Copy from p0lar on the old M3F
There are two main methods by which DTCs (Diagnostic Trouble Codes) are commonly suppressed within the MSS50/MSS52/MSS54/MSS54HP, and several alternative methods.
Let's start by learning how to identify a DTC string within the DME. A firm understanding of the DTC errors and their respective codes themselves will be of great assistance. NikolaiD has posted an excellent reference/list that can be located here.
Once you have an idea of which DTC you'd like to suppress, it's also important to understand the actual binary string within the DME that represents the particular DTC in question. These strings are not located in the same position in all binaries, so a table has been provided below with each version, DTC and respective offset.
The string is 14 bytes long, and generally starts with the hexadecimal DTC code itself, and finishes with a 'FF' terminator. For example, if we look at NikolaiD's chart, we can find that code 170 (0xAA), 'Minimum flow of secondary air', which is most commonly associated with the secondary air pump delete, has a hex code of 'AA'. Thus, within a sample 211323002501JD79 MSS54HP DME binary, we find a 14-byte string at offset 0xE3BE representing that particular DTC:
METHOD 1:
The first method to suppress a DTC, and coincidentally also the easiest, requires only a simple modification of the DTC string by replacing the 13th byte with '00':
METHOD 2:
The second method is to actually zero out the entire 14-byte string:
Q: Will this only suppress the CEL? Will it also set the secondary air pump emissions monitor to ready?
METHOD 3 (untested):
The third method is to perform a hybridization of the previous two by zeroing out the first and 13th bytes of the 14-byte string:
METHOD 4 :
The fourth method is to substitute the following string for the entirety of the original string, exactly as has been done within other OEM binaries for OEM suppressed codes:
Regardless of which method you employ, the DME's errors must be cleared after reflashing the DME with the updated binary.
Note that the important byte (suffix) immediately preceding the 'FF' cap has been observed to be only one of the following 13 codes, possibly dealing with the grouping of function:
There are generally two 128-byte groupings of DTCs in each section of the 32kb or 64kb binary parameter space, at the locations defined below, and always preceded by the following binary string:
Except in the case of 0701, which uses the following code to demarcate the DTC code positions:
In the case of both strings, the following four characteristics are defined:
However, in the string located in the master segment, the remainder are purposed:
The locations by version of all DTC strings, which account for ~5.4% of the total volume of MSS54HP data and ~10.8% of the total volume of MSS54/MSS52 data:
Comprehensive MSS54/MSS54HP DTC Offset Information
Unique DTCs across all MSS54/MSS54HP Versions:
Code:
AA 01 01 01 01 01 01 00 01 02 03 28 27 FF
Code:
AA 01 01 01 01 01 01 00 01 02 03 28 [B]00[/B] FF
Code:
00 00 00 00 00 00 00 00 00 00 00 00 00 00
Originally Posted by terraphantm There is a no EOBD variant for the E46 M3. But since we have much finer control of the DME nowadays, I don't really recommend flashing it (since it would disable OBD altogether). You're best off turning off the error codes you want to turn off. It has been reported that 0'ing out the entire string for the cat efficiency codes sets the monitors to ready. |
Code:
00 01 01 01 01 01 01 00 01 02 03 28 00 FF
Code:
00 28 28 03 02 03 02 00 01 02 03 28 00 FF
suffix 0x00 |
function group disabled |
0x01 | enabled/general |
0x02 | enabled/? |
0x03 | enabled/? |
0x05 | enabled/? |
0x09 | enabled/CAN External to DME |
0x23 | enabled/CAN? |
0x25 | enabled/sensor |
0x27 | enabled/general |
0x2D | enabled/DME Internal |
0x2F | enabled/EGAS |
0x34 | enabled/EWS, immobilizer |
0xA5 | enabled/misfire |
Code:
00 01 01 01 14 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 FF
Code:
00 01 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 FF
- K_ED_CONTROL = bytes 0,1 (00 00 = disabled, 00 01 = enabled)
- K_FSP_CONCEPT = byte 2 (0 = set environment condition, 1 = set special condition?, other = 'illegally masqed')
- K_FSP_TIMER = byte 3 (0 = by duration of engine operation, 1 = by mileage, other = 'illegally masqed')
- K_DS2_VMAX = byte 4 (RPM)
- K_MIL_CONTROL = byte 8 (enabled/disabled)
- K_MIL_PERIODE = byte 9 (x100 in ms)
- K_DCY_N_MIN = bytes 10,11 (RPM)
- K_DCY_DELAY = byte 12 (seconds)
- K_TMOT_OBD_WARM = byte 13 (temperature in °C)
Version 211321000502 |
DME Variant MSS52 |
Slave Offset 0x38B2 |
Master Offset 0x7812 |
211321000901 | MSS52 | 0x38B2 | 0x7812 |
211321001301 | MSS52 | 0x38B4 | 0x7814 |
211321001401 | MSS52 | 0x38B4 | 0x7814 |
211321001501 | MSS52 | 0x38B4 | 0x7814 |
211321001601 | MSS52 | 0x38B4 | 0x7814 |
211321001701 | MSS52 | 0x38B4 | 0x7814 |
