Sharocks 2004 CB/Cinn 6MT Build Journal
    Hi all,
    Been in the crowd for quite some time. Have had a lot of ups and downs with my current car but still enjoy it sometimes maybe.
    Mostly a placeholder for now. I have to find photos to try and document it the best I can during Rona Days.
    Specs:
    2004
    Carbon Black
    Cinnamon
    6MT
    Premium Package
    Cold Weather Package
    Brushed Aluminum Trim
    Sunroof
    Lifetime Sirius
    1 Owner (bought her from the original owner)
    Dinan Stage 3 (Basically everything but the blower)
    Build List (Current as of 01/25/2022):
    Engine:
    Motorsport CSL Intake
    Dinan TBs
    Schrick Cams 288/280
    Schrick DLC Coated Rocker Arms
    SuperTech Titanium Valve Springs
    Stage 3 Ported Head
    ARP 2000 Head Studs
    OE Head Gasket
    HTE Alpha N Dyno Tune
    Exhaust:
    SSV1 Headers
    SS Oversized Section 1 with Vibrant 2.5" Ultra Quiet Resonators Welded In
    SS Oversized Un-Resonated Section 2
    MXP Mevius Titanium Prototype Race Exhaust with HPF 3.5" adjustable slash cut Titanium tips
    Driveline:
    Fan Clutch Delete
    Bimmerworld Group N Track Motor Mounts
    Rogue Engineering Transmission Mounts
    AutoSolutions Custom 45% Ultimate SSK
    Dinan Hi-Clamp Clutch Kit
    CDV Delete
    AKG 95A Differential Bushings
    AKG 95A Subframe Bushings
    Custom Diffsonline Dinan 3.91 Triple Clutch Differential with 30/70 Ramps
    Suspension:
    TCK D/A Coilovers
    Hyperco 500/550 Springs
    Vorshlag Camber Plates
    TCK Monoball RSM
    H&R Adjustable Front Swaybar (set to medium)
    OE FCABs
    Rogue Engineering Track RTABs
    Custom Alignment (-3.5/-2.5 Camber, 0 Toe F/R)
    Corner Balanced (3250 lbs with 1/4 tank without me in it)
    Brakes:
    Brembo GTR 4 Piston BBK
    Brembo Type V Rotors
    Raybestos ST43 Pads/StopTech Street Pads
    Centric Blank Rear Rotors
    Exterior:
    OE Euro Front Bumper
    Custom 1x1 CF Fog Light Covers
    Frozen Gray Side Mirrors
    Vorsteiner Double Sided 1x1 CF CSL Trunk
    Vorsteiner 1x1 CF GTS3 Diffuser
    Sharkfin Delete
    Dinan Badge
    Interior:
    Custom Tainik Thickened 12 O'Clock Cinnamon Striped Steering Wheel
    OE BMW Individual Cinnamon Shift Boot
    OE BMW Individual Cinnamon E-Brake Boot
    OE BMW Individual Cinnamon Armrest
    OE Eurotray
    Dinan Plush Floormats
    E83 X3 Rearview Mirror with Compass and Homelink
    3M Griptaped Pedals
    OE E9X M3 Illuminated Shift Knob
    Grom BM53 Bluetooth adapter
    Lighting:
    Osram Nightbreaker 5k D2S Bulbs
    Invisibulb Corner Lights
    OE Side Markers
    LED Trunk Plate Lights
    Wheels:
    OE CSL Square Rear with Michelin PS2's 265/35/19
    Forgeline ZX3R Square 17x10 ET38 with Toyo R888R's 255/40/17 (Track)
    Macht Schnell 90mm Wheel Stud Kit
    Maintenance
    Full Beisans Vanos Rebuild
    Reddish Motorsport Subframe Reinforcement
    WPC Coated Rod Bearings with ARP Hardware
    Blackstone Oil Analysis (every oil change)
    Oil Changes with Castrol Supercar 10W60
    OE Coolant Flush
    OE Transmission Flush
    OE Differential Flush
    OE Oil Temp Sensor
    OE Evap Hose
    OE Coolant Return Line
    OE Headlight Ballasts
    OE Headlight Level Sensor
    Dinan Intake Filter
    OE Cabin Air Filter
    OE Fuel Filter
    OE Rear Brake Linings
    OE F/R Fender Liners
    Misc:
    Car made 355 whp/252 ft/lbs on a Mustang Dyno and 362 whp/265 ft/lbs on a DynoJet
    Redline is 8500
    After going to a CSL intake, Alpha N tune from HTE Tuning, SSV1's with the Oversized Sec 1 and 2 the car made:
    350 whp/260 ft/lbs on a Mustang Dyno. Redline is also decreased to 8250. More on this later.
