Comprehensive MSS54/MSS54HP DME Information
  • elrichmeister
    Should be manufacturing date after 09/2003.
    Im right at the cusp i think, do we now when exactly on that month?
    My car has 2003-09-04 manufacture date, since its earlier in that month, I'm assuming its a non-hp
  • bmwfnatic
    Originally posted by BTB View Post
    Pardon my ignorance but ... is there an easy way to determine whether I have MSS54 or MSS54HP such as VIN later than XXXX? Would like to do an MSSMapper tune with a reduced redline (~7k RPM)
  • BTB
  • karter16
    Note: the below question relates to the 0401 CSL binary.
    Does anyone have any information on the 16x12 table at 0x8E42A (table pointer reference in Master binary program code, start of data points when viewing the table in TunerPro is 0xe464). x axis is engine speed and y axis is relative fill, I do not yet know the units of the cell values. I should be able to figure it out in more time by continuing with disassembly, but wondered if anyone else has any info on this?
Name:	Screenshot 2024-11-30 at 7.17.45 AM.png
  • sapote
    There's also some resistors: https://nam3forum.com/forums/forum/s...=2582#post2582
    ​​​​​​The pressure sensor is different too, so you either have to scale it differently in software or swap out the hardware.
    The ambient pressure sensor is used only for CSL as the DME needs to interpret the MAP sensor in the CSL intake, and so for non-CSL I don't think it's matter. No?
  • sapote
    Originally posted by sda2 View Post
    Wow, this document seems to be a detail DME control software block diagram and theory! All we need is the "C" source code.
    Or have anyone used a compiler or assemble to convert the binary file to 68376 assembly codes? C source is perfect but I am happy to work with assembly codes.
  • R3VM3UP
    Originally posted by E46m3zcp View Post
    I am having a hard time understanding the maps shown in the first post on this thread. One of the first steps of EFI tuning is to calibrate the volumetric efficiency table (for example, when fitting a CSL airbox or more aggressive camshafts, it increases the VE and the air-fuel ratio gets too lean, and a VE table calibration can remedy this) anyone knows how pro tuners do this on our MSS54/HP ??
    Non CSL software uses the MAF to essentially 'directly' measure airflow. The CSL runs primarily alpha N with some sort of compensation from the MAP sensor on the air rail. I'd imagine the pulsations in the MAP rail require significant filtering due to the small volume of the rail and proximity to the ports, so it cannot be used as the primary air charge estimation method. The main alpha-N VE table is KF_RF_N_AQ_REL, which is a function of engine speed and relative throttle opening.
    KF = map
    RF = relative filling
    N = engine speed
    AQ_REL = relative cross sectional opening​
  • dreamdrivedrift
    Just wanted to say: THANK YOU! I was able to do something (simple) and fix my sport mode memory (which was set to always on) with the help of this thread and multiple others. Really appreciate the work of the community in creating and documenting these resources, all in their spare time. They are invaluable; and I learned a lot in the process.
  • E46m3zcp
  • M3Dude
    Hi guys,
    I am trying to code out the SAP on my E46 M3, is there a write-up anywhere that can be followed on a step-by-step basis? Also, does anyone know what the code needs to be changed to so the system is no longer searching for it? I couldn't find it in the tables...
  • heinzboehmer
    Originally posted by cek View Post
    I have a line on an MSS54 but need an MSS54HP. Before I bite the bullet I need to know for sure this conversion is as easy as stated above. Can anyone confirm that this information is correct? Just replace the PROM chips?
  • cek
    My understand is the MSS54 vs MSS54HP only difference is the flash PROM chips, 256KB vs 512KB. So to convert the MSS54 board to MSS54HP, one needs to remove the 2 chips (512KB) from a S54HP then read and save the files using something like the chip programmer below, then program the files into the two new chips (512K), i.e. AM29F400BB-60SC
    from https://www.mouser.com/ProductDetail...W34bxMGA%3D%3D
    then solder the new programmed chips back to the S54 DME board and now it become a S54HP DME.
    Have anyone done this before?
  • R3Z3N
    ^Translated to English via Google Machine Learning
  • sda2
    I wonder how it got there
  • gixxer
    To anyone tracking their DME information:
    Anyone has this hardware number MSS54HP variant? If so, then what model year is the car?
    DME/ECU Type: MSS54HP
    DME Version: 211323002701-J469
    Transmission Type: 6 Speed Manual
    Chassis: E46
    Hardware Number: 7842981
    Thanks.
