Anyone save the DTC address’ in different software versions??
    Did anybody happen to save that long list of the diagnostic trouble code locations and where they were in each software release? I would appreciate if you could post or send them to me!
    was searching for this too. even google cache isn't working any longer for me
    2003 AW/BLK 6MT - Instagram
      If you just want what the DTCs are, here's a list from Tool32
      Error Number Error Text
      0x01 Relay fuel pump
      0x02 Idling control closing coil
      0x03 Intake valve 1
      0x04 Intake valve 3
      0x05 Intake valve 2
      0x06 Time out SMG-CAN
      0x07 EVANOS1-Hall sensor
      0x08 EVANOS2-Hall sensor
      0x09 Knocking sensor 1
      0x0A AVANOS1-Hall sensor
      0x0B AVANOS2-Hall sensor
      0x0C Lambda sensor 2 before cat
      0x0D Lambda sensor 1 before cat
      0x0E LDP-Heater
      0x0F Synchronisation CS-sensor 1 with KW
      0x10 KW-inductive sensor
      0x11 SMG switching process
      0x12 GKS driver
      0x13 Secondary air pump relay
      0x14 Start relay
      0x15 AVANOS1-late valve
      0x16 AVANOS1-early valve
      0x17 Ignition coil 2
      0x18 Ignition coil 3
      0x19 Ignition coil 1
      0x1A Ignition coil 8
      0x1B Tank leakage diagnosis valve
      0x1C GKS regulator
      0x1D Idling control opening coil
      0x1E Monitoring AD-converter
      0x1F Intake valve 5
      0x20 Intake valve 6
      0x21 Intake valve 4
      0x22 Intake valve 7
      0x23 Intake valve 8
      0x24 Tank ventilation valve
      0x25 Lambda sensor heating 1 before cat.
      0x26 Lambda sensor heating 2 before cat.
      0x27 Lambda sensor heating 1 after cat.
      0x28 Lambda sensor heating 2 after cat.
      0x29 Air mass sensor 1
      0x2A Direct speed input
      0x2B Cooling water outlet temperature sensor
      0x2C Signal active oil level sensor
      0x2D EDK-hardware
      0x2E Consumption signal output KVA
      0x2F Engine speed signal output TD
      0x30 Relay A/C compressor
      0x31 internal index 95
      0x32 Ignition coil 4
      0x33 Ignition coil 6
      0x34 Ignition coil 5
      0x35 Electronic fan
      0x36 Main relay for supply voltage
      0x37 Ignition coil 7
      0x38 internal index 96
      0x39 Air mass sensor 2
      0x3A Sensor supply 1 Master
      0x3B Sensor supply 2 Master
      0x3C Pedal value sensor 1
      0x3D Pedal value sensor 2
      0x3E internal index 97
      0x3F Secondary air valve
      0x40 internal index 98
      0x41 Throttle valve pot. 2 Slave
      0x42 EWS-interface
      0x43 EVANOS1-early valve
      0x44 SMG safety concept
      0x45 Knocking sensor 3
      0x46 Knockingsensor 2
      0x47 Knocking sensor 4
      0x48 EVANOS1-late valve
      0x49 Air mass to DKG-adjustment not plausible
      0x4A EVANOS2-early valve
      0x4B EVANOS2-late valve
      0x4C internal: Surrounding pressure sensor
      0x4D Manifold air temperature sensor
      0x4E Cooling water temperature sensor
      0x4F Exhaust temperature sensor
      0x50 Switch chain grip
      0x51 MFL-interface
      0x52 Exhaust valve
      0x53 AVANOS2-early valve
      0x54 AVANOS2-late valve
      0x55 EDK-sensor
      0x56 CAN-Bus DME
      0x57 Lambda sensor 1 after cat.
      0x58 Lambda sensor 2 after cat.
