Zen and the Art of E46 M3 Ownership
    Got the front end suspension stuff all done this past weekend. Put the old rotors and wheels on (no calipers), and dropped it back on the ground immediately after installing the CABs.
    When thinking about my suspension set up before I went shopping, Iike I mentioned before, my goal was to achieve the CSL feel as much as possible. I used the FCM Ride Harmony spreadsheet to make the best effort in doing so. I wanted more street oriented coilover kit, as my assumption is that the CSL suspension also leaned a good bit towards being street friendly. While my intent was to use the CSL sway bars front and rear, realizing that the front spring rates of the PSS10's were going to be stiffer than stock I ended up going with a smaller front bar. Funny enough, the Bimmerworld bar fits that bill really well. It's less than a mm smaller than the CSL bar and it's also hollow, with some adjustability to boot.
    PSS10 Spring Rates: 250# F / 450# R (under some compression)
    Front Sway - 30mm hollow - Bimmerworld
    Rear Sway - 22.5mm CSL
    CSL Kingpins​
    I realize that the springs are progressive and that the rates here are an estimate. The front bar wall thickness is an estimate as well. For now this is where I am at. If the want/need is there, custom linear springs would make all of this a certainty.
    Moving on, I stripped the calipers and sent them to Renewed Finishes here in PA to get powder coated black. Looks like someone took a rattle can to em at some point.
    Now just waiting for all the brake stuff, and the front end will be done done. In the meantime, I'll focus on the O2 wiring and carbon airbox install.
    2006 E46 M3 Interlagos Blue ZCP Slicktop CS+
      So good.
      đŸ”¹ 2001 M3 Laguna Seca Blue
      Instagram: link
      Build thread: link
        So good.
        Love new parts! haha
          Got some pics from Renewed Finished. The calipers are all done. Also the exterior bit of the pistons got cerikoted.
          In the meantime, I got all the O2 wiring stuff taken care of and the airbox installed. Euro headers, Euro section 1, and carbon airbox are all done! Will need to get a tune by the time I get the rear end done and back on the road.
            Now I just need the calipers back. I decided on running 7.5mm spacers up front. This pushes the face of the wheel within 1.5mm of where the CSL fronts sit, and adds +4.5mm to the scrub radius vs the CSL. Fingers crossed the new scrub radius is minor in effect.
              Your scrub radius will be vastly better than most folks on this forum, and your steering feel will thank you. I expect you'll be fine - I'd personally cap my offset limits at ~et40 which is roughly where you're at.
              Also, I think that airbox is designed specifically to not need a tune - what makes you think that you need one? I'd leave it as is.
              If you're up for getting the springs measured - it would be great to have real numbers for those and not just guesstimates from a few shops. As you're looking to dial the suspension in, keep in mind that your FRC couple will be relative to ride height. If you target CSL ride height, 70.5% is pretty good. I run stock M3 ride height and prefer ~69% even with square tires. If you want lower than CSL, you may want to push it a bit above CSL FRC. This is driven mostly by changes to front suspension geometry as small ride height changes make pretty big roll center changes. Not so much in the rear.
              If you're an NVH hawk like I am, the CSL front sway bar bushings should work fine with that bimmerworld 30.2mm front sway bar. I did this with my old hotchkis bar when I ran that. I'm on a cabrio front bar/CSL rear bar now.
              Beautiful car and hardware
                Thank you for the insight. It is super helpful!
                On the tune: B/c I have euro headers and euro cats, you mentioned before that I would need to convert over to the stock euro tune. I know I should be fine with that, but a part of me figures that maybe there is something to gain from taking it a step further. I was hoping that an HTE tune might yield a bit more power (I don't care about power but if possible to inch a little closer to CSL territory I'll take it), and perhaps a slightly better dynamic. For sure I am open to input here, and something I can take into account.
                Unfortunately with the springs, since the fronts are already on the car I don't think I am going to get them measured. At least not at the moment. My thinking is to see how the car behaves on the road once it's all set up. If I ever did want to be a bit OCD about it, I might just have custom springs made. And then I can have the Bilstein's measured. To be honest, I suspect that I will be pleased with the setup as is though. Might be something for the future if I want to tinker.