211322000701 | MSS54 | 0x38B2 | 0x7812 |
211322000901 | MSS54 | 0x38B4 | 0x7814 |
211322001101 | MSS54 | 0x38B4 | 0x7814 |
211322001301 | MSS54 | 0x38B4 | 0x7814 |
211322001501 | MSS54 | 0x38B4 | 0x7814 |
211322001701 | MSS54 | 0x38B4 | 0x7814 |
211322002101 | MSS54 | 0x38B4 | 0x7814 |
211322002401 | MSS54 | 0x38B4 | 0x7814 |
211322002601 | MSS54 | 0x38B4 | 0x7814 |
211322002801 | MSS54 | 0x38B4 | 0x7814 |
211323001601 | MSS54HP | 0x6014 | 0xE014 |
211323001801 | MSS54HP | 0x6114 | 0xE014 |
211323001901 | MSS54HP | 0x6114 | 0xE014 |
211323002001 | MSS54HP | 0x6114 | 0xE014 |
211323002501 | MSS54HP | 0x6114 | 0xE014 |
211323002701 | MSS54HP | 0x6114 | 0xE014 |
211325000301 | MSS54HP {csl} | 0x6014 | 0xF014 |
211325000401 | MSS54HP {csl} | 0x6014 | 0xF014 |
dtc (dec) 0x00 (0) |
0301/0401 0x6688 |
0701 0x3F26 |
0901/1101/1301/1501/1701/2101/2401/2601/2801 0x3F28 |
1601 0x6688 |
1801/1901/2001/2501/2701 0x6788 |
0x00 (0) | 0x6696 | 0x3F34 | 0x3F36 | 0x6696 | 0x6796 |
0x00 (0) | 0x66A4 | 0x3F42 | 0x3F44 | 0x66A4 | 0x67A4 |
0x00 (0) | 0x66B2 | 0x3F50 | 0x3F52 | 0x66B2 | 0x67B2 |
0x00 (0) | 0x66C0 | 0x3F5E | 0x3F60 | 0x66C0 | 0x67C0 |
0x00 (0) | 0xF5EE | 0x7DEC | 0x7DEE | 0xE5EE | 0xE5EE |
0x00 (0) | 0xF5FC | 0x7DFA | 0x7DFC | 0xE5FC | 0xE5FC |
0x00 (0) | 0xF60A | 0x7E08 | 0x7E0A | 0xE60A | 0xE60A |
0x00 (0) | 0xF618 | 0x7E16 | 0x7E18 | 0xE618 | 0xE618 |
0x00 (0) | 0xF634 | 0x7E32 | 0x7E34 | 0xE634 | 0xE634 |
0x00 (0) | 0xF642 | 0x7E40 | 0x7E42 | 0xE642 | 0xE642 |
0x00 (0) | 0xF650 | 0x7E4E | 0x7E50 | 0xE650 | 0xE650 |
0x01 (1) | 0x6076 | 0x3914 | 0x3916 | 0x6076 | 0x6176 |
0x02 (2) | 0xF092 | 0x7890 | 0x7892 | 0xE092 | 0xE092 |
0x03 (3) | 0x61D4 | 0x3A72 | 0x3A74 | 0x61D4 | 0x62D4 |
0x04 (4) | 0x61F0 | 0x3A8E | 0x3A90 | 0x61F0 | 0x62F0 |
0x05 (5) | 0x61E2 | 0x3A80 | 0x3A82 | 0x61E2 | 0x62E2 |
0x06 (6) | 0x61B8 | 0x3A56 | 0x3A58 | 0x61B8 | 0x62B8 |
0x07 (7) | 0x6110 | 0x39AE | 0x39B0 | 0x6110 | 0x6210 |
0x08 (8) | 0xF298 | 0x7A96 | 0x7A98 | 0xE298 | 0xE298 |
0x09 (9) | 0xF0D8 | 0x78D6 | 0x78D8 | 0xE0D8 | 0xE0D8 |
0x0A (10) | 0x611E | 0x39BC | 0x39BE | 0x611E | 0x621E |
0x0B (11) | 0xF2A6 | 0x7AA4 | 0x7AA6 | 0xE2A6 | 0xE2A6 |
0x0C (12) | 0x60BC | 0x395A | 0x395C | 0x60BC | 0x61BC |
0x0D (13) | 0x60AE | 0x394C | 0x394E | 0x60AE | 0x61AE |
0x0E (14) | 0xF11E | 0x791C | 0x791E | 0xE11E | 0xE11E |
0x0F (15) | 0x65FC | 0x3E9A | 0x3E9C | 0x65FC | 0x66FC |
0x10 (16) | 0x6030 | 0x38CE | 0x38D0 | 0x6030 | 0x6130 |
0x11 (17) | 0x660A | 0x3EA8 | 0x3EAA | 0x660A | 0x670A |
0x12 (18) | 0x62EC | 0x3B8A | 0x3B8C | 0x62EC | 0x63EC |
0x13 (19) | 0xF3A2 | 0x7BA0 | 0x7BA2 | 0xE3A2 | 0xE3A2 |
0x14 (20) | 0xF1F0 | 0x79EE | 0x79F0 | 0xE1F0 | 0xE1F0 |
0x15 (21) | 0x6156 | 0x39F4 | 0x39F6 | 0x6156 | 0x6256 |
0x16 (22) | 0x6148 | 0x39E6 | 0x39E8 | 0x6148 | 0x6248 |
0x17 (23) | 0x6412 | 0x3CB0 | 0x3CB2 | 0x6412 | 0x6512 |
0x18 (24) | 0x6420 | 0x3CBE | 0x3CC0 | 0x6420 | 0x6520 |
0x19 (25) | 0x6404 | 0x3CA2 | 0x3CA4 | 0x6404 | 0x6504 |
0x1A (26) | 0x6466 | 0x3D04 | 0x3D06 | 0x6466 | 0x6566 |
0x1B (27) | 0x6260 | 0x3AFE | 0x3B00 | 0x6260 | 0x6360 |
0x1C (28) | 0x62DE | 0x3B7C | 0x3B7E | 0x62DE | 0x63DE |
0x1D (29) | 0xF0A0 | 0x789E | 0x78A0 | 0xE0A0 | 0xE0A0 |
0x1E (30) | 0x6068 | 0x3906 | 0x3908 | 0x6068 | 0x6168 |
0x1F (31) | 0x620C | 0x3AAA | 0x3AAC | 0x620C | 0x630C |
0x20 (32) | 0x621A | 0x3AB8 | 0x3ABA | 0x621A | 0x631A |
0x21 (33) | 0x61FE | 0x3A9C | 0x3A9E | 0x61FE | 0x62FE |
0x22 (34) | 0x6228 | 0x3AC6 | 0x3AC8 | 0x6228 | 0x6328 |
0x23 (35) | 0x6236 | 0x3AD4 | 0x3AD6 | 0x6236 | 0x6336 |
0x24 (36) | 0x60CA | 0x3968 | 0x396A | 0x60CA | 0x61CA |
0x25 (37) | 0x6316 | 0x3BB4 | 0x3BB6 | 0x6316 | 0x6416 |
0x26 (38) | 0x6324 | 0x3BC2 | 0x3BC4 | 0x6324 | 0x6424 |
0x27 (39) | 0x6332 | 0x3BD0 | 0x3BD2 | 0x6332 | 0x6432 |
0x28 (40) | 0x6340 | 0x3BDE | 0x3BE0 | 0x6340 | 0x6440 |
0x29 (41) | 0xF260 | 0x7A5E | 0x7A60 | 0xE260 | 0xE260 |
0x2A (42) | 0xF110 | 0x790E | 0x7910 | 0xE110 | 0xE110 |
0x2B (43) | 0x605A | 0x38F8 | 0x38FA | 0x605A | 0x615A |
0x2C (44) | 0xF52A | 0x7D28 | 0x7D2A | 0xE52A | 0xE52A |
0x2D (45) | 0xF51C | 0x7D1A | 0x7D1C | 0xE51C | 0xE51C |
0x2E (46) | 0x619C | 0x3A3A | 0x3A3C | 0x619C | 0x629C |
0x2F (47) | 0x61AA | 0x3A48 | 0x3A4A | 0x61AA | 0x62AA |
0x30 (48) | 0xF252 | 0x7A50 | 0x7A52 | 0xE252 | 0xE252 |
0x31 (49) | 0xF538 | 0x7D36 | 0x7D38 | 0xE538 | 0xE538 |
0x32 (50) | 0x642E | 0x3CCC | 0x3CCE | 0x642E | 0x652E |
0x33 (51) | 0x644A | 0x3CE8 | 0x3CEA | 0x644A | 0x654A |
0x34 (52) | 0x643C | 0x3CDA | 0x3CDC | 0x643C | 0x653C |
0x35 (53) | 0x6014 | 0x38B2 | 0x38B4 | 0x6014 | 0x6114 |
0x36 (54) | 0x6092 | 0x3930 | 0x3932 | 0x6092 | 0x6192 |
0x37 (55) | 0x6458 | 0x3CF6 | 0x3CF8 | 0x6458 | 0x6558 |
0x38 (56) | 0xF546 | 0x7D44 | 0x7D46 | 0xE546 | 0xE546 |
0x39 (57) | 0xF26E | 0x7A6C | 0x7A6E | 0xE26E | 0xE26E |
0x3A (58) | 0xF236 | 0x7A34 | 0x7A36 | 0xE236 | 0xE236 |
0x3B (59) | 0xF244 | 0x7A42 | 0x7A44 | 0xE244 | 0xE244 |
0x3C (60) | 0xF4F2 | 0x7CF0 | 0x7CF2 | 0xE4F2 | 0xE4F2 |
