Hello I am in the process of an S54 swap on E36 and am running in to an odd problem. Let me know if this is in the wrong section.
My setup:
1996 M3
Z3M harness
MSS54HP running 2701 map, swap tuned using the E30 swap XDFs. DTCs etc coded out
Currently the car is wired for the CSL & Map sensor, but I am trying to get the car to start/idle using the stock MSS54HP tune (without a MAF)
E46 M3 Fuel Pump Relay
E46 M3 fuel pump
E46 M3 fuel filter
E46 M3 Fuel Pressure Regulator
Condor Speedshop Adapter harness
5speed
Z3M cluster clone
I used MSS54Flasher to flash the tune on the DME.
the E36 is previously wired with dual fuel pumps. I replaced one of the pumps with an E46 M3 one, still in the E36 sender.
I have checked continuity at many of the wires/pins and they all seem to be wired correctly, but I have not tried checking voltages at different pins, etc... The issue I am running into is this:
When I key the car on, the fuel pump doesnt seem to prime, instead it turns on and stays on. When I try to start, the car wants to start, it will fire once or twice, but it will not start. Eventually it floods.
I found that when I pull out the 15A fuse to the fuel pump, the car will start up just fine and run until the fuel in the lines runs out.
I don't find any trouble codes when I try scanning it. The car sounds great and idles fine when it does start (it stays running for maybe 15-30 seconds).
I am wondering if
I will note that I originally had the Terra CSL full binary flashed on my DME. With this flash, I only used the ECUWorx binary modification tool to "delete" the EWS. I ran in to the same problem with this method, where the engine would crank and crank and never start.
Can anyone recommend some troubleshooting tips? I don't want to throw darts at a board here, and I do not want to throw money at replacing parts.
What would cause a car not start while the fuel pump is running?
Should the fuel pump be on all the time when the key is in position 2?
Any ideas would be really helpful I am running out of things to try.
					My setup:
1996 M3
Z3M harness
E46 M3 fuel pump
E46 M3 fuel filter
5speed
Z3M cluster clone
I am wondering if
- Something could be wired wrong? (I checked continuity at almost every circuit/relay I could find pertaining to the fuel pump/pump relay)
 - My DME is defective? Is there a way to verify if the DME is behaving correctly? I can pull up the DME in INPA but I cannot get it to connect to BMWLogger except for pulling troublecodes
 - Something is wrong with the map? I believe I pulled 2701JD679 from the MSS54HP DME, and I started with a fresh copy of this tune from the Github Repository, ran it through the swap XDFs, and tried running it.