                As far as ride height, good call on the FRC. The CSL ride height is supposedly 607mm/602mm F/R +-10mm. That's as low as I want to go. I am inclined to leave the height as pre-set from Bilstein, which I measured just now as 604mm(FR) and 611mm(FL). The rear still needs to be installed, and I am sure it will settle further, and then there is also corner balancing. But overall, it's kind of on point for me out of the box.
                  Are you measuring the ride height from the ground to the edge of the fender or the bottom of the wheel to the edge of the fender? I am just going to do from center of wheel to the edge of the fender 13.5'/13'.
                  I read somewhere, probably while searching via AI that Bilstein recommends 13.5/13.25 for the ride height as the optimum due to the internal bump stops on the PSS10.
                  My PSS10's finaly got delivered yesterday and plan is to install the wth TMS camber plates and rear MEYLE HD mounts. Already have Eibach Sways. Will also install CSL Kingpins with new wheel bearings in the front at least.
                    I am measuring from the bottom of the wheel to the edge of the fender. If AI is right, the .25" difference F to R for PSS10 is ideal for CSL height stagger. I have actually already installed the rear and dropped the car down to see where bilstein pre-set these things.
                    Unfortunately, I think the subframe reinforcement plates in the rear (with the OE subframe bushings) are throwing off the rear height. Here is how the car sits with the PSS10's installed with bilstein's pre-sets (also took measurements from the center of the wheel to the fender edge):
                    FL - 604mm - 13 3/4"
                    FR - 607mm - 13 7/8"
                    RL - 620mm - 14 7/16"
                    RR - 628mm - 14 7/8"
                    Maxing out the drop on the rear springs, lowers the rear to like 603mm and 598mm. Looks like CSL spec is about as low as I can go in my situation with the PSS10's. So for my purposes at least, that is rather convenient haha.
                    At the rate you are going you might know how the PSS10's feel before I do. I have the rear about done, just need to install the refreshed rear brakes, mess with the front toe so I can drive it to the shop, and find a shop that can do the alignment/corner balance. If I am being honest, probably another 2 or 3 weeks before it's done. It looks like I am going to finish this initial phase of the "I don't want another project" project (fml) right at the 12 month mark of ownership. haha
                      A few pictures of the rear end work. Finally had enough room on the table for just the rear end parts.
                      A long time ago I decided that if I was saving money by doing the work myself, I would always buy the right tools for the job. The headache is not worth trying to save a little bit of money.
                      Overall, rear wheel bearings weren't that terrible to do. Lots of stuff needed to come out, so a bit tedious as a result.
                      Towel method is the way to go with the sliding hammer!
                        That is awesome info! Thank you.
                        I think i have my heart stuck on the 13.5/13 height as it looks perfect and also i went up from 12" a year or two back and im just happy LOL.
                        I will not be installing any of the stuff as after speaking to the techs too much is going on right now so i'll do it when i am back from my trip in November. Plus the weather should be nice as its really Shite now 31-42c high humidity.
                          Amazing build! Excited to keep reading
                            Brakes are all done. Rear end is all done. Just got to re-align this muffler, and the car can be put back on the ground.
                            Rear Girodisc rotors weigh 12.6 lbs each on a bathroom scale. So a full ZCP Girodisc setup will save about 7 lbs in rotational mass.
                            For those that may not know, turns out you need to modify the pads a few mm's in order to avoid hitting the hardware on the Girodisc rear rotors. Girodisc will perform this service for you on their CNC with the purchase of the rotors.
                              They do exist!! No cutting needed if you run 996 calipers though right? That’s a solid weight drop, even if they otherwise had the same braking performance.
                                Haha. Yeah just have to email/call to verify availability and order. With the pads, it sounds like this may be an issue with the stock pads mostly but regardless they'll want to confirm with the purchaser the exact pad being run. B/c of the e-brake, it sounds like things are just pretty tight down there with a fully floating rotor.
                                The reduced weight should have a positive increase in braking performance, plus the GG rated pads. I would be curious to see if it's even quantifiable though. Maybe next spring when I get summer tires on I'll get a draggy or something.