    Some pics (I will chronologically add them later):
    Click image for larger version  Name:	35548093_1735408739900100_562551865787547648_o.jpg Views:	0 Size:	257.1 KB ID:	5876
    Cars and Coffee Larz Anderson Car Museum BMW CCA Day August of 2018
    Click image for larger version  Name:	37969517_1795896837184623_2364856731739095040_o.jpg Views:	0 Size:	135.7 KB ID:	5877 Click image for larger version  Name:	37919989_1795897040517936_1636690115268968448_o.jpg Views:	0 Size:	230.0 KB ID:	5878
    Friend from NYC is a CCC (Classic Car Club of Manhattan) Member, brought up their track spec E30 M3 for the weekend to Boston
    Click image for larger version  Name:	62202856_2260959437345025_2839152053295513600_o.jpg Views:	0 Size:	75.7 KB ID:	5879 Click image for larger version  Name:	64868151_2269601726480796_1642985223064911872_o.jpg Views:	0 Size:	217.5 KB ID:	5880
    Going to one of the only shops in Boston I trust, Eurotech Motorsports in Natick, MA. Farley tracks an E46 M3 and a 997.2 GT3. Still has the M3!
    Click image for larger version  Name:	40694434_1854438804663759_1894021324167184384_o.jpg Views:	0 Size:	154.8 KB ID:	5881
    What the car mostly looks like when it's out and about. I hate cleaning cars so Carbon Black and I do not get along. Car is Opticoat Pro'd currently. It seems to work. Wheels are ceramic coated but the Brembos + Raybestos pads DO NOT CARE.
    Still looking around for photos. Will link some videos. For now, my Instagram link is in my sig.
    2005 BMW ///M3
    โ€‹ Interlagos Blue/Black 6MT Dinan S3-R+
    2008 BMW ///M3 Alpine White/Bamboo/6MT Track Build โ€‹โ€‹
    Black6MT Daily
    This is copied over from Bimmerpost but you get the gist.
    Bought on 04/27/13
    When I first saw her:
    Driving back home, stopped in CT for Redbull:
    Hit 155k on the way in PA:
    Thought this was funny for some reason (was delirious after 13 hours of driving):
    Some background info on the car:
    I bought this car from the original owner who had it dealer serviced, at the same dealership he ordered it from, for it's entire life. From 2004-2013! Stacks of maintenance records, and after a 3 hour PPI, compression, leak down, and suspension bushings/subframe checks it passed with flying colors.
    Now the main part, I bought this car at 154,785 miles, all highway as it has no paint defects other than stone chips. Since it had such "high" mileage it was initially a turn off, but I figured I'd give her a go, with a PPI. Turns out this high milage E46 M3 was the best E46 M3 in overall condition/performance/maintenance history/and general honesty I had come across over my 4 years of searching for one. Then, I bought her.
    I usually have a knack for finding cars way out of state and extremely far away, fortunately, my parents are in the travel business and are extremely/annoyingly spontaneous folk and will never say no to a trip even if they are pointless and I don't come back with a car. This trip was different however, I always went with my dad, but my mom wanted to go for one. So off we went to Pittsburgh to pick up the car. Landing in Pittsburgh, saw the car all pretty and got a ride in a GT3 RS with full GMG exhaust, OEM Rollbar, Tune etc. I have a video, I will upload it later.
    Picked up the car, paid the money, said my thanks and drove 13 hours straight back to Boston. Best drive ever. Car did not give me any issues other than it going through gas extremely quickly for an I6.
    I look forward to using it properly.