0x3D (61) | 0xF500 | 0x7CFE | 0x7D00 | 0xE500 | 0xE500 |
0x3E (62) | 0xF554 | 0x7D52 | 0x7D54 | 0xE554 | 0xE554 |
0x3F (63) | 0xF3B0 | 0x7BAE | 0x7BB0 | 0xE3B0 | 0xE3B0 |
0x40 (64) | 0xF562 | 0x7D60 | 0x7D62 | 0xE562 | 0xE562 |
0x41 (65) | 0x60D8 | 0x3976 | 0x3978 | 0x60D8 | 0x61D8 |
0x42 (66) | 0x61C6 | 0x3A64 | 0x3A66 | 0x61C6 | 0x62C6 |
0x43 (67) | 0x612C | 0x39CA | 0x39CC | 0x612C | 0x622C |
0x44 (68) | 0x6618 | 0x3EB6 | 0x3EB8 | 0x6618 | 0x6718 |
0x45 (69) | 0xF0F4 | 0x78F2 | 0x78F4 | 0xE0F4 | 0xE0F4 |
0x46 (70) | 0xF0E6 | 0x78E4 | 0x78E6 | 0xE0E6 | 0xE0E6 |
0x47 (71) | 0xF102 | 0x7900 | 0x7902 | 0xE102 | 0xE102 |
0x48 (72) | 0x613A | 0x39D8 | 0x39DA | 0x613A | 0x623A |
0x49 (73) | 0xF21A | 0x7A18 | 0x7A1A | 0xE21A | 0xE21A |
0x4A (74) | 0xF2B4 | 0x7AB2 | 0x7AB4 | 0xE2B4 | 0xE2B4 |
0x4B (75) | 0xF2C2 | 0x7AC0 | 0x7AC2 | 0xE2C2 | 0xE2C2 |
0x4C (76) | 0xF1D4 | 0x79D2 | 0x79D4 | 0xE1D4 | 0xE1D4 |
0x4D (77) | 0xF1FE | 0x79FC | 0x79FE | 0xE1FE | 0xE1FE |
0x4E (78) | 0xF20C | 0x7A0A | 0x7A0C | 0xE20C | 0xE20C |
0x4F (79) | 0xF156 | 0x7954 | 0x7956 | 0xE156 | 0xE156 |
0x50 (80) | 0x6244 | 0x3AE2 | 0x3AE4 | 0x6244 | 0x6344 |
0x51 (81) | 0xF2FA | 0x7AF8 | 0x7AFA | 0xE2FA | 0xE2FA |
0x52 (82) | 0xF3DA | 0x7BD8 | 0x7BDA | 0xE3DA | 0xE3DA |
0x53 (83) | 0xF2D0 | 0x7ACE | 0x7AD0 | 0xE2D0 | 0xE2D0 |
0x54 (84) | 0xF2DE | 0x7ADC | 0x7ADE | 0xE2DE | 0xE2DE |
0x55 (85) | 0xF50E | 0x7D0C | 0x7D0E | 0xE50E | 0xE50E |
0x56 (86) | 0xF13A | 0x7938 | 0x793A | 0xE13A | 0xE13A |
0x57 (87) | 0x62FA | 0x3B98 | 0x3B9A | 0x62FA | 0x63FA |
0x58 (88) | 0x6308 | 0x3BA6 | 0x3BA8 | 0x6308 | 0x6408 |
0x59 (89) | 0x6626 | 0x3EC4 | 0x3EC6 | 0x6626 | 0x6726 |
0x5A (90) | 0x635C | 0x3BFA | 0x3BFC | 0x635C | 0x645C |
0x5B (91) | 0x636A | 0x3C08 | 0x3C0A | 0x636A | 0x646A |
0x5C (92) | 0x6378 | 0x3C16 | 0x3C18 | 0x6378 | 0x6478 |
0x5D (93) | 0x6386 | 0x3C24 | 0x3C26 | 0x6386 | 0x6486 |
0x5E (94) | 0x6634 | 0x3ED2 | 0x3ED4 | 0x6634 | 0x6734 |
0x5F (95) | 0x6642 | 0x3EE0 | 0x3EE2 | 0x6642 | 0x6742 |
0x60 (96) | 0x6650 | 0x3EEE | 0x3EF0 | 0x6650 | 0x6750 |
0x61 (97) | 0x665E | 0x3EFC | 0x3EFE | 0x665E | 0x675E |
0x62 (98) | 0x666C | 0x3F0A | 0x3F0C | 0x666C | 0x676C |
0x63 (99) | 0xF626 | 0x7E24 | 0x7E26 | 0xE626 | 0xE626 |
0x64 (100) | 0x63B0 | 0x3C4E | 0x3C50 | 0x63B0 | 0x64B0 |
0x65 (101) | 0x63BE | 0x3C5C | 0x3C5E | 0x63BE | 0x64BE |
0x66 (102) | 0x63CC | 0x3C6A | 0x3C6C | 0x63CC | 0x64CC |
0x67 (103) | 0x63DA | 0x3C78 | 0x3C7A | 0x63DA | 0x64DA |
0x68 (104) | 0xF4BA | 0x7CB8 | 0x7CBA | 0xE4BA | 0xE4BA |
0x69 (105) | 0xF084 | 0x7882 | 0x7884 | 0xE084 | 0xE084 |
0x6A (106) | 0xF0CA | 0x78C8 | 0x78CA | 0xE0CA | 0xE0CA |
0x6B (107) | 0xF228 | 0x7A26 | 0x7A28 | 0xE228 | 0xE228 |
0x6C (108) | 0xF27C | 0x7A7A | 0x7A7C | 0xE27C | 0xE27C |
0x6D (109) | 0xF28A | 0x7A88 | 0x7A8A | 0xE28A | 0xE28A |
0x6E (110) | 0x6180 | 0x3A1E | 0x3A20 | 0x6180 | 0x6280 |
0x6F (111) | 0xF308 | 0x7B06 | 0x7B08 | 0xE308 | 0xE308 |
0x70 (112) | 0xF316 | 0x7B14 | 0x7B16 | 0xE316 | 0xE316 |
0x71 (113) | 0xF324 | 0x7B22 | 0x7B24 | 0xE324 | 0xE324 |
0x72 (114) | 0xF332 | 0x7B30 | 0x7B32 | 0xE332 | 0xE332 |
0x73 (115) | 0xF340 | 0x7B3E | 0x7B40 | 0xE340 | 0xE340 |
0x74 (116) | 0xF34E | 0x7B4C | 0x7B4E | 0xE34E | 0xE34E |
0x75 (117) | 0xF35C | 0x7B5A | 0x7B5C | 0xE35C | 0xE35C |
0x76 (118) | 0xF36A | 0x7B68 | 0x7B6A | 0xE36A | 0xE36A |
0x77 (119) | 0xF378 | 0x7B76 | 0x7B78 | 0xE378 | 0xE378 |
0x78 (120) | 0xF386 | 0x7B84 | 0x7B86 | 0xE386 | 0xE386 |
0x79 (121) | 0xF394 | 0x7B92 | 0x7B94 | 0xE394 | 0xE394 |
0x7A (122) | 0x6084 | 0x3922 | 0x3924 | 0x6084 | 0x6184 |
0x7B (123) | 0x6102 | 0x39A0 | 0x39A2 | 0x6102 | 0x6202 |
0x7C (124) | 0x6164 | 0x3A02 | 0x3A04 | 0x6164 | 0x6264 |
0x7D (125) | 0x6172 | 0x3A10 | 0x3A12 | 0x6172 | 0x6272 |
0x7E (126) | 0x60A0 | 0x393E | 0x3940 | 0x60A0 | 0x61A0 |
0x7F (127) | 0x618E | 0x3A2C | 0x3A2E | 0x618E | 0x628E |
0x80 (128) | 0xF3F6 | 0x7BF4 | 0x7BF6 | 0xE3F6 | 0xE3F6 |
0x81 (129) | 0xF404 | 0x7C02 | 0x7C04 | 0xE404 | 0xE404 |
0x82 (130) | 0x6022 | 0x38C0 | 0x38C2 | 0x6022 | 0x6122 |
0x83 (131) | 0xF014 | 0x7812 | 0x7814 | 0xE014 | 0xE014 |
0x84 (132) | 0xF022 | 0x7820 | 0x7822 | 0xE022 | 0xE022 |
0x85 (133) | 0xF030 | 0x782E | 0x7830 | 0xE030 | 0xE030 |
0x86 (134) | 0xF03E | 0x783C | 0x783E | 0xE03E | 0xE03E |
0x87 (135) | 0xF04C | 0x784A | 0x784C | 0xE04C | 0xE04C |
0x88 (136) | 0xF148 | 0x7946 | 0x7948 | 0xE148 | 0xE148 |
0x89 (137) | 0xF164 | 0x7962 | 0x7964 | 0xE164 | 0xE164 |
0x8A (138) | 0xF172 | 0x7970 | 0x7972 | 0xE172 | 0xE172 |
0x8B (139) | 0xF180 | 0x797E | 0x7980 | 0xE180 | 0xE180 |
0x8C (140) | 0xF18E | 0x798C | 0x798E | 0xE18E | 0xE18E |
0x8D (141) | 0xF05A | 0x7858 | 0x785A | 0xE05A | 0xE05A |
0x8E (142) | 0xF068 | 0x7866 | 0x7868 | 0xE068 | 0xE068 |
0x8F (143) | 0xF076 | 0x7874 | 0x7876 | 0xE076 | 0xE076 |
0x90 (144) | 0x60E6 | 0x3984 | 0x3986 | 0x60E6 | 0x61E6 |
0x91 (145) | 0x60F4 | 0x3992 | 0x3994 | 0x60F4 | 0x61F4 |