      0x59 internal index 240
      0x5A Pre-cat sensor 1 TV-shift
      0x5B Pre-cat sensor 2 TV-shift
      0x5C Post-cat sensor 1 voltage monitoring
      0x5D Post-cat sensor 2 voltage monitoring
      0x5E internal index 241
      0x5F internal index 242
      0x60 plausibility coolant outtaken temperature
      0x61 internal index 244
      0x62 internal index 245
      0x63 internal index 246
      0x64 Tire pressure left front
      0x65 Tire pressure right front
      0x66 Tire pressure right back
      0x67 Tire pressure left back
      0x68 internal index 86
      0x69 Plausibility engine temperature
      0x6A Brake light switch
      0x6B Self test EGAS-actuator
      0x6C Oil valve left
      0x6D Oil valve right
      0x6E LED dynamic drive switch
      0x6F Pedal value comparison 1
      0x70 Pedal value comparison 2
      0x71 EVANOS2-regulation
      0x72 AVANOS2-regulation
      0x73 internal: ECU-temperature
      0x74 Servotronik valve measurement of current
      0x75 Servotronik measurement of speed signal
      0x76 Throttle valve pot. 1
      0x77 Throttle valve pot. 2
      0x78 Comparison throttle valve pot.
      0x79 Both throttle valve pots.
      0x7A internal: Master processor check
      0x7B Bus-Off local SMG-CAN
      0x7C potentiometer sound flap GKS
      0x7D Spoiler adjustment/TOG-lamp
      0x7E EKP-crash-disconnection
      0x7F Tank leakage diagnosis module
      0x80 Deviation idling speed
      0x81 KAT protection activated at empty petrol tank
      0x82 EWS-signal manipulation
      0x83 DSC-intervention not plausible
      0x84 Time out DSC-message
      0x85 Time out LWS-message
      0x86 Time out KOMBI-message
      0x87 Both V-Signal sources
      0x88 Idle speed regulator
      0x89 Jet stream pump
      0x8A Differential lock
      0x8B Cruise control system
      0x8C Engine noise
      0x8D Filling value plausibilisation
      0x8E System jet stream pump
      0x8F E-box-fan
      0x90 Lambda regulator 1
      0x91 Lambda regulator 2
      0x92 internal index 105
      0x93 internal index 106
      0x94 internal index 107
      0x95 Error if tank is empty
      0x96 internal: Memory test Master
      0x97 internal: driver diagnostics chain
      0x98 internal: Communication master
      0x99 internal index 87
      0x9A crankcase venting
      0x9B internal: Adaption-EEPROM master
      0x9C internal: Adaption-EEPROM Slave
      0x9D internal: Memory test Slave
      0x9E internal: Resets Slave
      0x9F Knock IC 1
      0xA0 Knock IC 2
      0xA1 internal: Knock signal path
      0xA2 Synchronisation CS-sensor 2 with KW
      0xA3 internal: Resets Master
      0xA4 internal index 99
      0xA5 internal index 100
      0xA6 internal index 101
      0xA7 internal index 102
      0xA8 internal index 103
      0xA9 internal index 104
      0xAA Minimum flow of secondary air
      0xAB Secondary air valve stuck
      0xAC Vanos-pressure storage valve
      0xAD KL50 starter switch0
      0xAE Fuel system diagnosis 1
      0xAF Fuel system diagnosis 2
      0xB0 internal index 174
      0xB1 MIL external info
      0xB2 KAT-conversion 1
      0xB3 KAT-conversion 2
      0xB4 Tank leak
      0xB5 Info Tank cap missing
      0xB6 Over-temperature on injection driver 1
      0xB7 Over-temperature on injection driver 2
      0xB8 EVANOS1 regulation
      0xB9 AVANOS1 regulation
      0xC2 Safety check disconnection FGR
      0xC3 Monitoring torque manager
      0xC4 Misfire cyl. 1 cat.-dam.
      0xC5 Misfire cyl. 2 cat.-dam.
      0xC6 Misfire cyl. 3 cat.-dam.
      0xC7 Misfire cyl. 4 cat.-dam.
      0xC8 Misfire cyl. 5 cat.-dam.
      0xC9 Misfire cyl. 6 cat.-dam.
      0xCA Misfire cyl. 7 cat.-dam.
      0xCB Misfire cyl. 8 cat.-dam.
      0xCC Misfire of multiple cyl. cat.-dam.