    Factory Specs
    2004
    Carbon Black
    Cinnamon (Heated/Powered/Lumbar Seats)
    6 Speed
    Moonroof
    Bi-Xenons
    HK Sound
    Exterior
    Painted Reflectors
    Macht Schnell 90mm stud kit
    Turner Motorsports 17.5mm/Macht Schnell 10mm Spacers F/R
    3M Clear Bra
    Sharkfin Delete
    Interior
    OEM BMW Motorsport Golf Ball Shift Knob
    OEM F10 M5 Illuminated ZHP Shift Knob Boot
    AC Schnitzer Pedals
    DIY Clutch Stop
    OEM Euro Long Console
    Aux Input
    WeatherTech Floormats
    Engine/Driveline
    Dinan Intake
    Dinan MAF
    Dinan Throttle Bodies
    Dinan 545i Modified SSK
    Dinan 3.91 LSD
    Dinan Stage 4 Tune
    Bimmerworld Silicone Intake Boot
    Exhaust
    JVT-R Ceramic Coated Headers
    OEM Section 1
    OEM Section 2
    Mevius Exhaust
    Suspension/Brakes/Wheels
    TCK D/A 450/550
    TCK Camber Plates
    TCK Monoball RSM's
    PFC 01 Pads F/R
    OEM ZCPs with Michelin PS2s 245/35/19 and 285/30/19
    Alignment Specs
    Corner-balanced
    Right height set to 13.5 F/R with a driver and half a tank of gas
    Running medium stiffness/medium compression
    Camber: -2.75F / -1.8R
    Toe: 1/8F / 1/16R
    Caster: Set as far back as possible
    So a quick update! I bought a foam gun off a fellow forum member, he was very easy to spot in public
    Dakar Yellow!
    It was in mint shape too! OEM+
    Now the biggest news of the last 10 minutes!
    I was picking up some stuff for my mom, and 30 seconds away from my house I see an AW M3 coupe. I think nothing of it since I've seen it around my town parked. This time I get to see the interior in some light and it looked interesting so I parked next to it for about 30 secs. It turns out to be an AW/Imola/SMG and an 04+. The best/worst part of this whole ordeal is the muffler he had on the car.
    I saw Ti tips and I assumed RE El Diablo or an AP, Megan or w/e. Lesson learned: Never Assume.
    I left him/her a note on his/her windshield, this person lives 30 seconds away from my house!
    Ohh and I installed the F10 M5 ZHP knob, install was a breeze, I used rubber cement to glue the boot to the E46 shift boot frame. I'll take some lighted pics at night.
    PS. If said forum member has an issue with the pics, please PM me, I'll remove them no problem!
    Nice picture taken by a good friend of mine Busabos77!
    Ok, so proper update time.
    Installed 17.5mm spacers up front to push out the ZCP's.
    And I met fellow forum member Mr.Wolfe while he was in my neck of the woods, nice to meet ya!
    I installed JVT Ceramic Coated headers last Thursday, I felt an immediate difference at all RPM's.
    While I was waiting on the install (it took about 8 hours at a shop because every single damn exhaust stud backed out!). I took some pics of their inventory
    Ferrari 575 with a 6 speed manual!
    I went to test drive an FRS because racecar, Toyota won't care how I park.
    My buddy also showed up to tag along, he parked fine though...
    Next I installed a Mevius muffler with Ti tips
    A preview of what it sounds like with the headers + muffler and my other "mods", it's a short video because I don't like having unburnt fuel in my face.
    While the muffler was being installed this gem rolled in, it's a numbered Canadian Euro Spec E36 M3 owned by a BMWCCA Instructor who knew all of my instructors.
    It's 18/45 Diamond Schwartz Metallic with an OEM GT Wing and Stamped LTW's with PSS's and PFC brakes all around (awesome sauce).
    Dat Motor! It's a built 3.0 S50B30 stroked to 3.2 with all new valves, cams etc.
    Full Raven rollcage and datalogger etc. Thing was done up right.
    964 PCar.
    Update!
    Muffler has been awesome! Here's a vid my cousin shot while riding shotgun.
    I get free parking at work, but I have to park in the loading dock to do so, I parked for 3 hours and this is what I see when I get to my car.
    She was a GREAT driver.
    Lady, how the hell did you get out of the car?
    Buddy with his Dad's Ford GT.
    Dem switches.
    Just going to get some groceries, ohh lets take the C63 Black Series today, why not!
    The night before Bimmercruise.
    All clean and purdy.
    Before the new tires and camber adjustments.
    I drive everyday, no garage queen here!
    After our usual Friday night meet, we decided to head to Downtown Toronto as a group for some Pho (my idea) the cops did not like us at all, especially at 2 AM. Found a nice dock, so we did some burnouts in my buddy's E60 M5. What a view as well, sorry for the sh1tty pic, I was tired.
    I met this guy at Bimmercruise, his car was an IND build car, Silver Ghost I believe. Makes me feel poor lol.
    My crap photography ain't doing it any justice...
    Spent 6 hours cleaning the car, top to bottom.
    Love these wheels! But they are a PITA to clean!
    Getting that stud kit and fuel filter installed.
    Dem tips...
    Going to school in the morning, this guy drives by...