0x92 (146) | 0xF5C4 | 0x7DC2 | 0x7DC4 | 0xE5C4 | 0xE5C4 |
0x93 (147) | 0xF5D2 | 0x7DD0 | 0x7DD2 | 0xE5D2 | 0xE5D2 |
0x94 (148) | 0xF5E0 | 0x7DDE | 0x7DE0 | 0xE5E0 | 0xE5E0 |
0x95 (149) | 0x65EE | 0x3E8C | 0x3E8E | 0x65EE | 0x66EE |
0x96 (150) | 0xF0BC | 0x78BA | 0x78BC | 0xE0BC | 0xE0BC |
0x97 (151) | 0x634E | 0x3BEC | 0x3BEE | 0x634E | 0x644E |
0x98 (152) | 0xF12C | 0x792A | 0x792C | 0xE12C | 0xE12C |
0x99 (153) | 0xF4C8 | 0x7CC6 | 0x7CC8 | 0xE4C8 | 0xE4C8 |
0x9A (154) | 0xF4D6 | 0x7CD4 | 0x7CD6 | 0xE4D6 | 0xE4D6 |
0x9B (155) | 0xF0AE | 0x78AC | 0x78AE | 0xE0AE | 0xE0AE |
0x9C (156) | 0x603E | 0x38DC | 0x38DE | 0x603E | 0x613E |
0x9D (157) | 0x604C | 0x38EA | 0x38EC | 0x604C | 0x614C |
0x9E (158) | 0x6252 | 0x3AF0 | 0x3AF2 | 0x6252 | 0x6352 |
0x9F (159) | 0xF19C | 0x799A | 0x799C | 0xE19C | 0xE19C |
0xA0 (160) | 0xF1AA | 0x79A8 | 0x79AA | 0xE1AA | 0xE1AA |
0xA1 (161) | 0xF1B8 | 0x79B6 | 0x79B8 | 0xE1B8 | 0xE1B8 |
0xA2 (162) | 0xF1C6 | 0x79C4 | 0x79C6 | 0xE1C6 | 0xE1C6 |
0xA3 (163) | 0xF1E2 | 0x79E0 | 0x79E2 | 0xE1E2 | 0xE1E2 |
0xA4 (164) | 0xF570 | 0x7D6E | 0x7D70 | 0xE570 | 0xE570 |
0xA5 (165) | 0xF57E | 0x7D7C | 0x7D7E | 0xE57E | 0xE57E |
0xA6 (166) | 0xF58C | 0x7D8A | 0x7D8C | 0xE58C | 0xE58C |
0xA7 (167) | 0xF59A | 0x7D98 | 0x7D9A | 0xE59A | 0xE59A |
0xA8 (168) | 0xF5A8 | 0x7DA6 | 0x7DA8 | 0xE5A8 | 0xE5A8 |
0xA9 (169) | 0xF5B6 | 0x7DB4 | 0x7DB6 | 0xE5B6 | 0xE5B6 |
0xAA (170) | 0xF3BE | 0x7BBC | 0x7BBE | 0xE3BE | 0xE3BE |
0xAB (171) | 0xF3CC | 0x7BCA | 0x7BCC | 0xE3CC | 0xE3CC |
0xAC (172) | 0xF2EC | 0x7AEA | 0x7AEC | 0xE2EC | 0xE2EC |
0xAD (173) | 0xF3E8 | 0x7BE6 | 0x7BE8 | 0xE3E8 | 0xE3E8 |
0xAE (174) | 0x626E | 0x3B0C | 0x3B0E | 0x626E | 0x636E |
0xAF (175) | 0x627C | 0x3B1A | 0x3B1C | 0x627C | 0x637C |
0xB0 (176) | 0x628A | 0x3B28 | 0x3B2A | 0x628A | 0x638A |
0xB1 (177) | 0x6298 | 0x3B36 | 0x3B38 | 0x6298 | 0x6398 |
0xB2 (178) | 0x62A6 | 0x3B44 | 0x3B46 | 0x62A6 | 0x63A6 |
0xB3 (179) | 0x62B4 | 0x3B52 | 0x3B54 | 0x62B4 | 0x63B4 |
0xB4 (180) | 0x62C2 | 0x3B60 | 0x3B62 | 0x62C2 | 0x63C2 |
0xB5 (181) | 0x62D0 | 0x3B6E | 0x3B70 | 0x62D0 | 0x63D0 |
0xB6 (182) | 0x6394 | 0x3C32 | 0x3C34 | 0x6394 | 0x6494 |
0xB7 (183) | 0x63A2 | 0x3C40 | 0x3C42 | 0x63A2 | 0x64A2 |
0xB8 (184) | 0x63E8 | 0x3C86 | 0x3C88 | 0x63E8 | 0x64E8 |
0xB9 (185) | 0x63F6 | 0x3C94 | 0x3C96 | 0x63F6 | 0x64F6 |
0xBA (186) | 0xF696 | 0x7E94 | 0x7E96 | 0xE696 | 0xE696 |
0xBB (187) | 0xF6A4 | 0x7EA2 | 0x7EA4 | 0xE6A4 | 0xE6A4 |
0xBC (188) | 0xF6B2 | 0x7EB0 | 0x7EB2 | 0xE6B2 | 0xE6B2 |
0xBD (189) | 0xF6C0 | 0x7EBE | 0x7EC0 | 0xE6C0 | 0xE6C0 |
0xBE (190) | 0xF6CE | 0x7ECC | 0x7ECE | 0xE6CE | 0xE6CE |
0xBF (191) | 0xF6DC | 0x7EDA | 0x7EDC | 0xE6DC | 0xE6DC |
0xC0 (192) | 0xF6EA | 0x7EE8 | 0x7EEA | 0xE6EA | 0xE6EA |
0xC1 (193) | 0xF6F8 | 0x7EF6 | 0x7EF8 | 0xE6F8 | 0xE6F8 |
0xC2 (194) | 0x6474 | 0x3D12 | 0x3D14 | 0x6474 | 0x6574 |
0xC3 (195) | 0xF49E | 0x7C9C | 0x7C9E | 0xE49E | 0xE49E |
0xC4 (196) | 0x6490 | 0x3D2E | 0x3D30 | 0x6490 | 0x6590 |
0xC5 (197) | 0x649E | 0x3D3C | 0x3D3E | 0x649E | 0x659E |
0xC6 (198) | 0x64AC | 0x3D4A | 0x3D4C | 0x64AC | 0x65AC |
0xC7 (199) | 0x64BA | 0x3D58 | 0x3D5A | 0x64BA | 0x65BA |
0xC8 (200) | 0x64C8 | 0x3D66 | 0x3D68 | 0x64C8 | 0x65C8 |
0xC9 (201) | 0x64D6 | 0x3D74 | 0x3D76 | 0x64D6 | 0x65D6 |
0xCA (202) | 0x64E4 | 0x3D82 | 0x3D84 | 0x64E4 | 0x65E4 |
0xCB (203) | 0x64F2 | 0x3D90 | 0x3D92 | 0x64F2 | 0x65F2 |
0xCC (204) | 0x6500 | 0x3D9E | 0x3DA0 | 0x6500 | 0x6600 |
0xCD (205) | 0x650E | 0x3DAC | 0x3DAE | 0x650E | 0x660E |
0xCE (206) | 0x651C | 0x3DBA | 0x3DBC | 0x651C | 0x661C |
0xCF (207) | 0x652A | 0x3DC8 | 0x3DCA | 0x652A | 0x662A |
0xD0 (208) | 0x6538 | 0x3DD6 | 0x3DD8 | 0x6538 | 0x6638 |
0xD1 (209) | 0x6546 | 0x3DE4 | 0x3DE6 | 0x6546 | 0x6646 |
0xD2 (210) | 0x6554 | 0x3DF2 | 0x3DF4 | 0x6554 | 0x6654 |
0xD3 (211) | 0x6562 | 0x3E00 | 0x3E02 | 0x6562 | 0x6662 |
0xD4 (212) | 0x6570 | 0x3E0E | 0x3E10 | 0x6570 | 0x6670 |
0xD5 (213) | 0x657E | 0x3E1C | 0x3E1E | 0x657E | 0x667E |
0xD6 (214) | 0x658C | 0x3E2A | 0x3E2C | 0x658C | 0x668C |
0xD7 (215) | 0x659A | 0x3E38 | 0x3E3A | 0x659A | 0x669A |
0xD8 (216) | 0x65A8 | 0x3E46 | 0x3E48 | 0x65A8 | 0x66A8 |
0xD9 (217) | 0x65B6 | 0x3E54 | 0x3E56 | 0x65B6 | 0x66B6 |
0xDA (218) | 0x65C4 | 0x3E62 | 0x3E64 | 0x65C4 | 0x66C4 |
0xDB (219) | 0x65D2 | 0x3E70 | 0x3E72 | 0x65D2 | 0x66D2 |
0xDC (220) | 0x65E0 | 0x3E7E | 0x3E80 | 0x65E0 | 0x66E0 |
0xDD (221) | 0xF4E4 | 0x7CE2 | 0x7CE4 | 0xE4E4 | 0xE4E4 |
0xDE (222) | 0xF412 | 0x7C10 | 0x7C12 | 0xE412 | 0xE412 |
0xDF (223) | 0xF420 | 0x7C1E | 0x7C20 | 0xE420 | 0xE420 |
0xE0 (224) | 0xF42E | 0x7C2C | 0x7C2E | 0xE42E | 0xE42E |
0xE1 (225) | 0xF43C | 0x7C3A | 0x7C3C | 0xE43C | 0xE43C |
0xE2 (226) | 0xF44A | 0x7C48 | 0x7C4A | 0xE44A | 0xE44A |
0xE3 (227) | 0xF458 | 0x7C56 | 0x7C58 | 0xE458 | 0xE458 |
0xE4 (228) | 0xF466 | 0x7C64 | 0x7C66 | 0xE466 | 0xE466 |
0xE5 (229) | 0xF474 | 0x7C72 | 0x7C74 | 0xE474 | 0xE474 |
0xE6 (230) | 0xF482 | 0x7C80 | 0x7C82 | 0xE482 | 0xE482 |
