DME Wiring for OBD Access
    I am trying to access my DME via OBD connection and I am running into an issue. I have found some conflicting information about how to access. I am building this car and the electrical harness is all custom as I have the new AIM PDM32.
    My question is- what pin gives data and write access to the DME? Utilizing WDS, I have the following wired to the DME:
    DME
    X60001 Pin 7 +12v
    X60001 Pin 8 +12v
    x60001 Pin 4,5,6 grounded to chassis
    X60004 Pin 26 +12v
    X60004 pin 32 datalink connection
    For the OBD plug I have the following wired:
    Pin 1 +12v
    Pin 4,5 grounded to chassis
    Pin 7 datalink connection to DME x60004 pin 32
    Pin 9- RPM signal to x60004 pin 17
    Pin 16 +12v
    I am getting voltage to the OBD2 pins however using a Schwaben OBD tool it will not turn on. I tried another amazon OBD reader that works on my other e46 and it will show a light as battery power but no DME connection.
    doing some searching on this forum I found a wiring diagram for a bench flash harness for the MSS54. See below.
Name:	bench flash harness.JPG
    Notice that with the bench flash harness, +12v is being applied to Pin 1, 7,8 on X60001. Looking at WDS, x60001 pin 1 is to the fuel injector relay and pin 3 isnt used in a manual car. only in SMG to the TCU however this shows a K line connection directly to the OBD2 Pin 7.
    Can anyone verify the correct wiring to the DME for power and data access from the OBD2 connection? I would appreciate any insight!
    This is something I wrote up for E30 S54 swaps, the only difference for you may be how you pull +12v fuse switched:
    TunerPro XDFs, DTCs, A2L, DIY Bench Flash Harness, Swap XDFs COMPREHENSIVE
      were you able to figure this out? I’m in the same boat and want to add in an ob2 port.
      Thanks!
      DME
      X60001 Pin 7 +12v
      X60001 Pin 8 +12v
      X60004 Pin 26 +12v
      Pin 1 +12v
      Pin 16 +12v