    Car is used to get me from Point A to food!
    Picking up some parts from the stealer, LSB wrapped E92 M3 parks next to me. Take a pic, girl in the passenger seat starts laughing at me...
    Eggnog Season has returned! ERMAHGAD!
    Heading to school in the morning, Vorsteiner GTS-3 Widebody M3.
    Miles just keep climbing!
    One clean tip, one dirty as hell!
    Some sort of an update I guess, been really busy lately however I somehow find time to do little things to the car.
    First up, the DIY Clutch Stop. This thing FTW. And less than 4 dolares FTMFW.
    I can finally hit 5th gear without an damn issues!
    Next up was to change my cabin air filter. I forgot I left a brand new one under my trunk mat
    Old one wasn't THAT dirty I guess.
    There's a DIY thread over on M3Forum about installing the F10 M5 Illuminated ZHP knob correctly. I did mine a year ago to this upcoming month and mine looks better than yours :lol:
    Helped a great friend of mine install his Karbonious CSL Airbox :drool: I basically held a flashlight and suggested the use of zipties the whole time!
    Looks like someone got a new toy (05+, ZCP wheels)
    And crossed this a couple days ago! Planned a vanos and rod bearing overhaul over the summer.
    Subframe will have to wait until next year, as well as new brakes (thinking AP Racing + PFC :drool.
    Car is eating rear tires so I'm getting my RTAB's checked out, it's either that or my alignment specs are too harsh for street use.
    Other than that, I have some goodies awaiting the car back home in Boston (OEM BMW Motorsport and Swift Spring goodies :drool and in the future I plan on getting some light 18's with stickier tires.
    Undecided if I want to leave the car's exterior stock. Not sure if I want to conform to the rep CSL parts everyone and their mom throws on these cars.
    Mini Update:
    Got a full set of PSS in 245/275 for a great deal thanks to a local!
    Also, my friend got this for me for helping him install an exhaust on his E36 M3 and giving him a spare Euro Bosch headlight.
    OEM BMW Motorsport Golf Ball Shift Knob!
    It took 4 months to get here, it was ordered by fluke in December with no expectations to ever receive it!
    Other news, the car basically sits at my parents house since I work in Downtown Boston now, so I can be a little crazy/crazier with practicality now. Getting an oil change, trans and diff fluid flush next week along with new belts for preventative maintenance. Also doing a valve adjustment to finish off my Inspection 2 next month.
    Lastly, I found a local tuner! They're called BrenTuning in Central Mass and they offer live dyno tunes. I figured I would give them a shot since they are local and I want/expect instant gratification for everything!
    2005 BMW ///M3
    Black6MT Daily
      You're going to have to excuse the iPhone 4 and my neanderthal photo taking skills but that was a WHILE ago. When I originally bought this car I never thought I'd keep it. I was going to sell it in a year or so and possibly upgrade to an E9X M3. LOL
      I'm still digging around for photos.
      2005 BMW ///M3
      Black6MT Daily
        Ok so where we last left off I was still in school in Toronto going into my senior year. Yay.
        Halfway through my dad got sick so I made a deal with my dean to transfer one of my degrees over to Boston University. Now I'm moving back!
        I quickly realized that the M3 does not like Boston. I needed a car to lug around stuff too. So I bought a one owner 2005 X5 4.8iS in LeMans Blue with the comfort black leather option. Was a great car for the 3 years I had it. Managed 10 MPG consistently and was my "M5" because I needed the space but wanted some power.
        Click image for larger version  Name:	X5 LeMans.jpg Views:	0 Size:	271.7 KB ID:	31180
        Click image for larger version  Name:	X5 LeMans 2.jpg Views:	0 Size:	306.5 KB ID:	31181
        So somewhere along the way I had the idea that the X5 and M3 could be combined to one car to do it all. I had a local doctor looking for an E46 M3 for a track candidate and wanted to trade his B7 RS4 in Sprint Blue. I took it for a drive because I had never driven one or any Audi before and WOW. Yea no. Understeer all day long. No thanks. Great color and spec but wasn't going to cut it.
        Click image for larger version  Name:	B7 RS4.jpg Views:	0 Size:	59.1 KB ID:	31182
        A few (terrible I might add) shots of the M3 getting it's last fill of Canadian overpriced 91!
