Obioban's 2005 IR/IR Coupe
  • 0-60motorsports
    Oops, read that too quickly.
    Yes, this still uses the OE cabin filter element.
    Oh That's great! Thanks.
    Now if Sloan are going to make the cabin filter housing using the same technique for people who do not want to go for their full strutbar kit.....
  • Obioban
    No I meant the actual FILTER element
  • 0-60motorsports
    Ha. I'll probably be selling it after this is installed.
  • Obioban
    Still using the OE Cabin filter element?
  • nyc951
    Correct.
    ​​​​​​…. Are the pics working?
    Pics are working - just wanted to confirm
  • 0-60motorsports
    Correct.
  • Obioban
    Originally posted by nyc951 View Post
    Obioban
    When you say “The cabin air filter housing needs to be replaced to create the clearance for the brace to fit”, does that mean SLON provides a modified air cabin filter box with this kit?
    Correct.
  • nyc951
    Obioban
  • 0-60motorsports
    Very Nice! Love it. I wonder if SLON can make the cabin air filter housing for those of us that do not want to use their strut bar.
  • Surge709
    Looked like such a nice piece of work! So much want! Let us know how install goes this weekend.
  • Obioban
    ​ Back story:
    SLON has made a front strut tower brace that triangulates loads to the firewall (as BMW has done on newer cars). The result of this is an 18-20% (depending on other mods and chassis condition) torsional rigidity increase (as actually measured on a chassis twister). More torsional rigidity is only better-- better handling, better ride quality, better grip, better NHV. In terms of making your car better, it's right up there with reducing weight. Speaking of reducing weight, this is also 5.5 lbs lighter than stock, on the front end of the car (where it's hard to remove weight).
    This is how it assembles, so the part pictures make sense. The portion behind the cabin air filter housing is structural epoxied to the firewall. The cabin air filter housing needs to be replaced to create the clearance for the brace to fit:
    Click image for larger version  Name:	IMG_5139.jpg Views:	1 Size:	45.2 KB ID:	230021
    These parts are like nothing I have seen in the aftermarket space, or professionally (I'm a product design engineer, in an automotive adjacent space). I hesitate to say it, because it sounds absurd, but they feel like I imagine F1 parts would feel. Super light, super stiff, super precise.
    They're also some of the best packaged parts I've received. Every significant part has it's own custom cut foam hole, so they can't damage each other. They'd have to come by a truly inept shipping company for any hard to come to them.
    Everything is absurdly rigid, all the alu parts are pocketed and ribbed, for weight and structure, and the CF looks perfect. Oh, and the cork filled carbon firewall plug is just next level (more on that)
    Pics:
    Click image for larger version  Name:	IMG_4605.jpg Views:	3 Size:	204.1 KB ID:	230168Click image for larger version  Name:	IMG_4606.jpg Views:	2 Size:	290.1 KB ID:	230169Click image for larger version  Name:	IMG_4607.jpg Views:	2 Size:	298.8 KB ID:	230170Click image for larger version  Name:	IMG_4608.jpg Views:	2 Size:	101.4 KB ID:	230171Click image for larger version  Name:	IMG_4609.jpg Views:	2 Size:	115.4 KB ID:	230172Click image for larger version  Name:	IMG_4610.jpg Views:	2 Size:	283.0 KB ID:	230173Click image for larger version  Name:	IMG_4611.jpg Views:	2 Size:	286.8 KB ID:	230174Click image for larger version  Name:	IMG_4612.jpg Views:	2 Size:	404.4 KB ID:	230175Click image for larger version  Name:	IMG_4613.jpg Views:	2 Size:	401.1 KB ID:	230176​​
    Click image for larger version  Name:	PNG image.png Views:	1 Size:	969.3 KB ID:	230022
    ^accurate mold, can still see the BMW stamp
    Click image for larger version  Name:	IMG_4615.jpg Views:	2 Size:	371.1 KB ID:	230178Click image for larger version  Name:	IMG_4616.jpg Views:	2 Size:	397.5 KB ID:	230179
    Click image for larger version  Name:	IMG_4614.jpg Views:	2 Size:	436.0 KB ID:	230180
    This last part may be the most interesting of them all. The original version was pure carbon. A Space-X engineer, that's also a member on here (who I don't want to out-- he can self identify if he chooses), bought one of these of that version, and suggested it would be a more effective thermal barrier if it was sandwiched cork, as they do rockets. SLON tested that out, and the results were as below:
    ^stock vs carbon vs carbon/cork/carbon
    So, that got integrated into the design (and the member who suggested it received the updated version).
    Amusingly for me, that probably means I'll get a comfort upgrade out of this-- I have been running the (NLA) CSL cabin air filter housing for a decade now, and it's lighter but same material as stock-- so presumably it's just thinner, and a worse thermal barrier as a result.
    So, yeah. Consider this the most gushing post I have ever written. As I said back when we had the SLON rear wall group buy, they're making the parts that I have wanted for this chassis for a decade+, that nobody was willing to do.
    Hoping to have time to install it this weekend, so more to follow...
    Not my car, but this is how it should look when done:
    Click image for larger version  Name:	2.png Views:	1 Size:	973.6 KB ID:	230023 Click image for larger version  Name:	3.png Views:	1 Size:	942.4 KB ID:	230024
    No affiliation (though I've never heard anyone say anything bad about IND), but it appears IND has one in stock, if you want one and don't want to wait:
    https://ind-distribution.com/product...5727c149&_ss=r​​
  • Obioban
    Oh cool! That's a pretty great spec. Mine is a no option car except for auto and iDrive (both things that my GF insisted on ). If we weren't so far apart, it would be interesting to see how the two compare weight wise.
    I tried looking for the valvetronic thing and can't find it for some reason. tlow98 was who originally told me about it
    My brothers old 128i, speced the same as mine other than slick top, with non run flat tires was 3050 lbs.
  • tlow98
    Love the n51/52 motors. Great power package for the weight and balance of those cars. Congrats!
    MILV - modified intake lift valve is the mod ppl are doing. It definitely falls into “diminishing returns” category, but does add up once you’re at the end of the regular flow mods.
    Take a look in here: https://www.e90post.com/forums/showt...1329840&page=3
    awesome price Obioban. I’d have definitely picked it up for that price. Nicely optioned, nice color. No brainer!
  • heinzboehmer
    Single hump. The car is actually optioned exactly how I would have done myself other than having a sunroof.
    I had a 335i cluster in my wife's e91 for just that reason!
    Never heard of the valvetronic mod-- will look into that.
  • Obioban
    Nice, they're fun little cars. Been having fun modding mine in a different way to the M3. Very different experience when you're modding for convenience vs performance.
    Single hump or double hump? Mine has iDrive and have been running the bimmertech MMI for carplay/android auto. Works and integrates with the BMW stuff great.
    Get yourself a 135i cluster. It's exactly the same as the 128i cluster, except it has an oil temp gauge. They're cheap on eBay too. Just make sure it's lower mileage than the one in your car to avoid the hassle of desoldering the EEPROM. I've got the chip programmer if you want to ship stuff to me, but might be easier to just buy and do it yourself.
    Also, look for part outs in California. All 128i sold here were N51 cars, so they all came with the 3 stage manifold.
    There's also some popular mod to the valvetronic variable lift system, but can't remember the name of it right now...
