On the old forum there was a thread on how to delete the PCV sucking jet pump on newer model S54s without a CEL. Anyone happen to have that info? I believe it required patching out a setting in the bin.
PCV Sucking Jet Pump Delete
which part is considered the "Sucking jet" i always get the Sucking jet confused with the "Air shut off valve"Originally posted by eacmen View PostOn the old forum there was a thread on how to delete the PCV sucking jet pump on newer model S54s without a CEL. Anyone happen to have that info? I believe it required patching out a setting in the bin.
https://www.ecstuning.com/b-genuine-...617833647~oee/
can we tune/code out the air shot off valve as well? is it really needed? have any idea where it is on the CSL software?
i was considering hooking it up to a spare barbed fitting on the bottom of my aftermarket intake manifold with my turbo setup but dont mind getting rid of it if it gets rid of one more possible pain point.Last edited by nextelbuddy; 04-10-2020, 04:59 AM.
Is this in reference to the extra CCV stuff on top of the fuel/air rail on 05+?DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Originally posted by ac427 View PostAnyone?
Doing a CSL box soon, I've got a CSL breather and had planned on modifying it to hook into the little tube/valve on a standard (US Spec.) M3. After looking at pictures of different people's CSL box installs I've noticed the vast majority do not modify their CSL breather. What effect does eliminating this extra tube/valve and
I’m not sure there’s actually an answer in there.
Thank you, it was an interesting read though. i attempted to answer your oil catch tank question at the end.Originally posted by DoubleSidedTape View Post
To evacuate the cylinders of exhaust gases at low speeds for a cleaner burnOriginally posted by ac427 View Post
What is this extra CCV stuff for?
Is the sucking jet anything to do will idle control?
Once enough speed has been reached to self evacuate, the valve closes and returns to pre 04 setup to catch blow by oil at high speeds
Thank you. How was the system changed post 2004?Originally posted by BL92 View Post