        Click image for larger version  Name:	M3 Gas.jpg Views:	0 Size:	166.5 KB ID:	31183
Name:	M3 Gas 2.jpg
        2005 BMW ///M3
        Black6MT Daily
          Amazing car please create threads for the others as time permits
          DD: /// 2011.5 Jerez/bamboo E90 M3 ยท DCT ยท Slicktop ยท Instagram
          /// 2004 Silvergrey M3 ยท Coupe ยท 6spd ยท Slicktop ยท zero options
            Car looks great!
              How does the OE CSL wheel setup ride around town with the 265 tires all around? That setup is gorgeous!
                Will do, nice to see ya here!
                2005 BMW ///M3
                Black6MT Daily
                  Originally posted by Loopyspec View Post
                  Car looks great!
                  Thank you!
                  2005 BMW ///M3
                  Black6MT Daily
                    It's pretty good. Car tramlines a lot due to the alignment but I needed the alignment to keep it from rubbing.
                    It's not the fastest in this spec but it does look good haha
                    2005 BMW ///M3
                    Black6MT Daily
                      I see you still take your pics with a potato ๐Ÿ˜œ
                      2003.5 Titanium Silver / Black 6M/T (Gone)
                        A little toe in up front will help a bit.
                        Looks like you've done a bit of work to it from what I remember. ๐Ÿ˜‚
                          Ya, did it say o toe f & r in your op? I love some toe out! And a little in, in the rear for stability. Eats tires a little more, but worth it imo
                            Who let you in here!? LOL
                            2005 BMW ///M3
                            Black6MT Daily
                              Ok massive photo dump, bear with me I'm going through years of what I can find lol
                              So I snagged the last brand new Vorsteiner GTS3 1x1 CF diffuser directly from them in 2014. Bought it as an early Christmas present to myself. Love the way the way it looks and it fits very well.
                              A friend of mine has a YouTube channel called IgnitionTube. He wanted to shoot the M3 and do a video. Here's a shot of it semi clean. Video is below.
                              A shot from Boston's Car's and Coffee at Larz Anderson circa 2015?
                              At this point I had a CEL on for no cats. I've been running the JVT's without a tune for about almost 2 years. Time for a tune. I didn't want a flash or a can tune. I wanted to hear it, see it and watch it on a dyno with the person tuning my car in my state. BrenTurning was what everyone around was using. Bren extracted a shit ton out of the car. This is when we realized that the PO had spent quite a bit of money on this car. More on this later. Here's a vid.
                              So I had been scouring forums, eBay, online etc for a Vorsteiner CSL trunk. My GTS3 diffuser was still in the box as I didn't want to run it without a trunk. It looks incomplete and weird. After like 4 years of searching, a friend of mine was parting his AW M3 in Texas. He had a double sided CF trunk in 1x1 weave to match my diffuser with the edge exposed. Perfect! I also bought his V1 Vorsteiner CSL front bumper and a VCSL 1x1 CSL diffuser. Sold both of those parts to get some money back haha.
                              This was day 1 of running the trunk, still needed quite a bit of fiddling.
Name:	CSL Day .jpg
                              A peek into the interior at the same time, just "upgraded" to a ZCP steering wheel. God I hate alcantara. What a bad phase.
                              I had also found a person on M3F parting an individual car. He had extended Cinnamon and he hated it lol. I bought as many parts as I could off him. Got the shifter boot, e brake boot and armrest.
                              Just awful. SMDH.
Name:	Terrible Wheel .jpg
                              Right afterwards, I had vanos blow up on me. Marbles the whole shabang. Mileage was around 165k at the time but the car had a new vanos unit installed by the dealer at 111k. Shocker.
                              Opted for EVERYTHING Raj over at Beisans Systems sold at the time. Sucks he didn't offer the teflon upper chain guide then SMDH.
                              Had my shop in Boston install everything.
                              While doing this work we found out that the cams were not stock on this motor. I called the PO and turns out when vanos exploded at 111k it damaged the head in a few ways. They had the head built and added cams at the time. Further looking through paperwork, I found what I needed to see. Schricks. Explained the trash idle and surging I was getting prior to the tune. Also absolute shit gas mileage but that's partially due to being not tuned and being catless.
                              Some shots at this point.
Name:	M3 Rooftop .jpg
Name:	M3 Rooftop 1.jpg
Name:	M3 Rooftop 2.jpg
Name:	M3 Rooftop 3.jpg
                              After this I took the M3 with my friends in a caravan style down to H2Oi in Ocean City MD. I'm still looking for pics, but it was during Hurricane Joaquim. Yea. Not that much fun. Yea.
                              2005 BMW ///M3
                              Black6MT Daily
