I heard Last Friday that my crank is ready. Will pick it up tomorrow morning. Given I'll most likely be getting new pistons, I separated.the old pistons and rods. I also checked the rod that had the failed bearing in it. The bearings didn't spin and the rod big end surface felt smooth, but it was definitely shinier then the others. Inserting a bore guage all 5 rods are within 0.01mm of each other, but the one with the failed bearing measures 0.07mm larger. This is just with the rod bolts snug with a wrench, but not torqued. Will repeat with them properly torqued, but so far doesn't look great just comparing against each other.
Since I'm getting closer to being able to start actually assembling things again I went ahead and ordered most of the parts I'll need to start building the engine as well as the remaining parts I needed for the SMG to manual conversion.
