2003 E46 M3 - Steel Grey Slicktop
    Starting a thread to log my build
    2003 M3 - Steel Grey, Slicktop, Impulse Cloth
    came with 118k on the odo
    First things first, swapped out the warped A pillars. Car spent most of its life in CA and NV
      Got some orange corners
        Looking forward to following the build !
          Nice fellow slicktop and impulse cloth owner as well
            Installed Falk MFG USB panel along with a new console + flap as they were pretty scratched up
              Topped off PS fluid while installing Eventuri intake
                Valve adjustment @ 119k mi, though prev owner took care of valve adjustment less than 5k miles ago, found 4 shims out of spec.
                Cleaned out valve cover
                Replaced CPV o-ring with viton o-ring
                  Installed MCS 1WNR + Ground Control front sway bar @ 119,500 mi
                  Some installation notes:
                  - Front strut assembly order: small collar, larger collar with spring perch, spring, helper spring perch, helper spring, stepped spacer, camber plate, stepped spacer, 3 supplied washers, two jam nuts
                  - GC sway bar collars will sit about 1/4in above control arm at full droop
                  - No dust boot for rear struts... wonder if intentional
                  - Counted about 19 threads (exposed threads under the height adj lock collar) to achieve 1 finger gap in front.​
                  Throwout bearing decided to go on fritz after test drive... 🤦🏻‍♂️ the gift that keeps on giving
                  Next up - to the alignment shop.
                  Click image for larger version  Name:	IMG_4530.jpg Views:	0 Size:	126.3 KB ID:	310361 Click image for larger version  Name:	IMG_4570.jpg Views:	0 Size:	62.3 KB ID:	310360 Click image for larger version
ID:	310369 Click image for larger version
                    - Motorsport Hardware studs + tuner nuts
                    - Volk 21a - 18x9.5 ET22 - square setup
                    - Wrapped in Yokohama NEOVA AD09 265/35/18
ID:	310363 Click image for larger version
ID:	310366 Click image for larger version
ID:	310364 Click image for larger version
                      Few more beauty shots from today
                        How could I forget ... Recaro ABE + PCI rails. Sits a bit offset to the left, but got used to it rather quickly. Car is starting to feel dialed in.
                        Click image for larger version  Name:	IMG_4257.jpg Views:	0 Size:	107.4 KB ID:	310492 Click image for larger version  Name:	IMG_4260.jpg Views:	0 Size:	131.1 KB ID:	310493 Click image for larger version
                          Something very comforting about these amber lights at night
                            A little out of order... short console + new ebrake (courtesy of prev owner 🙏)
ID:	310501 Click image for larger version
ID:	310502 Click image for larger version
ID:	310503 Click image for larger version
ID:	310504 Click image for larger version
ID:	310500 Click image for larger version