      0xCD Misfire cyl. 1 Exhaust
      0xCE Misfire cyl. 2 Exhaust
      0xCF Misfire cyl. 3 Exhaust
      0xD0 Misfire cyl. 4 Exhaust
      0xD1 Misfire cyl. 5 Exhaust
      0xD2 Misfire cyl. 6 Exhaust
      0xD3 Misfire cyl. 7 Exhaust
      0xD4 Misfire cyl. 8 Exhaust
      0xD5 Misfire of multiple cyl. Exhaust
      0xD6 Pre-cat sensor 1 period length
      0xD7 Pre-cat sensor 2 period length
      0xD8 Pre-cat sensor 1 rise time
      0xD9 Pre-cat sensor 2 rise time
      0xDA Pre-cat sensor 1 signal displacement
      0xDB Pre-cat sensor 2 signal displacement
      0xDC internal index 235
      0xDD systemcheck crankcase venting
      0xDE CAN timeout ZSG
      0xDF preasure intaken manifold
      0xE0 plausibility loading signal
      0xE1 environmental temperature
      0xE2 Kombi relative time
      0xE3 internal index 79
      0xE4 EGAS-actuator
      0xE5 EGAS-regulation
      0xE6 EGAS-Nominal/actual-comparison
      0xE7 internal: slave processor check
      0xE8 Function check TEV
      0xE9 internal index 85
      0xXY Unknown error location
      The definitions won't change from version to version. If you want to delete a code, you're better off just searching for it in the binary.
        Thanks for this, it was so convenient having the address to go right to the location. I’m sure someone saved it
          Here you go.
          https://docs.google.com/document/d/1...it?usp=sharing
            Maybe I'm crazy, but I feel like searching through that doc is no easier than just searching "FF[ErrorHexCode]" in the binary itself.
              Dec Hex 0901/1101/1301/1501/1701/2101/2401/2601/2801 1601 1801/1901/2001/2501/2701
              1 0x01 0x3916 0x6076 0x6176
              2 0x02 0x7892 0xE092 0xE092
              3 0x03 0x3A74 0x61D4 0x62D4
              4 0x04 0x3A90 0x61F0 0x62F0
              5 0x05 0x3A82 0x61E2 0x62E2
              6 0x06 0x3A58 0x61B8 0x62B8
              7 0x07 0x39B0 0x6110 0x6210
              8 0x08 0x7A98 0xE298 0xE298
              9 0x09 0x78D8 0xE0D8 0xE0D8
              10 0x0A 0x39BE 0x611E 0x621E
              11 0x0B 0x7AA6 0xE2A6 0xE2A6
              12 0x0C 0x395C 0x60BC 0x61BC
              13 0x0D 0x394E 0x60AE 0x61AE
              14 0x0E 0x791E 0xE11E 0xE11E
              15 0x0F 0x3E9C 0x65FC 0x66FC
              16 0x10 0x38D0 0x6030 0x6130
              17 0x11 0x3EAA 0x660A 0x670A
              18 0x12 0x3B8C 0x62EC 0x63EC
              19 0x13 0x7BA2 0xE3A2 0xE3A2
              20 0x14 0x79F0 0xE1F0 0xE1F0
              21 0x15 0x39F6 0x6156 0x6256
              22 0x16 0x39E8 0x6148 0x6248
              23 0x17 0x3CB2 0x6412 0x6512
              24 0x18 0x3CC0 0x6420 0x6520
              25 0x19 0x3CA4 0x6404 0x6504
              26 0x1A 0x3D06 0x6466 0x6566
              27 0x1B 0x3B00 0x6260 0x6360
              28 0x1C 0x3B7E 0x62DE 0x63DE
              29 0x1D 0x78A0 0xE0A0 0xE0A0
              30 0x1E 0x3908 0x6068 0x6168
              31 0x1F 0x3AAC 0x620C 0x630C
              32 0x20 0x3ABA 0x621A 0x631A
              33 0x21 0x3A9E 0x61FE 0x62FE
              34 0x22 0x3AC8 0x6228 0x6328
              35 0x23 0x3AD6 0x6236 0x6336