0xE7 (231) | 0xF490 | 0x7C8E | 0x7C90 | 0xE490 | 0xE490 |
0xE8 (232) | 0x6482 | 0x3D20 | 0x3D22 | 0x6482 | 0x6582 |
0xE9 (233) | 0xF4AC | 0x7CAA | 0x7CAC | 0xE4AC | 0xE4AC |
0xF7 (247) | 0x667A | 0x3F18 | 0x3F1A | 0x667A | 0x677A |
0xF8 (248) | 0x66CE | 0x3F6C | 0x3F6E | 0x66CE | 0x67CE |
0xF9 (249) | 0x66DC | 0x3F7A | 0x3F7C | 0x66DC | 0x67DC |
0xFA (250) | 0x66EA | 0x3F88 | 0x3F8A | 0x66EA | 0x67EA |
0xFB (251) | 0x66F8 | 0x3F96 | 0x3F98 | 0x66F8 | 0x67F8 |
0xFC (252) | 0xF65E | 0x7E5C | 0x7E5E | 0xE65E | 0xE65E |
0xFD (253) | 0xF66C | 0x7E6A | 0x7E6C | 0xE66C | 0xE66C |
0xFE (254) | 0xF67A | 0x7E78 | 0x7E7A | 0xE67A | 0xE67A |
0xFF (255) | 0xF688 | 0x7E86 | 0x7E88 | 0xE688 | 0xE688 |
DTC (hex) 0x00 |
DTC (dec) 0 |
DTC Suffix (hex) 0x00 |
DTC Suffix (dec) 0 |
DTC String 00282803020302000102032800FF |
0x00 | 0 | 0x00 | 0 | 00282803020302000102032800FF |
0x01 | 1 | 0x03 | 3 | 01282806060606000102032803FF |
0x02 | 2 | 0x27 | 39 | 02C8C805020205000102032827FF |
0x03 | 3 | 0x27 | 39 | 03282804010104000102032827FF |
0x04 | 4 | 0x27 | 39 | 04282804010104000102032827FF |
0x05 | 5 | 0x27 | 39 | 05282804010104000102032827FF |
0x06 | 6 | 0x00 | 0 | 06010A0101010A000102032800FF |
0x06 | 6 | 0x00 | 0 | 06282803020302000102032800FF |
0x06 | 6 | 0x01 | 1 | 06010A0101010A000102032801FF |
0x06 | 6 | 0x01 | 1 | 06282803020302000102032801FF |
0x06 | 6 | 0x23 | 35 | 06010A0101010A000102032823FF |
0x07 | 7 | 0x27 | 39 | 07282803020302001102032827FF |
0x08 | 8 | 0x00 | 0 | 08282803020302001102032800FF |
0x09 | 9 | 0x01 | 1 | 09102002010102000102032801FF |
0x0A | 10 | 0x27 | 39 | 0A282803020302001102032827FF |
0x0B | 11 | 0x00 | 0 | 0B282803020302001102032800FF |
0x0B | 11 | 0x01 | 1 | 0B282803020302001102032801FF |
0x0C | 12 | 0x25 | 37 | 0C28FA0301011400011D032825FF |
0x0D | 13 | 0x25 | 37 | 0D28FA0301011400011C032825FF |
0x0E | 14 | 0x00 | 0 | 0E2828030202030A0402032800FF |
0x0E | 14 | 0x03 | 3 | 0E2828030202030A0402032803FF |
0x0F | 15 | 0x25 | 37 | 0FC8C804010104000108092825FF |
0x10 | 16 | 0x27 | 39 | 10282804010104000102032827FF |
0x10 | 16 | 0x27 | 39 | 10282808010108000102032827FF |
0x11 | 17 | 0x00 | 0 | 11141403020302000102033200FF |
0x11 | 17 | 0x01 | 1 | 11141403020302000102033201FF |
0x11 | 17 | 0x01 | 1 | 1114140302030200011A1B2801FF |
0x12 | 18 | 0x00 | 0 | 12282802010102000102032800FF |
0x12 | 18 | 0x01 | 1 | 12282801010101030A0B142801FF |
0x13 | 19 | 0x27 | 39 | 13285002010102000102032827FF |
0x14 | 20 | 0x00 | 0 | 14282802010102000102032800FF |
0x15 | 21 | 0x27 | 39 | 152828030A030A001102032827FF |
0x16 | 22 | 0x27 | 39 | 162828030A030A001102032827FF |
0x17 | 23 | 0x01 | 1 | 17281404020204000111032801FF |
0x18 | 24 | 0x01 | 1 | 18281404020204000111032801FF |
0x19 | 25 | 0x01 | 1 | 19281404020204000111032801FF |
0x1A | 26 | 0x00 | 0 | 1A281404020204000111032800FF |
0x1B | 27 | 0x00 | 0 | 1B060601010101000A05032800FF |
0x1B | 27 | 0x27 | 39 | 1B060601010101000A05032827FF |
0x1C | 28 | 0x00 | 0 | 1C282802010102000C02032800FF |
0x1C | 28 | 0x03 | 3 | 1C0A280101010113140A0B2803FF |
0x1D | 29 | 0x27 | 39 | 1DC8C805020205000102032827FF |
0x1E | 30 | 0x2D | 45 | 1E01010101010100010203282DFF |
0x1F | 31 | 0x27 | 39 | 1F282804010104000102032827FF |
0x20 | 32 | 0x27 | 39 | 20282804010104000102032827FF |
0x21 | 33 | 0x27 | 39 | 21282804010104000102032827FF |
0x22 | 34 | 0x00 | 0 | 22282804010104000102032800FF |
0x23 | 35 | 0x00 | 0 | 23282804010104000102032800FF |
0x24 | 36 | 0x27 | 39 | 24282803020203000119352827FF |
0x25 | 37 | 0x27 | 39 | 25502802020203000120032827FF |
0x25 | 37 | 0x27 | 39 | 25502803020203000120032827FF |
0x26 | 38 | 0x27 | 39 | 26502802020203000121032827FF |
0x26 | 38 | 0x27 | 39 | 26502803020203000121032827FF |
0x27 | 39 | 0x03 | 3 | 27502803020203000122032803FF |
0x27 | 39 | 0x27 | 39 | 27502803020203000122032827FF |
0x28 | 40 | 0x03 | 3 | 28502803020203000123032803FF |
0x28 | 40 | 0x27 | 39 | 28502803020203000123032827FF |
0x29 | 41 | 0x25 | 37 | 29A0A004010104000112032825FF |
0x2A | 42 | 0x01 | 1 | 2AC82801010201000104032801FF |
0x2B | 43 | 0x00 | 0 | 2B282802010102001802032800FF |
0x2B | 43 | 0x01 | 1 | 2B282802010102001802032801FF |
0x2B | 43 | 0x25 | 37 | 2B282802010102001802032825FF |
0x2C | 44 | 0x01 | 1 | 2C3C3C04010104000102122801FF |
0x2D | 45 | 0x09 | 9 | 2D282802010102000102032809FF |
0x2D | 45 | 0x2D | 45 | 2D28280201010200010203282DFF |
0x2E | 46 | 0x00 | 0 | 2E282803020302000102032800FF |
0x2F | 47 | 0x00 | 0 | 2F282803020302000102032800FF |
0x30 | 48 | 0x03 | 3 | 30285002010102000102032803FF |
0x31 | 49 | 0x00 | 0 | 31282803020302000102032800FF |
0x32 | 50 | 0x01 | 1 | 32281404020204000111032801FF |
0x33 | 51 | 0x01 | 1 | 33281404020204000111032801FF |
0x34 | 52 | 0x01 | 1 | 34281404020204000111032801FF |
0x35 | 53 | 0x03 | 3 | 35FA010101FA01000A0B032803FF |
0x36 | 54 | 0x01 | 1 | 362850020101020001020D2801FF |
0x37 | 55 | 0x00 | 0 | 37281404020204000111032800FF |
0x38 | 56 | 0x00 | 0 | 38282803020302000102032800FF |
