Originally posted by Bry5on
He's what I did
This allows you to use the M track mode button on the steering wheel to act as the same DSC button in the SZM switch panel. I have M track mode setup and coded so that single press of DSC button enables/disables M track mode and press and HOLD dsc button disables DSC system. M trac mode button on steering wheel now will function exactly the sme and you can still use both buttons.
Code:
DSC Tap wire on X521 connector (Black 4 pin connector in SZM Switch panel) Pin 2 - DSC Passive Activation (12+ positive signal not negative ground signal) M Track BUTTON (This is negative ground momentary switch) X10170 Green Clock Spring Plug (10 pin connector) Pin 10 - 12 Volt ignition 2 source - Tap this wire for power to Relay Pin 8 - Cruise Control ON/Off Signal to DME - Remove this Pin it will be unused, wrap pin contact in electrical tape safely as it also has 12 volts directly from DME and has 1 volt when power is off. RELAY (any 4/5 wire relay I just used a factory BMW green relay and socket) Pin 30 and 86 - Combine both wires on relay for pin 30 and 86 together and wire to PIN 10 green connector X10170 via wire tap Pin 87 - Run this wire to PIN 2 X521 DSC Black 4 pin connector via wire tap Pin 85 - ground switch - wire to X10170 PIN 8. (When you press M track mode button, the button sends negative signal on pin 8 which grounds the relay which then sends 12 volts to DSC plug pin 2 to toggle DSC like the factory button)