              36 0x24 0x396A 0x60CA 0x61CA
              37 0x25 0x3BB6 0x6316 0x6416
              38 0x26 0x3BC4 0x6324 0x6424
              39 0x27 0x3BD2 0x6332 0x6432
              40 0x28 0x3BE0 0x6340 0x6440
              41 0x29 0x7A60 0xE260 0xE260
              42 0x2A 0x7910 0xE110 0xE110
              43 0x2B 0x38FA 0x605A 0x615A
              44 0x2C 0x7D2A 0xE52A 0xE52A
              45 0x2D 0x7D1C 0xE51C 0xE51C
              46 0x2E 0x3A3C 0x619C 0x629C
              47 0x2F 0x3A4A 0x61AA 0x62AA
              48 0x30 0x7A52 0xE252 0xE252
              49 0x31 0x7D38 0xE538 0xE538
              50 0x32 0x3CCE 0x642E 0x652E
              51 0x33 0x3CEA 0x644A 0x654A
              52 0x34 0x3CDC 0x643C 0x653C
              53 0x35 0x38B4 0x6014 0x6114
              54 0x36 0x3932 0x6092 0x6192
              55 0x37 0x3CF8 0x6458 0x6558
              56 0x38 0x7D46 0xE546 0xE546
              57 0x39 0x7A6E 0xE26E 0xE26E
              58 0x3A 0x7A36 0xE236 0xE236
              59 0x3B 0x7A44 0xE244 0xE244
              60 0x3C 0x7CF2 0xE4F2 0xE4F2
              61 0x3D 0x7D00 0xE500 0xE500
              62 0x3E 0x7D54 0xE554 0xE554
              63 0x3F 0x7BB0 0xE3B0 0xE3B0
              64 0x40 0x7D62 0xE562 0xE562
              65 0x41 0x3978 0x60D8 0x61D8
              66 0x42 0x3A66 0x61C6 0x62C6
              67 0x43 0x39CC 0x612C 0x622C
              68 0x44 0x3EB8 0x6618 0x6718
              69 0x45 0x78F4 0xE0F4 0xE0F4
              70 0x46 0x78E6 0xE0E6 0xE0E6
              71 0x47 0x7902 0xE102 0xE102
              72 0x48 0x39DA 0x613A 0x623A
              73 0x49 0x7A1A 0xE21A 0xE21A
              74 0x4A 0x7AB4 0xE2B4 0xE2B4
              75 0x4B 0x7AC2 0xE2C2 0xE2C2
              76 0x4C 0x79D4 0xE1D4 0xE1D4
              77 0x4D 0x79FE 0xE1FE 0xE1FE
              78 0x4E 0x7A0C 0xE20C 0xE20C
              79 0x4F 0x7956 0xE156 0xE156
              80 0x50 0x3AE4 0x6244 0x6344
              81 0x51 0x7AFA 0xE2FA 0xE2FA
              82 0x52 0x7BDA 0xE3DA 0xE3DA
              83 0x53 0x7AD0 0xE2D0 0xE2D0
              84 0x54 0x7ADE 0xE2DE 0xE2DE
              85 0x55 0x7D0E 0xE50E 0xE50E
              86 0x56 0x793A 0xE13A 0xE13A
              87 0x57 0x3B9A 0x62FA 0x63FA
              88 0x58 0x3BA8 0x6308 0x6408
              89 0x59 0x3EC6 0x6626 0x6726
              90 0x5A 0x3BFC 0x635C 0x645C
              91 0x5B 0x3C0A 0x636A 0x646A
              92 0x5C 0x3C18 0x6378 0x6478
              93 0x5D 0x3C26 0x6386 0x6486
              94 0x5E 0x3ED4 0x6634 0x6734
              95 0x5F 0x3EE2 0x6642 0x6742
              96 0x60 0x3EF0 0x6650 0x6750
              97 0x61 0x3EFE 0x665E 0x675E
              98 0x62 0x3F0C 0x666C 0x676C
              99 0x63 0x7E26 0xE626 0xE626
              100 0x64 0x3C50 0x63B0 0x64B0
              101 0x65 0x3C5E 0x63BE 0x64BE
              102 0x66 0x3C6C 0x63CC 0x64CC
              103 0x67 0x3C7A 0x63DA 0x64DA
              104 0x68 0x7CBA 0xE4BA 0xE4BA
              105 0x69 0x7884 0xE084 0xE084
              106 0x6A 0x78CA 0xE0CA 0xE0CA
              107 0x6B 0x7A28 0xE228 0xE228
              108 0x6C 0x7A7C 0xE27C 0xE27C
              109 0x6D 0x7A8A 0xE28A 0xE28A