0x39 | 57 | 0x00 | 0 | 39A0A004010104000112032800FF |
0x3A | 58 | 0x01 | 1 | 3A28320501010A00010D032801FF |
0x3B | 59 | 0x01 | 1 | 3B28320501010A00010E032801FF |
0x3C | 60 | 0x01 | 1 | 3C4B4B0501010500010D032801FF |
0x3C | 60 | 0x25 | 37 | 3C4B4B0501010500010D032825FF |
0x3D | 61 | 0x01 | 1 | 3D4B4B0501010500010E032801FF |
0x3D | 61 | 0x25 | 37 | 3D4B4B0501010500010E032825FF |
0x3E | 62 | 0x00 | 0 | 3E282803020302000102032800FF |
0x3F | 63 | 0x00 | 0 | 3F285002010102000102032800FF |
0x40 | 64 | 0x00 | 0 | 40282803020302000102032800FF |
0x41 | 65 | 0x00 | 0 | 41142802010102000117032800FF |
0x42 | 66 | 0x01 | 1 | 42010101010101000102032801FF |
0x43 | 67 | 0x27 | 39 | 432828030A030A001102032827FF |
0x44 | 68 | 0x00 | 0 | 44141403020302000102033200FF |
0x44 | 68 | 0x01 | 1 | 44141403020302000102033201FF |
0x44 | 68 | 0x01 | 1 | 441414030203020001051B2801FF |
0x45 | 69 | 0x01 | 1 | 45102002010102000102032801FF |
0x46 | 70 | 0x01 | 1 | 46102002010102000102032801FF |
0x46 | 70 | 0x01 | 1 | 46102002010202000102032801FF |
0x47 | 71 | 0x00 | 0 | 47102002010102000102032800FF |
0x47 | 71 | 0x01 | 1 | 47102002010102000102032801FF |
0x48 | 72 | 0x27 | 39 | 482828030A030A001102032827FF |
0x49 | 73 | 0x25 | 37 | 4964C802010102000102032825FF |
0x49 | 73 | 0x25 | 37 | 49C8C802010102000102032825FF |
0x4A | 74 | 0x00 | 0 | 4A2828030A030A001102032800FF |
0x4B | 75 | 0x00 | 0 | 4B2828030A030A001102032800FF |
0x4C | 76 | 0x01 | 1 | 4C142802010102000102032801FF |
0x4C | 76 | 0x01 | 1 | 4CC8C804010104000102032801FF |
0x4D | 77 | 0x25 | 37 | 4D14280201010200010A032825FF |
0x4E | 78 | 0x25 | 37 | 4E14280201010200010B032825FF |
0x4F | 79 | 0x01 | 1 | 4F282802010102000102032801FF |
0x50 | 80 | 0x01 | 1 | 500A0101010A01000105032801FF |
0x51 | 81 | 0x00 | 0 | 5128280302030210040A032800FF |
0x51 | 81 | 0x01 | 1 | 5128280302030210040A032801FF |
0x52 | 82 | 0x00 | 0 | 52285002010102000102032800FF |
0x53 | 83 | 0x00 | 0 | 532828030A030A001102032800FF |
0x54 | 84 | 0x00 | 0 | 542828030A030A001102032800FF |
0x55 | 85 | 0x02 | 2 | 550A0A01010101000117032802FF |
0x56 | 86 | 0x09 | 9 | 56010A0101010A000102032809FF |
0x57 | 87 | 0x01 | 1 | 5728FA0301011400011E032801FF |
0x57 | 87 | 0x25 | 37 | 5728FA0301011400011E032825FF |
0x58 | 88 | 0x01 | 1 | 5828FA0301011400011F032801FF |
0x58 | 88 | 0x25 | 37 | 5828FA0301011400011F032825FF |
0x59 | 89 | 0x01 | 1 | 59282814141414000102032801FF |
0x5A | 90 | 0x00 | 0 | 5A01010101010100013B262800FF |
0x5B | 91 | 0x00 | 0 | 5B01010101010100013B272800FF |
0x5C | 92 | 0x01 | 1 | 5C0101010101013B011E3A2801FF |
0x5C | 92 | 0x25 | 37 | 5C0101010101013B011E3A2825FF |
0x5D | 93 | 0x01 | 1 | 5D0101010101013B011F3A2801FF |
0x5D | 93 | 0x25 | 37 | 5D0101010101013B011F3A2825FF |
0x5E | 94 | 0x00 | 0 | 5E040101010401001102032800FF |
0x5E | 94 | 0x01 | 1 | 5E040101010401001102032801FF |
0x5F | 95 | 0x00 | 0 | 5F040101010401001102032800FF |
0x5F | 95 | 0x01 | 1 | 5F040101010401001102032801FF |
0x60 | 96 | 0x00 | 0 | 60282802010102000102032800FF |
0x60 | 96 | 0x00 | 0 | 60282802010102000A020C2800FF |
0x60 | 96 | 0x00 | 0 | 60282803020302000102032800FF |
0x60 | 96 | 0x25 | 37 | 60282802010102000A020C2825FF |
0x61 | 97 | 0x00 | 0 | 61282803020302000102032800FF |
0x62 | 98 | 0x00 | 0 | 62282803020302000102032800FF |
0x63 | 99 | 0x01 | 1 | 63282814141414000102032801FF |
0x64 | 100 | 0x00 | 0 | 64282803020302000102052800FF |
0x65 | 101 | 0x00 | 0 | 65282803020302000102052800FF |
0x66 | 102 | 0x00 | 0 | 66282803020302000102052800FF |
0x67 | 103 | 0x00 | 0 | 67282803020302000102052800FF |
0x68 | 104 | 0x00 | 0 | 68282803020302000102032800FF |
0x69 | 105 | 0x25 | 37 | 69010101010101000102032825FF |
0x6A | 106 | 0x01 | 1 | 6A010101010101000102032801FF |
0x6A | 106 | 0x09 | 9 | 6A010101010101000102032809FF |
0x6B | 107 | 0x03 | 3 | 6B010101010101000102032803FF |
0x6B | 107 | 0x2F | 47 | 6B01010101010100010203282FFF |
0x6C | 108 | 0x00 | 0 | 6C320A05010105000102032800FF |
0x6D | 109 | 0x00 | 0 | 6D320A05010105000102032800FF |
0x6E | 110 | 0x00 | 0 | 6E285002010102000102032800FF |
0x6E | 110 | 0x03 | 3 | 6E285002010102000102032803FF |
0x6F | 111 | 0x01 | 1 | 6F96960501010A000102032801FF |
0x6F | 111 | 0x25 | 37 | 6F96960501010A000102032825FF |
0x70 | 112 | 0x01 | 1 | 7096960501010A000102032801FF |
0x70 | 112 | 0x25 | 37 | 7096960501010A000102032825FF |
0x71 | 113 | 0x00 | 0 | 71282828012801001102032800FF |
0x72 | 114 | 0x00 | 0 | 72282828012801001102032800FF |
0x73 | 115 | 0x01 | 1 | 73142802010102000102032801FF |
0x74 | 116 | 0x00 | 0 | 740A0101010201000402032800FF |
0x75 | 117 | 0x00 | 0 | 750A0101010101000402032800FF |
0x76 | 118 | 0x01 | 1 | 76323205010105000102032801FF |
0x76 | 118 | 0x25 | 37 | 76323205010105000102032825FF |
0x77 | 119 | 0x01 | 1 | 77323205010105000102032801FF |
0x77 | 119 | 0x25 | 37 | 77323205010105000102032825FF |
0x78 | 120 | 0x01 | 1 | 78FAFA05010105000102032801FF |
0x78 | 120 | 0x25 | 37 | 78C8C805010105000102032825FF |
