ugaexploder's 2004 SG/IR - 1st e46 M3
  • ugaexploder
    I've been working at a snail's pace just due to a combination of having to go out of town during the week for work, waiting on parts, and trying not to get too into the weeds with this car.
    I was able to source some amber tail lights, since I've seen some other members have some on their SG and it looks great. While I was waiting on parts to finish the exhaust system, I changed the front sway bar and end links, rear sway end links, new headlight level sensors front and back with new brackets or bushings.
  • ugaexploder
    When I went to take a look at how the clutch was wired, I noticed the wiring looked okay but the switch was unidentifable. No part number or anything, it just 20M Italy 314 on one side, and >PA66 GF30< on the other. Replaced it with the black 61-31-9-122-700 switch.
  • ugaexploder
    I thought the intermittent stalling issue was fixed with the new AC compressor since it was driving beautifully all the way home, then of course on the lip getting in to my garage...I stalled. I basically spent hours upon hours trying to figure out what the hell is going on and it dawned on me that a lot of these SMG-to-6spd conversions have the same issues. The problem is that most of this information is scattered across the internet, which can make it frustrating to put the pieces together.
    I noticed there were a couple different ways of wiring out to pin 20 on the DME and it was based on whether or not a gear identification switch (23-14-2-229-113) was installed during the conversion. I figured this would be the first thing I would tackle once on jack stands. I think it's all sorted out now, after making some changes to the .bin file, checking to make sure SMG was coded out, etc. There were definitely some speedbumps here and there, but so much of it is due to variations between models, where the information is coming from whether it's a stock car, or engine swap, and even more variables. I come from the electrical testing world, where you absolutely need to verify contractor work.
  • ugaexploder
    Got my car back from a local shop about 2 months ago to do the following work:
    Installed Redish V3 SF Plates
    Installed Practical R&D Vincebar
    ​Installed new diff
    Installed new driveshaft
    Changed all bushings/mounts (annoyed I didn't take care of the CV boots...)
    Installed Ohlins R&T
    Changed diff fluid
    Changed brake fluid
    Installed New AC Compressor
    Installed New Steering Rack
    Installed New Wheel Bearings
    Installed New Tie Rods
    Installed Beisan VANOS solenoid
    New Wheels and Tires
    ​The tech who turned the wrench did an awesome job. I felt like they could have done a better job at communicating...it was an expensive bill. Thankfully, the car is back in the garage so I can take over from here with the easy stuff.
  • ugaexploder
    Have a bunch of parts on order...I tend to try and finish projects as fast as I can which isn't great for my wallet or other hobbies. While I'm waiting for parts, here are a few things I did just to pass the time.
    I know it's not much but I have some nice things coming in the future. My first priority is to take care of the subframe. The bump stop in the rear looks pretty bad so I decided the first thing I would do along with SF reinforcement would be of course changing out bushings and mounts, but also going to tackle suspension...which may "bleed" into wheel/tires...which will then "bleed" into brakes. It's all just money and time I guess.
    Traded a local fellow enthusiast for his 18" style 67's. May end up trying to save some money and acquire a couple more rear wheels to go square setup on factory 67's. Not sure...need to consult some of the local guys who know way more about setups to make a decision.
    Click image for larger version  Name:	rear quarter 18.jpg Views:	0 Size:	174.4 KB ID:	224115
    Click image for larger version  Name:	front quarter 18.jpg Views:	0 Size:	167.7 KB ID:	224116
    Looks like the side grills are some aftermarket ones...well, the logos had faded and bubbled pretty bad so I replaced those.
    Click image for larger version  Name:	new side emblem.jpg Views:	0 Size:	60.2 KB ID:	224117
    Car didn't have any floor mats so ordered some new ones from weathertech. I've always like their floorliners.
    Click image for larger version  Name:	driver interior.jpg Views:	0 Size:	125.0 KB ID:	224118
  • ugaexploder
    Some pictures that were shared to me from previous owner of the engine rebuild. I think he did a great job, and the motor runs awesome. It did throw a code when I was there and he mentioned that I would need to change the VANOS solenoid soon. Have one on order from Beisan and it looks like a simple process. Car actually cut off on me a few times so I turned the AC off and it ran without issues.
Name:	engine rebuild_1.jpg
Name:	engine rebuild_2.jpg
Name:	engine rebuild_5.jpg
Name:	engine rebuild_11.jpg
Name:	engine rebuild_4.jpg
Name:	engine rebuild_6.jpg
Name:	engine rebuild_7.jpg
Name:	engine rebuild_8.jpg
Name:	engine rebuild_10.jpg
Name:	engine rebuild_3.jpg
Name:	engine rebuild_9.jpg
Name:	engine rebuild_12.jpg
  • ugaexploder
    started a topic ugaexploder's 2004 SG/IR - 1st e46 M3
    First time e46 m3 owner here. Main goal for me is to restore the car with focus on handling and reliability.
    Just picked up the car a couple weeks on 6/24/23 fairly local from a fellow enthusiast. The car has 164k on the clock, and engine was rebuilt around 156k by previous owner. Below is a list of things from the previous owner that had been done under his ownership.
    Engine:
    Water pump & thermostat - Borg Warner
    Rear main, oil pan gasket, valve cover gasket, timing chain guides, misc. gaskets and seals, pulleys, oil filter housing gasket, CPV O-ring
    NGK Spark Plugs
    Delphi Coil packs
    Fuel injectors clean/flow-matched
    Engine Rebuild:
    BLOCK:
    OEM Piston Rings
    OEM/Glyco Main bearings
    ARP Main Studs
    ARP Rod Bolts
    VAC Coated Road Bearings
    Cylinder Hone
    New Engine Wiring Harness
    HEAD:
    VANOS Rebuild (Biesan)
    Valve Stem Seals
    OEM Head Gasket Kit
    ARP Head Studs
    Valve lash adjustment (wiseco shim kit)
    Timing Guides/tensioner/gaskets
    Valve job, valve stem seals, deck milling
    Transmission:
    SMG-to-6spd manual conversion with Lang Racing bell housing modification
    Transmission input shaft seal
    OEM shifter assembly
    OEM shift boot and knob
    OEM pedal assembly and hydraulics
    UUC Trans mount
    Coding/tuning done by Solo Motorsports
    Brakes:
    StopTech Slotted Front Rotors w/ Sport Pads
    StopTech Rear Rotors w/ Street Pads
    Bimmerworld SS brake lines
    Pentosin DOT 4 fluid
    General Maintenance:
    Complete AC system O-ring replacement
    AC receiver/drier and recharge
    Fuel system cleaned, fuel filter
    OE pressure regulator
    OEM dipstick and fuel cap
    Window seals and windshield cowl
    Oil changes with Redline 10w60 & Mann filters
    Interstate AGM Battery
    OEM radiator
    OEM throttle pedal (manual)
    OEM voltage regulator
    OEM fuel pump
    Bosch Alternator
    Bosch power steering pump
    OEM diff bushings with OEM diff cover
    Diff fluid service with new drain/fill plugs
    Day 1
    First day, made it home on a roughly 2 hour drive back.
    Click image for larger version  Name:	front quarter 19.jpg Views:	0 Size:	168.8 KB ID:	224098
    Click image for larger version  Name:	rear.jpg Views:	0 Size:	86.7 KB ID:	224099