              110 0x6E 0x3A20 0x6180 0x6280
              111 0x6F 0x7B08 0xE308 0xE308
              112 0x70 0x7B16 0xE316 0xE316
              113 0x71 0x7B24 0xE324 0xE324
              114 0x72 0x7B32 0xE332 0xE332
              115 0x73 0x7B40 0xE340 0xE340
              116 0x74 0x7B4E 0xE34E 0xE34E
              117 0x75 0x7B5C 0xE35C 0xE35C
              118 0x76 0x7B6A 0xE36A 0xE36A
              119 0x77 0x7B78 0xE378 0xE378
              120 0x78 0x7B86 0xE386 0xE386
              121 0x79 0x7B94 0xE394 0xE394
              122 0x7A 0x3924 0x6084 0x6184
              123 0x7B 0x39A2 0x6102 0x6202
              124 0x7C 0x3A04 0x6164 0x6264
              125 0x7D 0x3A12 0x6172 0x6272
              126 0x7E 0x3940 0x60A0 0x61A0
              127 0x7F 0x3A2E 0x618E 0x628E
              128 0x80 0x7BF6 0xE3F6 0xE3F6
              129 0x81 0x7C04 0xE404 0xE404
              130 0x82 0x38C2 0x6022 0x6122
              131 0x83 0x7814 0xE014 0xE014
              132 0x84 0x7822 0xE022 0xE022
              133 0x85 0x7830 0xE030 0xE030
              134 0x86 0x783E 0xE03E 0xE03E
              135 0x87 0x784C 0xE04C 0xE04C
              136 0x88 0x7948 0xE148 0xE148
              137 0x89 0x7964 0xE164 0xE164
              138 0x8A 0x7972 0xE172 0xE172
              139 0x8B 0x7980 0xE180 0xE180
              140 0x8C 0x798E 0xE18E 0xE18E
              141 0x8D 0x785A 0xE05A 0xE05A
              142 0x8E 0x7868 0xE068 0xE068
              143 0x8F 0x7876 0xE076 0xE076
              144 0x90 0x3986 0x60E6 0x61E6
              145 0x91 0x3994 0x60F4 0x61F4
              146 0x92 0x7DC4 0xE5C4 0xE5C4
              147 0x93 0x7DD2 0xE5D2 0xE5D2
              148 0x94 0x7DE0 0xE5E0 0xE5E0
              149 0x95 0x3E8E 0x65EE 0x66EE
              150 0x96 0x78BC 0xE0BC 0xE0BC
              151 0x97 0x3BEE 0x634E 0x644E
              152 0x98 0x792C 0xE12C 0xE12C
              153 0x99 0x7CC8 0xE4C8 0xE4C8
              154 0x9A 0x7CD6 0xE4D6 0xE4D6
              155 0x9B 0x78AE 0xE0AE 0xE0AE
              156 0x9C 0x38DE 0x603E 0x613E
              157 0x9D 0x38EC 0x604C 0x614C
              158 0x9E 0x3AF2 0x6252 0x6352
              159 0x9F 0x799C 0xE19C 0xE19C
              160 0xA0 0x79AA 0xE1AA 0xE1AA
              161 0xA1 0x79B8 0xE1B8 0xE1B8
              162 0xA2 0x79C6 0xE1C6 0xE1C6
              163 0xA3 0x79E2 0xE1E2 0xE1E2
              164 0xA4 0x7D70 0xE570 0xE570
              165 0xA5 0x7D7E 0xE57E 0xE57E
              166 0xA6 0x7D8C 0xE58C 0xE58C
              167 0xA7 0x7D9A 0xE59A 0xE59A
              168 0xA8 0x7DA8 0xE5A8 0xE5A8
              169 0xA9 0x7DB6 0xE5B6 0xE5B6
              170 0xAA 0x7BBE 0xE3BE 0xE3BE
              171 0xAB 0x7BCC 0xE3CC 0xE3CC
              172 0xAC 0x7AEC 0xE2EC 0xE2EC
              173 0xAD 0x7BE8 0xE3E8 0xE3E8
              174 0xAE 0x3B0E 0x626E 0x636E
              175 0xAF 0x3B1C 0x627C 0x637C
              176 0xB0 0x3B2A 0x628A 0x638A
              177 0xB1 0x3B38 0x6298 0x6398
              178 0xB2 0x3B46 0x62A6 0x63A6
              179 0xB3 0x3B54 0x62B4 0x63B4
              180 0xB4 0x3B62 0x62C2 0x63C2
              181 0xB5 0x3B70 0x62D0 0x63D0
