EWS delete with Terra's modified CSL file
    I'm having a strange intermittent issue where the EWS hates me. It's most likely a failed module as it said ECU not recognized. It's also strange it said ECU, not DME. Tomato, tomato I guess.
    The issue I'm having is a no crank. The key is recognized and I have term 15 without an issue. Now the question:
    Using the Modification Tool for an EWS delete, will this alter the wrong part of the boot sector or should it ideally work? Also, will it overwrite any tune I have since it is recognizing the car as having CSL software? I'm not trying to walk the DME bricked road here.
    If you didn't clear the ISN turn off EWS in the tune and be done with this. Dme is probably throwing an EWS manipulation code as the ews isn't aligned to the dme.
    2003 E46 M3 TiAg/Cinnamon 6MT
    2005 E46 330i ZHP Imola/Sand
    Instagram:@thegenius46m
