Comprehensive MSS54/MSS54HP DME Information
  • E46m3zcp
    Nope. Hardware differences are only related to year (HP vs non-HP). Firmware is different though.
    When you say it's only related to year, does it mean some late non-CSLs M3s are equipped with MSS54HPs ?
    Also do we know what changes the newer DME software versions (say 2009 vs 2006) bring ?
    How should I interpret the HEX data shown in this thread (the one showing the offset and bytes corresponding to options)? Is it the contents of the EEPROM memory ? What are the 0DA files ? Are they the exact binary program to be flashed onto the DME EEPROM ? So could I interpret and modify an ODA with say a text editor and enable/disable features, then flash it to my DME? I am very new to this, thanks for being patient with my noob questions
    Cheers!
  • Chris_de
    hey guys,
    i recently started with the mss54hp disassemlby in idapro.
    So as first step i searched for the locations where the can-registers are setup, but i'm already stuck at this point.
    I can see that many other registers are set but i cannot find the can-addressspace.
    I'm searching for addresses for can upwards 0xFFF080 - 0xFFF0A6 as stated in the MC68336/376 ref.manual.
    Can you help me getting started and find the right initial spots to look at?
    regards
    chris
  • bigjae46
    Yes, thank you! I need this thread!
  • heinzboehmer
    Originally posted by Andy2424 View Post
    sorry, since my mother tongue is not english, i do not understand the term flashes in the context.
    Can someone explain to me what that means? Misfire?
    thank you 👍
    Basically means to install the software onto the module. Usually also implies that all previous software is overwritten.
  • Andy2424
    thank you 👍
  • TropicalM3
    I have a 2006 M3 MSS54HP and I am replacing my ECU with a used one and I want to clone the used one from my original ECU, can I just do a full read using MSSflasher or BMWFlash and write it into the donor ECU? Would that be enough to start and drive the car?
  • E46 Adam
    The 60 flash limit (really 30 flash limit) is artificial and MSSFlasher can clear that. The physical limits are going to be on the order of 10-100k flashes.
    alright kinda cool knowing they can take 100000 Flashes, Thanks!
  • Slideways
    Can the flash limit be cleared after it has hit the 30/60 limit?
  • terra
    Originally posted by E46 Adam View Post
    does a DME take 60 flashes max throughout it's whole life even Mssflasher can't reset that 60 flash limit?
  • E46 Adam
    Originally posted by R3Z3N View Post
    ^Just use MSS Flasher to reset the flash counter.
  • rbg
    Yes you can DIY all of this.
    VIN is super easy with Tool32: https://www.ecuworx.co.uk/2016/02/26...f-with-tool32/
    You can either code out EWS or sync it to your car.
    Yay! Thank you so much for your explanation. I would've googled, but as we all know the best resource for our platform has been reborn :-)
  • heinzboehmer
    Originally posted by rbg View Post
    Ok I see. What about donor ECU begin coded for different VIN, will EWS module need to be coded off, can you DIY it?
  • rbg
    It can't. You need an HP (or a non-HP converted to HP spec) to run a MAP sensor.
  • heinzboehmer
    Hm... I thought non-HP DME can not run MAP software.
  • rbg
