Cockroach Individual M3 4/1 Drivers Window Replacement
  • bigjae46
    I just looked it up. A 245/40R18 A052 is $336, a 255/40R17 is $301. That is $140 per set of tires. You get a 100% payback on Fattycharged's wheels after 8 sets of tires. 2-3 years? As much as putting a car on track will ever make financial sense...this is one case that makes total sense if you have a limited tire budget.
    Keep a set of 18s so you can run 18s when you get a good deal on a set of used tires.
  • fattycharged
    I know a local someone with an extra set of new in box Arc-8's in a 17x9.5… $1100 keeps me from sending them back to APEX for a return… 😂
  • bigjae46
    Originally posted by samthejam View Post
    You're good. I know how it goes!
    I just have a lot of 18" wheels, what I ended up with.
    George Hill does have some 17" SSRs... . I think also the selection in 17s, I only looked at 275s and the selection wasn't that great. However on the 255s that would open up quite a few options... hmm.
    I also really enjoy how the car felt on the 265/35R18. The lower sidewall also had some clearance benefits. It is expensive to get all those things I like about the 265s though.
    I was also betting on my used tire guy having a decent supply of 245 A052s to get me through the year. Doesn't look so
    If you go with a 17x9.5 et35 wheel then you can go between a 255 and 275. Lots of 255/40R17s. Even in the 275/40R17s - Falken RT660s, NT01s, and Hoosier RCES are all reasonable.
    Not a fan of the 660s but $1100 a set makes it bearable. I got 26 sessions which is impressive consider the amount of understeer I dealt with. My car likes to overheat the front tires so partly a setup related issue.
  • samthejam
    Nice! Why don't you run 17s? The tire bill is much lower. Falken 660s in 275/40R17 are $276 per tire. You can even run 255/40R17s although they may be a little stretched on a 10" wheel. The only bad thing about 17x10s is you can run apex wheels or...apex wheels. More options in a 17x9.5...more streetable too.
    Sorry I didn't stop back by at the track...I was screwing with my car until 6pm. At that point I just wanted to go home.
  • bigjae46
  • samthejam
    New PB at my local track, still on those used 245 A052s. They gave up the ghost a session after this one.
    Biggest slip and slide bloopers from that.
    You can roast 3rd gear with 200tws!
    How much track out? All of it
    As of this post still driving to work on this tire.
    Unsure what tires to order next, I still have those ECFs that are bricks if it comes to it.
    I also got the bumper securely mounted and both side plastics in.
    Definitely wearing out rears before fronts on this car on track, however the fronts are pretty dead too.
    The 245s are so fun to drive on, but you can tell they're combined loading struggles. However it's a blast. They also just can't wick away the heat for how I drive and the weight. These yokos arent known for liking that anyways, but from my E28 experience these feel too small. Compound is doing all the work until it gets too hot.
  • discoelk
    getting kinda burnt out tho
    So real with an E46M. I don't remember my ZHP street/track car being as needy.
  • Loopyspec
    The CSL bumper looks great! i wish i was more mechanically inclined as you are. I know I can do a lot, but I lack the confidence when it comes to engine work (rod bearings, vanos), which is the pricier of maintenance items.
  • samthejam
  • samthejam
    I had to buy a new passenger side lower inner fender liner. There were no used ones on Ebay. I have a left one from Jay, and that center rad ducting I will repair. It just needs that divider from the one that has already somehow got smashed up on my car. I really should get that new but I have this one for right now.
    Also getting non, washing headlight trim pieces. New hood trim for the windshield sprayers, and got a used front grill to cut up to make it fit the CSL rep bumper. Also ordered all the screws and clips. Bumper will basically just be a cover that fits over the kevlar thing. I will have it so it can be removed without jack and only turning the wheels for servicability.
    I will not be converting to 2001 alu support or fixing the washer bottle reservoir on this go around.
  • samthejam
    CSL Bumper project has begun. Someone had one for $250, it didn't come with the carbon splitters or the grille. Which will be its own problem that I will work through.
  • samthejam
    Just need to fix the roof or replace with a carbon roof. I'll trade a carbon roof for your slicktop headliner...just saying...
    I need a slicktop headliner if I delete sunroof or go carbon roof
  • bigjae46
  • samthejam
    The roof will probably just get wipe on clearcoat. I want to try that stuff, another friend used that on a Suburban with good success.
  • samthejam
    We were up until 4am working on the hood last night. Just need to order a bumper and headlight bezels now and spray them. Very very very happy for a driveway paintjob. I have seen worse Maacos
    The car has had a rep non-m sedan(?) bumper since I have owned it so will be glad to see that go.
    Lessons learned dont use a cheap spray gun for the clearcoat or at all. When wetsanding down any crimes on the clearcoat, never go down to 1000. Theres a lot of microscratches we spent forever trying to get out. We had a fancy sonax cutting compound that said it would go to 1000 it did for the most part. They probably won't ever come out but it's more than good enough for me.