0x79 | 121 | 0x01 | 1 | 79010101010101000102032801FF |
0x79 | 121 | 0x25 | 37 | 79010101010101000102032825FF |
0x7A | 122 | 0x2D | 45 | 7A01010101010100010203282DFF |
0x7B | 123 | 0x00 | 0 | 7B010A0101010A000102032800FF |
0x7B | 123 | 0x00 | 0 | 7B282803020302000102032800FF |
0x7B | 123 | 0x01 | 1 | 7B010A0101010A000102032801FF |
0x7B | 123 | 0x01 | 1 | 7B282803020302000102032801FF |
0x7B | 123 | 0x23 | 35 | 7B010A0101010A000102032823FF |
0x7C | 124 | 0x00 | 0 | 7C282803020302000102032800FF |
0x7C | 124 | 0x03 | 3 | 7CFA0A0101010113140A0B2803FF |
0x7D | 125 | 0x00 | 0 | 7D010101010101000102032800FF |
0x7D | 125 | 0x00 | 0 | 7D141402020101000102032800FF |
0x7D | 125 | 0x03 | 3 | 7D010101010101000102032803FF |
0x7D | 125 | 0x03 | 3 | 7D141402020101000102032803FF |
0x7E | 126 | 0x09 | 9 | 7E010101010101000102032809FF |
0x7F | 127 | 0x00 | 0 | 7F010101010101374647392800FF |
0x7F | 127 | 0x27 | 39 | 7F010101010101374647392827FF |
0x80 | 128 | 0x25 | 37 | 80FAFA01050105000102032825FF |
0x81 | 129 | 0x01 | 1 | 8101010101010100014A4B2801FF |
0x82 | 130 | 0x01 | 1 | 82010101010101000102032801FF |
0x83 | 131 | 0x09 | 9 | 83191901010101000102032809FF |
0x84 | 132 | 0x09 | 9 | 84010A0101010A000102032809FF |
0x85 | 133 | 0x09 | 9 | 85010A0101010A000102032809FF |
0x86 | 134 | 0x09 | 9 | 86010A0101010A000102032809FF |
0x87 | 135 | 0x25 | 37 | 87282803020302000102032825FF |
0x88 | 136 | 0x03 | 3 | 88141405020205000107062803FF |
0x88 | 136 | 0x25 | 37 | 88141405020205000107062825FF |
0x88 | 136 | 0x27 | 39 | 88141405020205000107062827FF |
0x89 | 137 | 0x03 | 3 | 89010101010101000102032803FF |
0x89 | 137 | 0x03 | 3 | 89285002010102000102032803FF |
0x8A | 138 | 0x00 | 0 | 8A282803020302000102032800FF |
0x8B | 139 | 0x09 | 9 | 8B01010101010100010A032809FF |
0x8C | 140 | 0x01 | 1 | 8C010101010101000102032801FF |
0x8C | 140 | 0x01 | 1 | 8C102002010102000102032801FF |
0x8D | 141 | 0x00 | 0 | 8D010101010101394E0A042800FF |
0x8D | 141 | 0x01 | 1 | 8D010101010101394E0A042801FF |
0x8D | 141 | 0x05 | 5 | 8D010101010101394E0A042805FF |
0x8E | 142 | 0x01 | 1 | 8E010101010101000102032801FF |
0x8E | 142 | 0x01 | 1 | 8E142802010102000102032801FF |
0x8F | 143 | 0x03 | 3 | 8F285002010102000102032803FF |
0x90 | 144 | 0x25 | 37 | 9028C80301011400012B2D2825FF |
0x91 | 145 | 0x25 | 37 | 9128C80301011400012C2E2825FF |
0x92 | 146 | 0x00 | 0 | 92010101010101000102032800FF |
0x93 | 147 | 0x00 | 0 | 93010101010101000102032800FF |
0x94 | 148 | 0x34 | 52 | 943C3C02040103000102032834FF |
0x95 | 149 | 0x01 | 1 | 95282803020302000102392801FF |
0x95 | 149 | 0x25 | 37 | 95282803020302000102392825FF |
0x96 | 150 | 0x2D | 45 | 9601010101010100010203282DFF |
0x97 | 151 | 0x00 | 0 | 97282803020203000102032800FF |
0x97 | 151 | 0x01 | 1 | 97282803020203000102032801FF |
0x98 | 152 | 0x00 | 0 | 9828280A28280A000102032800FF |
0x99 | 153 | 0x00 | 0 | 99282803020302000102032800FF |
0x9A | 154 | 0x00 | 0 | 9A282803020302000102032800FF |
0x9A | 154 | 0x00 | 0 | 9A285002010102000102032800FF |
0x9A | 154 | 0x25 | 37 | 9A285002010102000102032825FF |
0x9B | 155 | 0x2D | 45 | 9B01010101010100010203282DFF |
0x9C | 156 | 0x2D | 45 | 9C01010101010100010203282DFF |
0x9D | 157 | 0x2D | 45 | 9D01010101010100010203282DFF |
0x9E | 158 | 0x2D | 45 | 9E28280A28280A00010203282DFF |
0x9F | 159 | 0x01 | 1 | 9F102002010102000102032801FF |
0xA0 | 160 | 0x01 | 1 | A0102002010102000102032801FF |
0xA1 | 161 | 0x01 | 1 | A1102002010102000102032801FF |
0xA2 | 162 | 0x00 | 0 | A2C8C804010104000108092800FF |
0xA3 | 163 | 0x2D | 45 | A301010101010100010203282DFF |
0xA4 | 164 | 0x00 | 0 | A4282803020302000102032800FF |
0xA5 | 165 | 0x00 | 0 | A5282803020302000102032800FF |
0xA6 | 166 | 0x00 | 0 | A6010101010101000102032800FF |
0xA7 | 167 | 0x00 | 0 | A7010101010101000102032800FF |
0xA8 | 168 | 0x00 | 0 | A8010101010101000102032800FF |
0xA9 | 169 | 0x00 | 0 | A9010101010101000102032800FF |
0xAA | 170 | 0x27 | 39 | AA010101010101000102032827FF |
0xAB | 171 | 0x00 | 0 | AB010101010101000102032800FF |
0xAC | 172 | 0x00 | 0 | AC282803020302000102032800FF |
0xAD | 173 | 0x01 | 1 | AD280102010101000102032801FF |
0xAE | 174 | 0xA5 | 165 | AE010101010101480B024C50A5FF |
0xAE | 174 | 0xA5 | 165 | AE282828020228480B024C50A5FF |
0xAF | 175 | 0xA5 | 165 | AF010101010101490B024D50A5FF |
0xAF | 175 | 0xA5 | 165 | AF282828020228490B024D50A5FF |
0xB0 | 176 | 0x00 | 0 | B00101010101010A3738462800FF |
0xB0 | 176 | 0x23 | 35 | B00101010101010A3738462823FF |
0xB0 | 176 | 0x25 | 37 | B00101010101010A3738462825FF |
0xB1 | 177 | 0x00 | 0 | B10A0A03020302000102032800FF |
0xB1 | 177 | 0x00 | 0 | B1282803020302000102032800FF |
0xB1 | 177 | 0x01 | 1 | B10A0A03020302000102032801FF |
0xB2 | 178 | 0x25 | 37 | B201010101010100012F332825FF |
0xB3 | 179 | 0x25 | 37 | B3010101010101000130342825FF |
0xB4 | 180 | 0x00 | 0 | B4010101010101393738462800FF |
0xB4 | 180 | 0x27 | 39 | B4010101010101393738462827FF |
0xB5 | 181 | 0x00 | 0 | B5010101010101393738462800FF |
