but only 165lb of tongue load. Not a problem for me since I'm planning to use this to hold two mountain bikes on a 1up rack, which will total about 120lbs. This 2" receiver is totally removable and can be detached and hidden in about 30 seconds.
It's worth noting that this is the factory BMW version of the hitch, made for BMW by Westfalia, and different from the Westfalia version available today because this one is aluminum and about half the weight. Of course I weighed everything, and after subtracting out the 8lb weight of the bumper shocks, I've added just 18lb to the rear of the car, vs 55+ of the roof rack setup. Once the rack comes off, I'll come in at ~3440lb and 49.4/50.6% weight distribution with a half tank, which is almost dead on for a stock e46 M3. Pleased with this outcome once again!
I'll drive the car tomorrow after a full 48 hours of epoxy curing, but for these two, no noticeable change is best.