              182 0xB6 0x3C34 0x6394 0x6494
              183 0xB7 0x3C42 0x63A2 0x64A2
              184 0xB8 0x3C88 0x63E8 0x64E8
              185 0xB9 0x3C96 0x63F6 0x64F6
              186 0xBA 0x7E96 0xE696 0xE696
              187 0xBB 0x7EA4 0xE6A4 0xE6A4
              188 0xBC 0x7EB2 0xE6B2 0xE6B2
              189 0xBD 0x7EC0 0xE6C0 0xE6C0
              190 0xBE 0x7ECE 0xE6CE 0xE6CE
              191 0xBF 0x7EDC 0xE6DC 0xE6DC
              192 0xC0 0x7EEA 0xE6EA 0xE6EA
              193 0xC1 0x7EF8 0xE6F8 0xE6F8
              194 0xC2 0x3D14 0x6474 0x6574
              195 0xC3 0x7C9E 0xE49E 0xE49E
              196 0xC4 0x3D30 0x6490 0x6590
              197 0xC5 0x3D3E 0x649E 0x659E
              198 0xC6 0x3D4C 0x64AC 0x65AC
              199 0xC7 0x3D5A 0x64BA 0x65BA
              200 0xC8 0x3D68 0x64C8 0x65C8
              201 0xC9 0x3D76 0x64D6 0x65D6
              202 0xCA 0x3D84 0x64E4 0x65E4
              203 0xCB 0x3D92 0x64F2 0x65F2
              204 0xCC 0x3DA0 0x6500 0x6600
              205 0xCD 0x3DAE 0x650E 0x660E
              206 0xCE 0x3DBC 0x651C 0x661C
              207 0xCF 0x3DCA 0x652A 0x662A
              208 0xD0 0x3DD8 0x6538 0x6638
              209 0xD1 0x3DE6 0x6546 0x6646
              210 0xD2 0x3DF4 0x6554 0x6654
              211 0xD3 0x3E02 0x6562 0x6662
              212 0xD4 0x3E10 0x6570 0x6670
              213 0xD5 0x3E1E 0x657E 0x667E
              214 0xD6 0x3E2C 0x658C 0x668C
              215 0xD7 0x3E3A 0x659A 0x669A
              216 0xD8 0x3E48 0x65A8 0x66A8
              217 0xD9 0x3E56 0x65B6 0x66B6
              218 0xDA 0x3E64 0x65C4 0x66C4
              219 0xDB 0x3E72 0x65D2 0x66D2
              220 0xDC 0x3E80 0x65E0 0x66E0
              221 0xDD 0x7CE4 0xE4E4 0xE4E4
              222 0xDE 0x7C12 0xE412 0xE412
              223 0xDF 0x7C20 0xE420 0xE420
              224 0xE0 0x7C2E 0xE42E 0xE42E
              225 0xE1 0x7C3C 0xE43C 0xE43C
              226 0xE2 0x7C4A 0xE44A 0xE44A
              227 0xE3 0x7C58 0xE458 0xE458
              228 0xE4 0x7C66 0xE466 0xE466
              229 0xE5 0x7C74 0xE474 0xE474
              230 0xE6 0x7C82 0xE482 0xE482
              231 0xE7 0x7C90 0xE490 0xE490
              232 0xE8 0x3D22 0x6482 0x6582
              233 0xE9 0x7CAC 0xE4AC 0xE4AC
              234 0xEA
              235 0xEB
              236 0xEC
              237 0xED
              238 0xEE
              239 0xEF
              240 0xF0
              241 0xF1
              242 0xF2
              243 0xF3
              244 0xF4
              245 0xF5
              246 0xF6
              247 0xF7 0x3F1A 0x667A 0x677A
              248 0xF8 0x3F6E 0x66CE 0x67CE
              249 0xF9 0x3F7C 0x66DC 0x67DC
              250 0xFA 0x3F8A 0x66EA 0x67EA
              251 0xFB 0x3F98 0x66F8 0x67F8
              252 0xFC 0x7E5E 0xE65E 0xE65E
              253 0xFD 0x7E6C 0xE66C 0xE66C
              254 0xFE 0x7E7A 0xE67A 0xE67A
              255 0xFF 0x7E88 0xE688 0xE688
                I put it in a spreadsheet here on github...
                Github WIki
                DTC Excel Spreadsheet
                TunerPro XDFs, DTCs, A2L, DIY Bench Flash Harness, Swap XDFs COMPREHENSIVE