0xB5 | 181 | 0x01 | 1 | B5010101010101393738462801FF |
0xB6 | 182 | 0x01 | 1 | B6FAC802010102000102032801FF |
0xB7 | 183 | 0x01 | 1 | B7FAC802010102000102032801FF |
0xB8 | 184 | 0x27 | 39 | B8282828012801001102032827FF |
0xB9 | 185 | 0x27 | 39 | B9282828012801001102032827FF |
0xBA | 186 | 0x02 | 2 | BA282803020302000102032802FF |
0xBB | 187 | 0x02 | 2 | BB282803020302000102032802FF |
0xBC | 188 | 0x02 | 2 | BC282803020302000102032802FF |
0xBD | 189 | 0x02 | 2 | BD282803020302000102032802FF |
0xBE | 190 | 0x02 | 2 | BE282803020302000102032802FF |
0xBF | 191 | 0x02 | 2 | BF282803020302000102032802FF |
0xC0 | 192 | 0x00 | 0 | C0282803020302000102032800FF |
0xC0 | 192 | 0x02 | 2 | C0282803020302000102032802FF |
0xC1 | 193 | 0x00 | 0 | C1282803020302000102032800FF |
0xC1 | 193 | 0x02 | 2 | C1282803020302000102032802FF |
0xC2 | 194 | 0x09 | 9 | C2010101010101000102032809FF |
0xC3 | 195 | 0x09 | 9 | C364640A01010A000102282809FF |
0xC4 | 196 | 0xA5 | 165 | C40101010101010001020350A5FF |
0xC5 | 197 | 0xA5 | 165 | C50101010101010001020350A5FF |
0xC6 | 198 | 0xA5 | 165 | C60101010101010001020350A5FF |
0xC7 | 199 | 0xA5 | 165 | C70101010101010001020350A5FF |
0xC8 | 200 | 0xA5 | 165 | C80101010101010001020350A5FF |
0xC9 | 201 | 0xA5 | 165 | C90101010101010001020350A5FF |
0xCA | 202 | 0x00 | 0 | CA010101010101000102035000FF |
0xCB | 203 | 0x00 | 0 | CB010101010101000102035000FF |
0xCC | 204 | 0xA5 | 165 | CC0101010101010001020350A5FF |
0xCD | 205 | 0xA5 | 165 | CD0101010101010001020350A5FF |
0xCE | 206 | 0xA5 | 165 | CE0101010101010001020350A5FF |
0xCF | 207 | 0xA5 | 165 | CF0101010101010001020350A5FF |
0xD0 | 208 | 0xA5 | 165 | D00101010101010001020350A5FF |
0xD1 | 209 | 0xA5 | 165 | D10101010101010001020350A5FF |
0xD2 | 210 | 0xA5 | 165 | D20101010101010001020350A5FF |
0xD3 | 211 | 0x00 | 0 | D3010101010101000102035000FF |
0xD4 | 212 | 0x00 | 0 | D4010101010101000102035000FF |
0xD5 | 213 | 0xA5 | 165 | D50101010101010001020350A5FF |
0xD6 | 214 | 0x25 | 37 | D601010101010100012B242825FF |
0xD7 | 215 | 0x25 | 37 | D701010101010100012C252825FF |
0xD8 | 216 | 0x25 | 37 | D8010101010101000142442825FF |
0xD9 | 217 | 0x25 | 37 | D9010101010101000143452825FF |
0xDA | 218 | 0x25 | 37 | DAFA960302020300013E402825FF |
0xDA | 218 | 0x25 | 37 | DAFA960502020300013E402825FF |
0xDB | 219 | 0x25 | 37 | DBFA960302020300013F412825FF |
0xDB | 219 | 0x25 | 37 | DBFA960502020300013F412825FF |
0xDC | 220 | 0x34 | 52 | DC282802040103000102032834FF |
0xDD | 221 | 0x00 | 0 | DD010101010101000102032800FF |
0xDD | 221 | 0x00 | 0 | DD010101010101000102062800FF |
0xDD | 221 | 0x00 | 0 | DD282803020302000102032800FF |
0xDD | 221 | 0x25 | 37 | DD010101010101000102062825FF |
0xDE | 222 | 0x00 | 0 | DE282803020302000102032800FF |
0xDE | 222 | 0x01 | 1 | DE282803020302000102032801FF |
0xDF | 223 | 0x00 | 0 | DF282803020302000102032800FF |
0xDF | 223 | 0x00 | 0 | DFA0A004010104000102032800FF |
0xDF | 223 | 0x00 | 0 | DFA0A004010104000136172800FF |
0xDF | 223 | 0x03 | 3 | DFA0A004010104000136172803FF |
0xE0 | 224 | 0x00 | 0 | E0010101010101000102032800FF |
0xE0 | 224 | 0x00 | 0 | E0010101010101000136172800FF |
0xE0 | 224 | 0x00 | 0 | E0282803020302000102032800FF |
0xE1 | 225 | 0x00 | 0 | E1010101010101000102032800FF |
0xE1 | 225 | 0x00 | 0 | E1010101010101020A0B0C0A00FF |
0xE1 | 225 | 0x00 | 0 | E1282803020302000102032800FF |
0xE1 | 225 | 0x01 | 1 | E1010101010101020A0B0C0A01FF |
0xE1 | 225 | 0x25 | 37 | E1010101010101020A0B0C0A25FF |
0xE2 | 226 | 0x00 | 0 | E2010101010101000102032800FF |
0xE2 | 226 | 0x00 | 0 | E2010101010101020A0B0C0A00FF |
0xE2 | 226 | 0x00 | 0 | E2282803020302000102032800FF |
0xE2 | 226 | 0x25 | 37 | E2010101010101020A0B0C0A25FF |
0xE3 | 227 | 0x00 | 0 | E3010101010101000102032800FF |
0xE3 | 227 | 0x00 | 0 | E3282803020302000102032800FF |
0xE4 | 228 | 0x03 | 3 | E4010101010101000102032803FF |
0xE5 | 229 | 0x00 | 0 | E5010101010101000102032800FF |
0xE6 | 230 | 0x03 | 3 | E60101010101010F1002032803FF |
0xE6 | 230 | 0x27 | 39 | E60101010101010F1002032827FF |
0xE7 | 231 | 0x2D | 45 | E701010101010100010203282DFF |
0xE8 | 232 | 0x00 | 0 | E8010101010101120A3C3D2800FF |
0xE8 | 232 | 0x27 | 39 | E8010101010101120A3C3D2827FF |
0xE9 | 233 | 0x00 | 0 | E9282803020302000102032800FF |
0xF7 | 247 | 0x00 | 0 | F7282803020302000102032800FF |
0xF8 | 248 | 0x02 | 2 | F8282803020302000102032802FF |
0xF9 | 249 | 0x02 | 2 | F9282803020302000102032802FF |
0xFA | 250 | 0x02 | 2 | FA282803020302000102032802FF |
0xFB | 251 | 0x02 | 2 | FB282803020302000102032802FF |
0xFC | 252 | 0x00 | 0 | FC282803020302000102032800FF |
0xFC | 252 | 0x02 | 2 | FC282803020302000102032802FF |
0xFD | 253 | 0x00 | 0 | FD282803020302000102032800FF |
0xFD | 253 | 0x02 | 2 | FD282803020302000102032802FF |
0xFE | 254 | 0x00 | 0 | FE282803020302000102032800FF |
0xFE | 254 | 0x02 | 2 | FE282803020302000102032802FF |
0xFF | 255 | 0x00 | 0 | FF282803020302000102032800FF |
0xFF | 255 | 0x02 | 2 | FF282803020302000102032802FF |
